Question about Kenmore 24 in. 15689 Built-in Dishwasher
I have a Kenmore dishwasher and recently it seems to have stopped pumping the water, as in stopped spraying the water. It still sounds the same and runs through the cycles but it seems to only steam the dished as opposed to wash them. There is no leaking of any kind.
  • Kenmore Master
  • 528 Answers
Water not getting to the unit as they should be or your pump is clog with left over you will need to take the spray arm out and get to the pump and clean it.
watch for broken glass!!!
Posted on Jan 01, 2010
My mother-in-law called and her dishwasher is making a loud noise when the motor runs. sounds like a bad bearing somewhere? the noise stops when it drains (motor not running?). does that sound like the...
There is only one motor -- it runs a water pump for recirculating the water when it's washing and runs a water pump when it's draining.
It sounds like the spray arm is making the noise -- this is the part thru which the motor / pump forces the water during the wash cycle -- the pumped water causes the arm to rotate -- a warn or loose spray arm or mount is likely the problem.
Or, it could be just some utensil stuck in the bottom of the dishwasher which the spray arm is rubbing.
More info, let me know.
Charlie
Jul 16, 2011 | Kenmore Dishwashers
Kenmore 17379 dishes are not clean after running a cycle
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Jan 31, 2011 | Kenmore 24 in. 17372 / 17374 / 17379...
Pump doesnt seem powerfull enough to push water to top rack. i have cleened the filters and checked the pipe to the top rack and there are no obstructions. It is filling with water fine and empting with...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Oct 11, 2010 | Kenmore Dishwashers
The top rack is not cleaning. When I've run a test, it seems like the top "arm" is not turning or spraying water.
Check the spray arm opening/holes for clogging with debris. If clogged, remove the debris from the holes. Then position the spray arm in a certain position and operate the dishwasher for a minute and stop and check the position of the spray arm. If in the same position, then the arm may not be receiving water from the water pump and/or upper water inlet housing/tubing. Contact an appliance service company.
Feb 25, 2010 | Kenmore Dishwashers
My kenmore washing machine fills with water but will not wash..it sounds like its doing something then it stops after a while i hear it drain and then stops again..water doesnt spray..I let the dishwasher...
Often these work by reversing the motor which has two pump impellers. One direction will pump the water out and the other will pump it through the spray bar. IF the one pump impeller has broken then that would explain your symptoms.
If this is the type you have, verify that the motor is running reversed from when it is draining. If it is not running during wash time, then the timer is probably at fault. If it is running, check for broken pump impeller for the was direction.
Sep 29, 2009 | Kenmore 24 in. 16193 Stainless Steel...
My Kenmore 13593 dishwasher has stopped washing properly. It seems like the spray nozzles are not spinning. Almost as though there is not enough pressure or their is an internal leak. I have plenty of...
Look for plugged screens in the pump area... House water pressure has nothing to do with washing pressure as house water only fills, then the dw pump takes over...
Sep 20, 2009 | Kenmore 13593 Stainless Steel Built-in...
Kenmore dishwasher makes grinding noise while draining
disassemble the top of the dishwasher pump, remove the bottom spray arm and remove the screws on the top of the pump housing this will get you started
May 03, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Water Problem in Upper Wash
dishwasher arms are only swept round by the water spraying out of the jets some of which are at an angle. make sure jets are clean and if necessary take the spray arm boff to get debris out. usual culprits are sweet corn and rice
Mar 22, 2007 | Kenmore 24 in. 16534 Built-in Dishwasher
Spray arms
Sounds like the circulating pump is faulty or the spray arms hav become partially clogged. Loss of available water will stop the spray arm motion.
Feb 05, 2007 | Kenmore 16872 Built-in Dishwasher
Kenmore 24 in. 15689 Built-in Dishwasher Logo
204 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
