Question about Cameras
Missing screws on side of case - Cameras
2 Suggested Answers
SOURCE: Strimmer Case Removal
there are 2 small screw under the black plasic part. If you've taken all the "visable" screws out the molded plasic part snaps off. Also there is 1 screw under the label. Use your finger to locate the hole and just poke your screwdriver thru it label to remove it.
I hope that helps a little.........
Posted on May 31, 2008
Missing bottom case screws-need size
Sometimes there is a screw code next to the screw. Look at this code and then find a screw code with the same code, then remove this matching screw and yiu will be able to identify the screw you need.
Oct 17, 2012 | Dell Vostro 3500 Notebook PC Core i3...
When i open my Toshbia Satellite C655-65132 Laptop the right side of near the the edge of the computer pops up
Try any computer repair shop. They will probably give you the screws free of charge. I'm sure they've got plenty of them laying around.
May 13, 2012 | Computers & Internet
Missing screw on bottom of Toshbia Satellite C655
Further reading of you posts tell me that there is a screw missing as you say so screws are needed to keep parts together. Without them inserted things are loose especially when doing the lid back and forth. It may make noises because of the missing screw or screws. "Replace" the screws that are missing. This should stop that noise.....John
How do i remove a harddrive from a computer case when only one side has screws to remove? Details: Okay so i'm trying to remove a hard drive from a computer case that only has screws on the back right...
In this case the hard drive is mounted in a frame. Look for mounting screws that locks this frame to the computer case. When you remove this frame you can access the screws holding the hard drive.
Jun 12, 2011 | Compaq Computers & Internet
Stiches are loose in the bottom side of the cloth,if i change the bobbin case....will it help? I can understand that tension of thread is the problem.....but don't know what to do
the case the bobbin goes into has a little spring on its side .. the spring has one or two screws. one screw adjusts tension on the spring .. the bobbin thread goes under that spring when it is properly threaded .. if the screw is loose or missing then replace the screw or tighten it a little so that thread pulled thru the bobbin case spring has a bit of drag .. if its too loose then you can tighten the screw a bit more ... if you tighten it too much then it will pull the top thread thru to the bottom .. if your adjustment screw or spring is missing then you can replace the bobbin holder .. the new one should have the spring in place and be properly tightened .. . often the adjustment screw is just loose or the thread is not positioned correctly in the bobbin case slot. .
Jun 21, 2010 | Vacuums
Hi I removed all the screws, and took apart my Toshiba Satellite M35X-S149 in order to resolder the power supply to the motherboard, however with everything out, the motherboard won't come out of the...
If you do not have a disassembly manual, here is one to go back and track your steps.....There may be other connectors you have not detached. Check carefully, screws aren't the only things holding the mobo in place. I think the M35 uses special nuts on the VGA port, these have to be removed for the motherboard to release....There appears to be one screw holding the system board to the lower case, with the board facing up, look in the middle and toward the top right edge of the board, there is a screw along the right edge. 2nd hole down, remove that screw and lift the right side of the board. Make sure all the wire and flat cable connections have been removed.
http://tim.id.au/laptops/toshiba/satellite%20m30-35.pdf
Nov 07, 2009 | Toshiba Satellite M35X-S149 PC Notebook
Dryer door/casing is loose on hinge side of door
you can go to repairclinic.com and enter your model number. It will list all the parts. Find your hing and screws and your set.
Apr 13, 2009 | Frigidaire GLEQ2152ES Electric Dryer
May 22, 2008 | Black & Decker String Trimmer Cordless 12"...
Missing crib screws
HI,
it seems there's a lot of screw are missing but i can help you with that, just search on this site:
http://www.bestmattressreviews.com/simmons-beautyrest-mattress.html
or also you can buy it on the store nearest you,
thanks,
May 14, 2008 | Simmons Mattress Matino - Sno White Crib
Cameras Logo
136 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
