My cd/dvd rom is not found in My computer but it is installed (code 39)
My cd/dvd rom is installed but it is not found in my computer. If I try to update the driver it says it is up to date. In the device manager it says it is installed and working but it has a yellow ! next to it.
  • 3 more comments
  • daydo Jan 23, 2008
    i get code 39 i have tried to renstal it and i get a yellow box next to it
  • Anonymous Apr 04, 2008
    driver not found.
  • 2ephslc Jun 10, 2008
    my dvd/cd drive is an insert (floppy drive fills same slot) and it disappeared from the computer. I have uninstalled and restarted computer but no luck.
  • Anonymous Oct 07, 2008
    same problem
  • Anonymous Apr 19, 2009
    my dvd burn not appear on my computer system tools
  • 383 Answers
What programs can I use to burn or create CD's on my computer? A standard CD-ROM drive is not capable of creating a CD even if you have any of ... If you're running version 10 or higher and have a CD/DVD burner drive .
Good Luck, Please dont for get to Vote/Thank You
Posted on Dec 20, 2007
CD ROM won't recognize CD's/DVD's
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Dec 13, 2012 | Compaq PRESARIO C500 COMPATIBLE LAPTOP LCD...
I have an Acer Aspire 5332 and the CD-Rom/DVD Drive (Optiarc DVD RW AD-7580S ATA Device) is not working properly...every time I put a disk of any kind (i.e CD/DVD/Game) it doesnt recognize it and load
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
Mar 22, 2012 | Acer Computers & Internet
Dell latitude 6500 dvd code 39
you might have to uninstall then restart your computer then reinstall your cd rom or uninstall the driver then reinstall for this device
click start Control panel administrative tools computer management device manager scroll to cd/dvd rom drives + to expand could be a yellow question or exclamation mark ? ! or a red X right click update drivers
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
to check the registry
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
Feb 25, 2012 | Dell DVD-rom DVD Drive
My HL-DT-ST DVDRAM GMA-4020B needs drivers, and I do not have the orignal installation cd. I am able to read cd's but not dvd's.
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might have to turn off your computer physically unplug the leads that attach to your dvd ram restart your computer then reattach the leads
this should activate the found new hardware wizard then set it up again
hope this helps
Sep 11, 2011 | LG GMA 4020B DVD-RW Burner
Hi, i am using LG dvd rom HL-DT-ST_DVD-RAM_GSA-H55N on Windows XP platform. my dvd writer is detecting cd's but not detecting dvd's.i had flashed the dvd rom by LG firmware but that does not...
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom restart your computer then plug them back in this should activate the found new hardware wizard
hope this helps you
Sep 10, 2011 | LG GSA-H55N DVD-RAM Burner
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Cant install my cd rom
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Mar 28, 2009 | Pioneer DVR-107D DVD±RW Burner
DVD/CD-ROM DRIVES driver may be corrupted or missing. (Code 39)
To solve this Code 39 error, follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Another possible CD/DVD issue you may want to investigate
Oct 12, 2008 | Computers & Internet
DVD/CD-ROM driver does not not run any types of disc.
Dear Xu Ling ,
Its O.S. related problem please try to install this drive on another Computer and i'm sure it will works perfectly. in this case you have to re-install the OS on your Existing Computer, if you wanna use it on your own PC.
Takecare
Mar 26, 2008 | Computers & Internet
Computers & Internet Logo
478 people viewed this question
Alun Cox
David Payne
David Payne
