Question about Polaroid I533P Digital Camera
It does not turn on but isn't broken. - Polaroid I533P Digital Camera
Spa waterfall isn't flowing
If you turn the valve to operate the waterfall feature on your spa and no water is coming out of it, my best guess would be the valve is broken and not turning to allow the water to go to the waterfall.
Pull the top of the valve off and look inside for a broken part.
Rod
US Parts Center
888-521-6183
Feb 11, 2013 | Pentair IntelliFlo VS-3050 & VS+SVRS...
The key is there but the alram isn't. How do I turn the car on?
Hi Tony, Take up the broken pieces and if there is a battery in the key connect it to the broken pieces, insert the key holding the broken parts in the same relative position and start up. Get the key replaced asap. Regards John
Oct 13, 2012 | 2003 Jaguar X-Type
Broken screen
The screen is completely broken and isn't worth the time or money to replace. You're better off purchasing a brand new TV.
Jul 12, 2012 | Coby 40 TFTV4028 LCD TV
Why isn't the sewing machine wheel turning
it could be a problem with a belt , motor, a loose or broken part
taking the machine to be checked is the best solution
Jun 03, 2012 | Singer 2932 Mechanical Sewing Machine
Distributor not turning
Is it locked up or not turning when you try to start the car? Pull the distributor out and make sure the shaft isn't sheered off or the teeth aren't broken. You may have a seized up distributor shaft and it could have broken.
Jul 24, 2011 | 1984 Toyota Celica
Ge dryer not turning. tries to start making a humming noise. doesn't turn.
check the belt and tensioner, make sure the belt isn't broken and if not , make sure its tracking correctly
Jun 16, 2011 | GE Dryers
People can not hear me but i can hear them
Make sure that the phone isn't muted. There should be a button that looks like a microphone. If it's gray then the phone is muted. If it isn't, try using the camera or something to make sure your phone's microphone isn't broken.
May 04, 2011 | HTC Inspire 4G Smartphone
My kyros won't charge
I would first try a different power cord/brick and make sure that isn't the issue. If that still doesn't work then you may have a broken port on your Kyros. In that case try and get a warranty replacement and if that isn't feasible you will most likely have to pay for the repair. If you recently dropped it while it was plugged in, that may have broken the connection between the port and the device.
May 04, 2011 | Coby Kyros 716829701508 Tablet PC
Ignition key won't turn
Make sure you keep your foot on the brakes while turning the stairing wheel left to right try turning the key the sametime.
Oct 19, 2009 | 2000 Saab 9-3 Viggen
Polaroid I533P Digital Camera Logo
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
