Question about Abit AV8 Motherboard
ABit AV8 error code 9C what does this mean? Computer wont boot up, giving me this message. HELP!!!
    Problem Solver:
  • 20 Answers
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
a19
Posted on Oct 10, 2009
I have an abit av8 mother board and am tryng to install a new power supply (G7 powr exteme) the LED2 is flashing with with no constnt power availabe to power up te system please help is my board or th
Hello here is the homepage:
http://abit.ws/page/mi/download/download_driver.php@pFUN_KEY=9000&pTITLE_IMG=_2Fdownload_2Fimages_2Fdownload.html
You have probably connected the +12 volt 4 pin, connector wrong.
The pci-e graphic connector, sometimes fit here.
When this happends the mainboard will not boot up.
Try to read the manual for the power supply.
Good luck
Nov 09, 2012 | Abit Computers & Internet
When i boot up the computer it starts beeping immediately, otherwise boots just fine
The beeps are part of the boot sequence, more normally called the post report. The beeps length and number usually indicate a problem.
Check with the abit website, you need the post sequence for your motherboard.
Usually, with a post report, you get a single beep which means everything is tickety boo.
Feb 06, 2011 | Abit AV8 Motherboard
Wont boot up abit ag8 error code f.o tried
F.O. code points to button reset? This one is beyond me, suggest you see if the reset button is sticking on and causing it not to boot ( try bypassing this and the power switch and fabricate a switch to power the board on)
Jan 01, 2011 | Abit AG8 Motherboard
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
When i boot my pc the led get to 8.6 then goes to 9c i then get one long beep followed by four smaller beeps
Memory refresh toggle test failed
Try one Memoryblock
I think your memory is bad
Jan 30, 2010 | Abit AV8 Motherboard
AV8 Motherboad post code C5 freezes on boot.
Hi...
Try cleaning the contact point of the memory modules "with a pencil eraser" and insert them back... Clean also the Processor heat sink if dusty... Then check the voltage of the CMOS (3V) battery it maybe dead, if so you need to replace that with the same type.
Keep me posted if still does not work...
Happy fixya...
Feb 28, 2009 | Abit AV8 Motherboard
Computer wont turn on trys to but keeps restarting itself
83 - 96 - 9E (for a **** second)-9F
on the post code definition display on the mobo.
When it hits 9E it has shutdown and reads 9F when totally powered off.
I have read on other newsgroups that the power supply might be at fault
I took this from an overclocking forum, I hope it helps
Dec 20, 2008 | Abit AV8 Motherboard
Recieving error code FF and pc will not boot/recognise harddrive
the problem it is in harddisk
is that u have ur smp (power supply)
just check the power supply & insert the cable
properly in to the slot of motherboard & check whether the display has come if it comes than boot the xp cd if problem occurs go to nearest shop of computer
Dec 04, 2008 | Abit AV8 Motherboard
ABIT AV8 not reading SATA ASUS DVD Burner
you should contact your computer servicing centre.the problem might be of the drive.for getting more knowledge about the ASUZ mother board and SATA please make use of your users CD which is given with every ASUZ motherboard.easily understandable pictorial reprasentation of the whole mother board are given there.by that you can even find out the problem in *********** board if any. if you are convinced please rate me
Sep 22, 2008 | Abit AV8-3rd Eye Motherboard
Abit AV8 Motherboard Logo
1,616 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
