Question about Frigidaire Dryers
Only spins for a second then turns off - Frigidaire Dryers
  • Frigidaire Master
  • 7,482 Answers
You might try to remove your belt from the motor and see if it runs any longer with out trying to turn the drum...if it does the same, then I would say the problem is probably the motor.
Turn your power off and try to rotate the drum by hand 1/4 to 1/2 turn, then turn your power back on and try to restart the dryer. Sometimes motors get dead spots in them and this may help..
Hope this helps
Posted on Oct 01, 2009
How do i reset code F21 to a Bosch Maxx 7 washing maschine?
Turn knob to 12 o'clock position
turn to 6 o'clock position
press an hold the spin button
turn knob to 7 o'clock while still pressing the spin button
let go of the spin button after 5 seconds
turn the knob back to 12 o'clock
assuming you have repaired you're f21 motor issue it should behave its self
Mar 27, 2015 | Bosch Washing Machines
I have an error message f51 on my whirlpool cabrio washer model number WTW7600XW0, What is it and how can I fix this error on my own
F51 error code is a motor rotor position sensor failure or a lower harness problem. You need to check the motor in manual test mode, not automatic test mode. This will check the hall sensors and do a spin test: Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on). Select any one button (except POWER, START, STOP, and PAUSE/CANCEL) and follow the steps below, using the same button: Press/hold 3 seconds. Release for 3 seconds. Press/hold 3 seconds. Release for 3 seconds. Press/hold 3 seconds.
If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display. During the 5 second wait time with 88 showing in the display, press the same button once. You should be in manual test mode. If the button is not pressed within 5 seconds, the automatic test mode begins. The Rotor Position Sensor uses Wash, Rinse, and Spin indicators to detect the three hall sensors. Console can have up to two of these indicators on at the same time when the tub is not moving. Open the lid and rotate the basket by hand. The Wash, Rinse, and Spin indicators should toggle on and off according to the direction the tub is being turned.
SPIN TEST: Make sure lid is down. Press and release: 2nd RINSE or EXTRA RINSE. The lid locks and the lid lock indicator turns on. Press and release; SPIN SPEED, WATER LEVEL, or LOAD SIZE. The motor/basket spins at 23 rpm. Press again, motor /basket spins at 530 rpm. Press again, motor/basket spins at 950 rpm. Press again and motor turns off.
Oct 24, 2014 | Washing Machines
What does error code f 51mean?
http://www.applianceblog.com/mainforums/threads/32879-Whirlpool-Cabrio-UL-F51-Error-Codes
Jul 27, 2014 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
How do I fix a f51 code on a whirlpool cabrio washing machine
SPIN TEST: Make sure lid is down. Press and release: 2nd RINSE or EXTRA RINSE. The lid locks and the lid lock indicator turns on. Press and release; SPIN SPEED, WATER LEVEL, or LOAD SIZE. The motor/basket spins at 23 rpm. Press again, motor /basket spins at 530 rpm. Press again, motor/basket spins at 950 rpm. Press again and motor turns off. This was a cut n paste from a blog on that issue.
Apr 22, 2014 | Washing Machines
My netbook fan spin just for a second and then shuts down
Is the netbook functioning otherwise? Fans often spin on startup, then turn off until they are needed.
Feb 05, 2014 | Computers & Internet
Hi, How Can I Reset error in my wash machine Bosch
You can reset the error code by the follow steps.
Turn the knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code.
Sep 26, 2013 | Bosch Washing Machines
I have a Maytag Neptune TL. The machine is working normally except it's not able to fully extract the water out of the clothes. When the full cycle is complete the clothes are still dripping wet. I have a...
We are talking about FAV6800A or FAV9800A TL correct?
If so you need these links the Service Manual and parts look up; here is the Service Manual for reference. Sears Parts Direct for reference.
If your machine completes the wash cycle with no error code such as ND (No Drain) and there is no visible water in the bottom of the wash basket when you remove your wash load then I would do this test.
Take the next wet wash load that is dripping wet and lets do a Quick Spin Test in Service Mode. During this test test the FAV6800A LED display model will step thru the RPM (revolutions per minute) or goal is to ensure the machine will spin the wash basket up through all Spin Cycle RPM ranges. Any RPM range above 99RPM’s will be shown with a (.) dot after the two numbers displayed i.e. 350RPM will show as 35. 550RPM will shoe 55. And so on.
I’m and owner of the FAV6800A and I’m not sure what the LCD display of the FAV9800A will display.
Enter into Service Mode;
Page 14 of the Service Manual; below I have cut and paste the instructions.
Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the control beeps.
Now go to page 14 and enter this front panel key pad press to start a Quick Spin Test and see if the machine with that wet clothes load will spin the wash basket to 850RPM.
Quick Spin Test
While in Service Mode, press the Hand Wash
key to start a Quick Spin Test.
Quick Spin test steps are as follows:
1) Lock the lid.
2) Spin to index speed 90 rpm and hold for 60
seconds. Pump drains machine.
3) Spin to index speed 150 rpm and hold for 6
seconds.
4) Spin to index speed 350 rpm and hold for 6 seconds.
5) Spin to index speed 550 rpm and hold for 6 seconds.
6) Spin to index speed 700 rpm and hold for 6 seconds.
7) Spin to index speed 850 rpm and hold for 6 seconds.
Pump out.
8) Coast down to 0 rpm chimes 3 times.
Hit the Off button to get out of service mode.
If the machine spins the wash basket to 850 RPM then we need to start looking further. What are your results?
You can check the flow rate of the drain system by again entering Service Mode and turn the Drain Pump on in service mode. I would (hand fill) place 5 gallons of water in the machine and turn on the drain pump see page 16 for Board Output Test.
Enter Service Mode and press the Delicates key. You are now in Board Output Test now press the Presoak key and the Drain Pump will turn on. If your machine pumps out the 5 gallons of water in 60 seconds or less I would say your Sump Cap, drain line connection from Sump Cap to input to the Drain Pump, Drain Pump and discharge line are all working as designed. If the Machine takes greater then 60 seconds to dump the water then you need to start troubleshooting for a drain line restriction or Drain Pump issue…...Rich
Apr 05, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washine machine won't turn last spin.
If it has a Start-Reset button, try pressing and holding for 3 seconds..
Select a drain and spin prog and try again
Plz rate my suggestion.
Thanks.
Dec 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Service Mode
System Diagnostics
SERVICE MODE
The service mode provides service personnel the
ability to verify the operation of the washing machine.
The service mode can be entered in the middle of
any wash cycle. While in the service mode, the
servicer can start a variety of special service tests.
Accessing Service Mode:
Pressing down the delicates and heavy soil keys for
3 seconds places the machine in the service mode.
Motor speed will be displayed when started. To exit
Service Mode, press delicates and heavy soil keys
for 3 seconds again.
Troubleshooting
December 2004 4 16025861
©2004 Maytag Services
Stage of
Wash Cycle
Advances To
Presoak End of Presoak
Wash Every 5 Minutes of
Wash Time
Spin/Drain Every Step of The
Spin Profile
Rinse End of Rinse
Speed Range Displayed
a) 0-99 rpm 0-99 (actual)
b) 100-999 rpm Speed / 10
Quick Service Cycle
While in service mode, pressing the delicates key
will start a quick service cycle. This will be a quick
check of all systems.
The following steps will be followed.
1. Energize the cold and bleach water valves. Fill to
Low level, then turn bleach and cold off.
2. Energize the hot and fabric softener water valves. Fill
to high level, then turn all valves off.
3. Lock the door.
4. Tumble using 7/3 tumble pattern for 12 sec.
5. Turn the drain on.
6. Spin to 800 RPM using default rates.
7. End spin and coast down.
8. Unlock the door when the RPM is zero.
9. Display a ‘PA’ (Passed) on continuously for 10 seconds
if no diagnostic codes were logged during this
test.
The up arrow if pressed will advance to the next step.
The right most dot will be turned on as an indication
of failure and stay on until quick service cycle test
has reached the end. Any diagnostic code logged
during this test will result in failure of the test, but will
not necessarily stop the test. While in quick service
cycle, the pressing of the hand wash will suspend
the machine at this step for 30 minutes until the
Hand Wash key is pressed again. All LED’s will
flash on and off while the cycle is suspended, or on
hold.
Motor Drive System
To check the system, check the board for proper
output to the motor control. Performing a board
output test does this. Then perform the Motor
Control Board Output Test.
Motor Control Board Output Test
1. Disconnect power to the washer.
2. Remove the front panel and pull the JP4 Connector
from the motor control board.
The following Quick Spin test steps are as follows:
1) Lock the door.
2) Spin to 350 rpm and hold for 6 seconds.
3) Spin to 550 rpm and hold for 6 seconds.
4) Spin to 600 rpm and hold for 6 seconds.
5) Spin to 650 rpm and hold for 6 seconds.
6) Spin to 800 rpm and hold for 6 seconds.
If the Spin key is pressed again during the Quick Spin
test, the current speed will be held indefinitely. Pressing
the Spin key again will allow the quick test to
proceed as listed above.
When the washer is in the Service Mode, the speed
will be displayed as a two digit number or a letter/
number.
Quick Spin Test
While in service mode, the pressing of spin key shall
start the washer in the quick spin mode.
3. Reconnect the washer power cord to supply
voltage. Make sure the door is closed.
4. Press delicates and heavy soil keys for 3 seconds
to activate Service Mode.
Jan 23, 2008 | Maytag Neptune MAH5500B Front Load Washer
Dryers Logo
29 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
