Question about GE Spectra JBP78 Electric Kitchen Range
A portion of the the heating element broke off
The oven wouldnt preheat - opened the oven door and saw the element broken, its about a 3 inch piece
  • 5,911 Answers
This does happen from time to time when the element goes bad. I've witnessed many of them blow open in this manner. This can also occur if something spills over in your oven and leaks directly on to the element. You will require a replacement heating element to restore your oven feature. The following link explains the steps required to replace an electric oven heating element:
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
This is a very simple repair that usually isn't that expensive if you wish to repair yourself. You can order a replacement on line from any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop all of them for the best deal. You will need to use a more complete model number (usually located on a nameplate around the oven door opening, lower drawer opening, or back of the operator console) to get better results for your parts search. The model number you provided only returns partial results.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: In some circumstances, the element failure can cause the Electronic Oven Control (EOC) board to fail. This is the control board on the operator console that controls all the oven features.
Posted on Oct 01, 2009
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    Oven won't hold temperature.
    If oven is electric pleace check that the heating elements are ok, could be that only one or two elements could be the only heaters hence luck power to maintain temparature when open or gets too slow to preheat.
    Aug 03, 2015 | Ovens
    Thermostat broken
    Good Morning a_t_pearson, this is Z. Thank you for your post! I understand that the thermostat is broken on your top Frigidaire oven; therefore I'm assuming that you have a double-wall oven. If so, please help me understand what you are referring to by thermostat? Is your oven not preheating or reaching desire temperature? Are you speaking about the bake and/or broil elements not heating? May I please have your model number? The serial tag, which lists your model number, is typically located on the front of the oven, on the left side, as you open the door. With this information I can better address the issue at hand. Thank you!
    Apr 01, 2014 | Electrolux Ovens
    How to change the lower element on a delonghi AD 699 toaster oven?
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Last night, we were using our Frigidaire oven to heat some salmon. My wife openned the oven door and there was a bright flash with sparks and a crackling noise, and a 1/2 inch portion of the element caught...
    Kill the power to the stove. L2 is always hot to the element. If it welded itself to the frame whats left of the element stays hot. Easy fix but power needs to be OFF
    Apr 17, 2010 | Ovens
    Model GBS307PDQ5: Oven preheated to 425 degrees.
    F3 usually means, that the oven temp. sensor is bad and one need to replace it.
    The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
    Whirlpool oven repair orange county, ca
    Feb 06, 2010 | Ovens
    Do I leave the oven door open a little while broiling?
    Yes, it is a good idea to let it open just in the first posistion which gives it about a 3 or 4 inch opening at the top. This will hold enough heat in to broil your food but will let enough out so that the ovenwill not over heat and it will keep the burner on. Usually broiling times are not that long so this will not over heat your home or present any other dangers. Of course you still want to preheat the oven with the door cloded for best results.
    Heatman101
    Jan 28, 2010 | Kenmore Ovens
    HEATS UP BUT TAKES 2 TIMES LONGER TO BAKE, tried cookies and cake, had to keep putting back in for longer. Did not burn, but had a weird consistency. Looked at baking coil, 'looks' fine and does get...
    your bake element should get red during the preheat time and also if you leave the door open after it has preheated.
    if it is not that will cause your oven to not heat right.
    even if it looks ok, it could still be bad.
    unplug the oven and remove the bake element, then take it to your local parts house and they can check it for you.
    this is the most common problem, but it could be a problem with your oven control. try the element first.
    Jan 09, 2010 | Amana ACF4225AS Electric Kitchen Range
    Bake element split and oven will not heat.
    thats an eazy one by a new element from one off our links at fixya and install it with the power off and no theres no reason why this happened it just wore out God bless,tom
    Jan 01, 2009 | GE Spectra JBP78 Electric Kitchen Range
    GE Spectra JBP78 Electric Kitchen Range Logo
    202 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
     Fix Your Board
    Fix Your Board
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
