Question about Sharp AL 1631 Copier
SHOW CH CODE - Sharp AL 1631 Copier
    President:
  • Sharp Master
  • 990 Answers
Hello sir ; CH code it means some where the door is open ,check the side door.
Posted on Oct 01, 2009
My sharp ar-5520 error code CH please help me
There are 2 possible causes for CH code.
If CH is flashing on the display then the developer unit is not installed correctly.
If CH is static then the right hand side door is not closed or closing correctly.
Hope this helps.
Dave.
Sep 23, 2017 | Sharp Office Equipment & Supplies
What is the pin code for Aiwa HVFX5500 vcr
hi ,
Try...
Power on,
Press both CH/UP key and REC/OTR key for more than 2 seconds,
OK will appear in the display panel.
or try
Press CH DOWN key on VCR while pressing the 7 key on remote and hold for more than 5 seconds.
The display should then show OK.
but First disable the child lock by pressing the "lock" button on the remote,
and only then press "Ch-" and "7".
Oct 02, 2014 | Televison & Video
How do i record a show onto a tape?
lets say you are hooked up correctly (cable to VCR in (from cable/sat box) & cable to TV from VCR out) and the VCR is set to Ch 3,, (PLEASE NOTE THE TV MUST BE ON CH 3)
program a recording
the VCR clock / date must be set and not flashing 12:00
then you go to menu, program a recording by imputing the start time / end time of the show and the date it will be recorded and Ch 3...(you might have to set your cable box for the same date/time as the VCR or manually turn to that ch you wish to record that morning or before you go to bed) put a new tape in the machine....
manual recording
a show,game or special comes on and you sitting and want to watch and record and even edit (no commercials) put tape in... press record button get the remote so you can pause (on commercials) and press pause again to resume recording
HAVE FUN
Dec 26, 2010 | Sony SLV-678HF VHS VCR
How do you program a code in
Look at the book and find the code for your tv..there may be many listed...1st = hold the program button down till the red light comes on. 2nd = put your code in press enter 3rd= then try ch. up and down..tv need to be on to test. if this doesn't work try a different code repeat. 2nd way to program... turn the tv on... do step 1 then press ch. up slowly over and over till the tv changes ch. when it does...press enter..it make take 100 or more ch. ups to find your set...don't get in a hurry....
Oct 23, 2009 | RCA Universal Remote Control
Sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly installed
For the 'CH' check the covers and make sure all covers are closed properly.
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Mar 03, 2009 | Sharp AL-1641CS Laser Digital Copier
Code CH on Sharp copier
CH code on a Sharp usually means the front door or a side door is not completely shut. Try opening and closing every exterior door until the code goes away. If the CH is flashing, it could mean either an optical or a heat roller fuse might have blown. Have you recently replaced any supplies?
Feb 27, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Sharp AR-160 has an error code CH when you power it on
Actually that means your out of ink. Odd code, but that is what is means.
Jan 29, 2009 | Sharp AR-160 Copier
Digital Copier
I believe a ch code on sharp is an indcation one of the covers is open.
Mar 23, 2007 | Sharp AL 800 Copier
Sharp AL 1631 Copier Logo
87 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
