Question about RCA HD61LPW42 61" Rear Projection HDTV
DLP Screen replacement
I'm planing to replace the screen on my set. Are there any tip I should be aware of?
  • guitar head Dec 20, 2007
    I am planning to install it myself.
    Problem Solver:
  • 4 Answers
First off make sure that the screen is professionally installed, and second try not to play any console games on your new screen!!!! By playing games on DLP and Plasma screens the resolution from the game is so strong that after time the backdrop of a game will be permentally burned into you screen!!! So try as hard as you can to not play games on the screen.
Posted on Dec 20, 2007
  • st_townsend Nov 21, 2010
    I have been playing video games on my DLP TV daily for 5 years. I have never once had any image burned into the screen. Even after leaving my games paused for hours.
Can I diagonally adjust (clockwise/counterclockwise) my Mitsubishi DLP TV? The picture is off center
You need to align the optics mechanically. If you changed the dlp chip and its not centered then the chip is not shimmed properly or the reflection mirror behind the lens needs adjustment. You should get a service manual for that chassis and follow the directions. there may be an electronic method but I am not aware of one.
Sep 05, 2015 | Mitsubishi WD-60C9 60" DLP HDTV
I do I fix white dots on screen
Hi
Have you tuned the channel frequency tuner? Use the remote to bring up setup menu on TV, scan channel frequencies & save. If it's an old TV that can't pick up digital signals, then you need to get a digital set top box & tune to TV.
Jun 26, 2014 | Mitsubishi WD-65735 Television
I have white dots on my HL-6156 Samsung tv. Started with 4 and is now 10 wide spaced over 12 to 15 inches of screen. Anything I can do ? Set is 5years old.
The DLP chip needs replacement that what causes the white dots eventually they will fill the entire screen assembly. You can get the replacement DLP chip with instructions from www.tvrepairworld.com
Mar 21, 2013 | Televison & Video
When turned on there is nothing on the screen but sound works
jlk33d,
It sounds like you have a bad lamp and should replace it. Generally sets will not power on if the lamp is bad but if you have not replaced the lamp and the set is more than 3 years old it would not hurt to replace it anyway. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which will help with the replacement as well as where to get the parts at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Feb 19, 2011 | Toshiba 62HM95 62" DLP HDTV
White dots all over the screen
call samsung. there are aware of this issue with several of their dlp sets. To avoid a class action lawsuit, they've extended the warranty of several models to cover the very issue. give samsung a call and see if you model is covered. i just got my 46" repaired at no cost and without a warranty.
Apr 11, 2010 | Samsung HLS4676S Television
The more i use my samsung flat screen tv the more white spots come on the screen. What do you think is the problem?
The DLP chip needs to be replaced. Samsung is aware of this problem and will probably cover the cost of part and labor. call 1-800-samsung for nearest service center. I replaced the chip on a 3 year old machine yesterday and Samsung covered all costs.
Nov 25, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Have little white dot's on screen will changing
Highly unlikely the bulb could be at fault; it sounds a lot like a defective DLP chip. If you are not aware of how this device functions, it is an array of physical mirrors which can fail individually and cause the effect you are having. The bulb failing would cause a loss of the entire screen, not just a few points.
Jul 05, 2009 | Samsung DLP HL-P5663W 56" TV
56" screen dlp Samsung
You can find a new Samsung replacement Lenticular screen and fresnel screen for a model # HL-P5663W from a major Samsung distributor at the following links:
Samsung HL-P5663W Replacement Part Fresnel Screen
Samsung HL-P5663W Replacement Part Lenticular Screen
Feb 12, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HLS5086W - spider crack
You will need to get the screen from here:http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP67%2D00261A&search%5Fmodel=HLS5086W You should also get the service manual for this TV set, as that will show you how to disassemble the TV set. Good Luck
Jul 05, 2007 | Samsung HLP5685W 56" Rear Projection...
Samsung HLS5086W - spider crack on outer screen
The outer screen is called a Lenticular screen, it may come as a set with the Fresnel (the inner, and the way I would actually go) the screen is very hard to replace usually on a DLP as they have a somewhat sealed upper side and alot of screws.
RCA HD61LPW42 61" Rear Projection HDTV Logo
835 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
