Question about NetGear Computers & Internet
Laptop not picking up router that is connected tomy pc
Laptop not picking up router that is connected to my pc
    Problem Solver:
  • 17 Answers
Your wireless settings may have the SSID Broadcast switched off. If this is the case, your laptop will not 'see' the wireless network. You will need to manually add the wireless connection or turn the SSID Broadcast back on.
Posted on Sep 30, 2009
Asus eee 1000 wll not connect to internet, it has picked up the wireless connection but still pages will say cannot connect. Is there a button to turn on?
maybe your routers security is running a type that is not compatible with your laptop, change the security wireless setting on the router and see what happens
use psk2 type
Jun 05, 2010 | ASUS Eee PC 1000H Laptop
When i hook it up i get the laptop to pick up the signal but the desktop will not go online
on the hind side of the modem how many ports do you see
my guess one port slightly seperated and named INTERNET or WAN and four more ports numbered 1,2,3,4
now connect the network cable from the modem to the WAN / INTERNET port and connect the laptopand PC to the ports1,2
now check to see if there is connection to only on Laptop or both
but if you have conection to only the laptop/PC connected to port1 then try this small trick
move the laptop to port 3 and in port 1 connect the cable from the modem which was connected to the WAN / INTERNET port
and u r set to go
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Lose router signal everytime i restart my laptop
This seems to be an issue with the router itself. As the laptop is able to connect to other networks easily, the trouble seems to be with the router.
Try updating the firmware on the router. Also, change the wireless channel on the router and check if that helps. If the issue persists then I believe you will have to get the router replaced.
Jun 21, 2009 | Zyxel (91-004-361002) Wireless Router
No comunication between router and cable modem.
this is because your PC is picking up the WRTG54G which is an internal signal booster (internal gateway) to the ROUTER ITSELF.
WRTG54G is in the middle like an interpreter.
The WRTG54G is not connect to ROUTER>
thus the laptop is not connected, like sprinkler attached to the end of a hose but the HOSE not attached to the water faucet.
turn OFF laptop. RESET WRTG54G (there is a small hole you can stick a pencil in there and hold down for 15 long seconds; UNPLUG power.
PLUB back in and hit auto config button.
let WRT54G pick up a new IP ADDRESS from router. once that is done turn on laptop and it should pick up a new signal with new IP address assigned to it by the WRTG54G.
Apr 26, 2009 | 2wire HomePortal 1100 Router...
How do I get internet on my laptop from my pc not using a cable?
what you would need to get is a wirless router. If you have high speed internet then you can plug the internet modem into the wireless router and then plug your main pc into the router via an ethernet cable and then set up your laptop to pick up the signal wirelessly. If you have dial up internet then you would still need a wireless router but it is a little more complicated. You could hook up the router to your main pc and then set up internet connection sharing so that way your laptop could pick it up wirelessly. hopefully this helps.
Apr 10, 2009 | HP Compaq Presario v3000z Notebook
I have a acer aspire 5315. I bought a D Link dir 615 wireless internet router. The problem I am having is that I can connect to the router, but I cannot connect to the internet. What is the problem?
Hi the router has not picked up your IP address.follow this Turn off your wireless router and internet connection and your laptop aswell for 30secs .Then first turn on your internet (if seperate from the router) if not switch on the wireless router/internet hub and wait untill the lights stop flashing then switch on your laptop and that should work.
Dec 15, 2008 | Acer Aspire 5100 Notebook
Connectivity issues with linksys router
If it worked before it should work again. Turn the router off for 30 seconds and try again. Als make sure that the wired PC connects to port 2 or above.
Bob
Jul 28, 2008 | Linksys Wireless-G WRTP54G Router
Settings in laptop for wireless connection
Most of the time the encryption key is typed wrong. make sure that yours is correct.
Dec 31, 2007 | Acer Aspire 5630 Notebook
Computers & Internet Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
