Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Opener will hum but not engage the drive train.
    President:
  • 3,197 Answers
If the humming you hear is the motor running you need to remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. If it is the motor humming but not turning you have a bad start capacitor which is held by a bracket and is next to the motor.
Posted on Sep 30, 2009
    Sniper:
  • 98 Answers
Sounds like your operator ran past the limits and the traveler is jammed against the front or rear stop bolt. if you remove the cover and turn the motor shaft you should be able to free up the traveler. then reset the limits. You might have to replace the bottom bushing on the motor bracket. It will come with part # 41c4220a.
Posted on Oct 02, 2009
Stanley pt300
The humming sound is from the door opener motor, it is likely mechanically jammed. Release the opener and try opening the door manually to see if the door is out of alignment or jammed.
Nov 21, 2017 | Vehicle Parts & Accessories
Humming noise when car is moving
most likely if its a hum it could be tires , if its a roar it could be the drive train
support the vehicle on jack stands , start the engine , put in drive and let it idle, if noise is gone ...its the tires if not check the drive train ...start with fluid levels
Mar 30, 2012 | 2003 Oldsmobile Alero
I just installed a Sears Craftsman 1/2 HP Garage Door opener. As I was doing the adjustment to keep the door closed, it closed too tight. I disengaged and confirmed the door arm was set wrong so I fixed...
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
May 04, 2017 | Sears Genie Garage Door Gpwk12 Wireless...
Steelcraft garage door opener opened but will not close. Motor hums but door does not move.
Ensure proper installation. Ensure gears in main control head box are not worn out, The main drive flat gear is plastic in a lot of these openers. Replace main gear unit are rebuild it.
Apr 24, 2011 | Craftsman 34 Hp Garage Door Opener Chain...
My 41A4315-7a Garage door opener Motor does not engage. It just hum sfor a second then stops. I checked the internal gears and they seem fine. The door buzzes for a second then stops. Any Ideas.
If the door is not stuck in the open position and just hums you could have a bad start capacitor. It is alongside the motor and has 4 wires going to it.
Dec 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
2003 Rendezvous TracOff lite comes on when making wide turns
You probably have a wheel hub/bearing going bad. Thes usually have sensors in them that will cause this issue.
Apr 14, 2010 | 2003 Buick Rendezvous
Motor hums but door doesn't move. If I disconnect door and give chain a horizontal poke, it will move. When I reconnect door it returns to humming, without movement.
Remove the cover from the motor unit and you will find the drive gear has stripped. White sawdust all over. The part number for the gear kit is 41A2817 and it comes with instructions. It is available at any good door opener service company.
Feb 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Motor hums but door will not open
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. The part number is 41A2817 and is available from Sears or any good door opener service company. It comes with instructions.
Jun 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
LIftmaster light flickers but won't open garage door
check your wire connections at the opener one of the little wires probably broke
Jan 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster moter hum's and the chain drive will not move
Try opening the case and looking to see if there is a white plasic powder in the bottom of the case. if there is you will have to replace the gears #41C4220A.
Dec 16, 2008 | liftmaster Chamberlain Garage Door Opener...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
413 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
