Question about Mach Speed V881DAS Motherboard
UPGRADING RAM I need to be able to find the manufacturer of my motherboard. All the board says on it is V881DAS. How do I know if it is Mach or Jetway?
  • 557 Answers
Mach speed is made by jetway. Will accept pc2100/2700/ or 3200 DDR SDRAM with a maximum of 2gb (1gb x 2)
Posted on Sep 30, 2009
Testimonial: "Thank you for making your answer clear. Advising me that Jetway made Mach Speed was perfect!"
  • 468 Answers
It is
Norton tells me that my RAM is low...I should be upgrading my RAM...to cantact my pc manufacture..can i do this here?
yes you can i need to know how much ram yyou have and what windows you have also then i will give you the price of how much the ram will be and give you a link to where you can buy it and then instruct you on how to fit it if this helped be sure to vote i look forward to hearing how you got on please reply with the details
Jan 15, 2011 | Iwill Computers & Internet
MS-6378X-L 512 Ram not working. My motherboard will not recognize the double sided 512's i got. what could be the problem? it takes one sided 256 and double sided 128 not problem.
1. this may be due the manufacturer or your mounting of the RAM itself. It is hard to tell from what you have described.
2. Some RAM sticks may not be built for you PC and take particular brand or configuration which your manufacturer of the PC will point out in the installation manual that came with you PC or Motherboard ( if you built the PC yourself)
3. Sometimes there is a hardware conflict when upgrading new hardware in an older PC.
4. there is also the contacts in a PC that have not been cleaned properly that will result in an failed installation of a device.
5. Some Mother board manufacturers only 2 require sticks of ram as opposed to 1 stick in a particular motherboard for proper operation.
6. check your manufactures site for the proper ram sticks to upgrade your motherboard with.
Jan 23, 2010 | Biostar GEFORCE 6100-M9 Motherboard
Upgrading Ram
Try to find out that which tpe of ram fits in your motherboard "DDR 1" or "DDR 2".
Aug 16, 2009 | Computers & Internet
Upgrading ram
Well with this type of motherboard yes you can put 1gb into it however you can put up to 2gb on it and be just fine. Hope this helps you out.
Apr 11, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
I want to upgrade my procesor to faster procesor.
Upgrading processor is not likely a practical solution; find out the motherboard manufacturer and contact their site for more information. As to upgrading the motherboard, you'll have to know what kind/size of board your system will require. If you don't have lots of experience, this process is very risky.
Frankly, the cheapest way to upgrade your computer is to buy a used and working product with Windows XP already installed. Go to http://craigslist.com, select your city, and search for a brand name you trust. I've bought DOZENS of used computers very cheap that way (I'm writing this on a $2,200 Dell Latitude D620 I bought fiv months old for $500, who needed the cash!)
Mar 30, 2009 | Gateway Computers & Internet
Motherboard specs
Hi dwman113,
Yes your Mach Speed MB will support 2x1 GB, Dual Channel Mode DDR2-800MHz, PC6400 memory modules. (Manual states the memory dimms should be paired).
Also known as matched memory.
Max Shared Video Memory is 256MB, refers only to the integrated built in video card.
Click this link to help you understand what CL stands for; http://www.hardwaresecrets.com/article/26/3
Small example. CL3 runs faster than CL5.
You can run any PCI-Express 16x graphics card & it can be rev 2.0. Graphics cards are backwards compatible which means it will also run at v1.0. You should not buy a SLI card because you only have 1 PCI-E x16 slot. To run SLI, (Hooking up 2 PCI-E x16 cards together viva a small SLI connector) your motherboard would need two PCI-E x16 slots & the board must support SLI mode & your's does not. Here is the main web site link for your Mach Speed MSA2-6100V MB.
http://www.machspeed.com/specs/viper/MSA2-6100V.html
If you have any more issues or questions just post it & we'll go from there.
Good luck dwman113!
Mike
Aug 06, 2008 | Mach Speed Computers & Internet
Hi i have a ram issue
specs for motherboard mach speed venom
Memory type ddr2 sdram
Memory slots 2 X 240 pin slots
Supported ram 800mhz 533mhz 400mhz 667mhz
I dont know if this will assist you in sorting problem out
Aug 02, 2008 | Mach Speed VENOM MSA2-6100V Motherboard
RAM Support
Please post the model number of you're Gigabyte board. This is key in order to answer you're question. The model number can be found on the board, if not written in bold white lettering on the board it will be found on one of the PCI (white) slots.
Apr 16, 2008 | AMD Sempron 2500 CPU (Box) and Motherboard...
Upgrading
Hello densola,
Do you want to keep your current motherboard? If that is the case, then you'll need to...
Check w/ the motherboard manufacturer for documentation on that board. This will give you the maximum specs (RAM and CPU) that the motherboard will support.
As for changing the BIOS, that's a whole other matter. The BIOS is written to firmware that resides in an IC that is soldered onto the motherboard. You can, however, check w/ the manufacturer to see what their latest BIOS update is. In fact, you'll likely need the latest BIOS update in order to support the hardware changes.
Please, let us know if this response was helpful for you or, of course, if you have more questions, etc on this topic.
Thank you
BJ
Apr 04, 2008 | Intel Motherboard
Computers & Internet Logo
78 people viewed this question
Top Mach Speed Computers & Internet Experts
David
David
Iqbal Husain
Iqbal Husain
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
