It sounds like you have a pieces of dirt in one of the carburetor jets. When you load the engine it can't get enough fuel to stay running and stalls out.
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
I would need more information to give you a good answer. I need to know how long will it stay running a few seconds an hour what is it. I had a 2000 blazer that would start fine everyday and i would 10 minutes and it died sometimes i drove an hour and it died. I parked it and everytime i started it would run about 10-15 minutes and die. after it would die i would check fuel pressure which was good and spark. Well turns out there's no spark so i changed coil ,plugs, wires, rotor. I finally changed the crankshaft positioning sensor and that tuned out to be the problem so good luck.
A Toyota will not run with the battery disconnected, it doesn't mean an alternator problem only a voltage and load test can determine that, it is unique to S\some Japanese cars and light trucks.
it maybe the battery, a quick and easy way to find out is boost it with a vehicle and leave the cables hooked and see if it will stay running under a load, if it does then the battery may need to be changed.
hi, i need to know something about your car in order to help you.
does your car have a distributor or 2 coil packs under the manifold.
there is 2 different problems.
i think your prob is your fuel pump breaking down under load, its common, get back to me 1st with my question before u do anything.
Does the engine die as soon as you release the key, or does it run for a couple of seconds after you release the key and then die? If it dies as soon as you release the key, try holding the key for a few seconds and see if it will stay running as long as you are holding the key (the starter will make a grinding sound while holding the key but won't hurt anything). If it stays running while you hold the key then dies when you release it, that indicates that the ignition switch is bad.
