Question about Sharp Heating & Cooling
Orange and red light blinking after one minite
I fixed this problem by disassembling the panels. On the front then sides then back of the unit. The first thing I noticed was some debris in the exhaust fan wheel on the back side. I used some long wood skewer to fish out the debris and even shook the unit upside down. (It's very heavy and would recommend help with shaking the unit.) Also, I think i found a little sensor that is about the size of a thumb drive and incased in a transparent plastic box. I tapped it with my finger and noticed this little black thing bounce up and down inside under the green circuit board. its located right above the drain connection. I didn't do anything else with this. I assumed its the sensor to measure the water buildup. I also found a small toy in the front fan wheel that blows the cool air through the top of the unit. fell out during the shake down. The final thing I noticed was when re-assembling the unit. On the front side you will see the two metal radiator looking panels. Between the two panels is a wire sensor that looks like a temperature measuring device. I had noticed it was touching the metal part of the radiator panel so I gently streightened it out so that it was parallel with the panels and not touching. I pressed the power button and it hasn't shut of yet. I snapped the front panel back on and all is good.
I have the white upright sharp AC unit with the three lights in the front and a power button next to the IR sensor. I lost the remote control and couldn't figured out why the unit would start up then shut down after a minute of use. The operation light would blink red then the orange timer light would blink next. Then both lights would blink simultaneously, then repeat. I thought this was a timer setting. but the unit is supposed to reset after disconnected from the power.
Posted on Jun 04, 2015
  • 24 Answers
Inside of your door panel should have a list of fault codes, also you can find fault codes close to the end of your owners manual
Posted on Sep 30, 2009
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
Panasonic standby light blinks Red/Orange why?
set is trying to move from standby to power supply on and not making it, No model indicated so best advice is take to some shop and get an estimate.
Aug 30, 2012 | Panasonic Televison & Video
Pwoer shot G5 red light blinks while charging
Absolutely. It blinks orange (or red) while it is charging. It will glow steady orange when the charge reaches 90% and green when fully charged.
May 20, 2012 | Canon Cameras
Why does my gateway nv53 battery light blink while charging?
Hi, The LED light on your Gateway NV53 Blinks while charging because it was designed to do so. According to the user manual, if the battery light is:
Solid Orange: Battery is fully charged Blinking Orange: Battery is charging Blinking Red: Battery is critically low Solid Red: Battery problems, contact Gateway support immediately.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 22, 2011 | Gateway Computers & Internet
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Blinking orange light
green light mean on
orange light means standby
red light means power failure
no light means the fuse my have blown
good luck
shaun
Jul 31, 2009 | Microsoft Xbox 360 Console
Plasma tv wont respond to the buttons being pushed on the tv
ok ,try cleaning the remote, first.open it up and clean it with alcohol and soft cloth.let it dry.then,assemble it.be sure your batteries are ok.
May 28, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Heating & Cooling Logo
672 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
