Question about Nintendo Wii Console
My wii dropped and now the eject button is jammed and now I can only play wii sports and the inside of the button is probably brocken
SOURCE: Can't get Wii sports disk to eject
From the official Nintendo site:
"The Wii console will need to be repaired. Because this type of damage is not covered under Nintendo's warranty, there will be a charge for the repair. Please call 1-800-255-3700 to discuss available options."
Posted on Dec 21, 2007
Tre_rules
  • 5 Answers
SOURCE: Game Disk
if you have it standing up, lay it down. This happens to me all the time with super smash bros: brawl. Just turn it the other way (if standing lay it down, if laying stand it up) and just move it around (slap) and the disc should come out.
Posted on May 16, 2008
SOURCE: Wii Power, Wii Goes Dead when I press Power or Eject Button or Remote Power Button. Is THIS AN INTERNAL DAMAGE
According to Nintendo u can try this. 1. push the reset button and if that doesn't work unplug all cords and memory cards (including sd) from wii and unplug av from the wii and the outlet in wall. Wait 2-3 min and then plug it back in. Thats as far as i got because that fixed my problem hope this helps someone!!!
Posted on Jun 18, 2008
SOURCE: it wont play my wii sports game but will play others
Maybe that disc your using is scratched or dirty.
Posted on Jun 27, 2009
Ruff_Racer
  • 49 Answers
SOURCE: My wii wont eject games, HELP!!!!!!!!
2 options:
- Disconnect the drive
- You see the white plastic mechanism on your right side and the wheel connected to the motor
- turn the wheel towards the back side of the drive while pushing the half inch square plastic piece towards the left.
You will see the disc coming out while you are turning the wheel.
OR
open the slot a little to be able to see the CD inside, then, on the side of the console buttons, insert a flat butter knife between the underside of the CD just enough to lift it a little, then slip another CD (a blank CD will do just fine) in place of knife, and pushed it in almost all the way, this should release the game CD, then pull the CD out slowly and carefully, and it should drag the game out.
Posted on Jun 29, 2009
Will not eject disk
Is your eject button broken? Does it click when you punch it, or goes in like the button on the board is broken?
It is either this or there is something jammed inside your system.
Video: How to open Wii Console
Check inside your drive and remove anything stuck in there causing the drive to not function correctly when ejecting.
Hope I helped!
Take care
May 09, 2010 | Nintendo Wii Console
Wii disk will not stay in the console
Has anything been jammed inside the Nintendo Wii to cause this?
Has the Nintendo Wii been dropped?
There are usually 2 causes for this.
The Nintendo Wii disc drive could be damaged and/or something is jammed inside the drive causing the discs to automatically eject.
Also, your firmware could have malfunctioned, causing the drive not to work.
If you have experiencing opening the Nintendo Wii up, I would recommend you do so and look to see if anything is stuck inside.
if you're not comfortable doing so, I would recommend for you to send this system in for repair.
Apr 19, 2010 | Nintendo Wii Console
Game will not eject. I've tried disconnecting power & still nothing. The Wii still plays the game disc fine.
Hope I helped!
Apr 12, 2010 | Nintendo Wii Console
Two games stuck inside console...eject button not ejecting either
The only way to get them out would be to open the WII manually. They have secured screws so they can't be open easy. **** lines in them and unscrew them. The reason it will not eject is because they are jammed inside.
Mar 24, 2010 | Nintendo Wii Console
Sync button is jammed on Wii
The two buttons are broken from inside.Your Wii need to be repairing.Contact the Wii service.
Oct 05, 2009 | Nintendo Wii Console
I drop my nintendo wii console, and later I tried to eject the disc,but it didn't work. I could only play the game that's inside the wii.
I've seen many people with this same problem.
I think if you drop the Wii, the disc ejecter breaks or something. Then you can't eject the disc or vice versa because the ejecter is broken. Call Nintendo Customer Service (1-800-255-3700 in the USA or Canada) and try to get it repaired.
Jul 17, 2009 | Nintendo Wii Console
Disc is stuck inside goes on will not eject or
You will find a small whole in front of the disc. Quite small, say a niddle head size just take a pin approx 3 inches and poke it slowly inside. You shall feel the pushing of a soft touch feather button like on your keyboard and your CD will come out. Don't forget to push eject button before poking the pin. and kindly do rate my solution.
Eject button not ejecting
mmm, try eject the game whit the wii face up side down
Apr 17, 2009 | Nintendo Wii Console
Wii console will not eject disk
I managed to eject a WII disc out manually very easily:
Nov 25, 2007 | Nintendo Wii Console
Cd stuck
Well, Recently the same thing happened to me, My bro dropped my WII on the floor and the eject button on it got stuck i was soo mad!!!
I tried loads of ways nothing really hard, just follow this and hope fully the WII will eject:
1.Make sure the WII is stood up properly.
2.Then switch on the WII (As i said early the WII won't eject the CD.
3.Now look near the eject button if it is stuck follow (A) or if not coming out follow (B).
(A1).Right if it is stuck and not coming out then the top bendy bit of the eject button put your nail through it and press it down it should eject but after a while it did not work any more for me :(.
(A2).Now, Disconnect all the Cable's in the WII not TV leave it for a while (and don't smash it again!), After a while approx 5 Min's plug 'em back in, switch on the WII then press eject hopefully that will work :D.
(B1).Now if it does not come out either look inside the drive or WII (I don't suggest that) or just do what i did with A2 hopefully that will work.
Hope your WII works by now and enjoy ejecting cd's from your WII but 1 more thing before you go (DON'T BREAK YOUR WII AGAIN OR YOU WILL HAVE TO DO THIS ALL OVER AGAIN :P AND IT MIGHT NOT EVEN WORK IF SMASH IT TO MANY TIMES!!! SO BE-CAREFUL!!!!
Sep 30, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
166 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
