Question about Garden
Murray model 42590x92A won't go. Replaced motion drive belt, adjusted clutch. It will take off, then slows down and eventually stops, just sits there and shakes. I chained it down in my shop, put a weight in the seat so I could try to find the problem, but it spins the tires, no problem. Any ideas?
  • 472 Answers
Ya did you ck to see if the key way is good on the tires
Posted on Oct 01, 2009
A drawn illustration of the drive belt on a Murray riding mower?
9f4f0355-fbcc-4309-9d49-c38336c29ea2.gifThis is foe the motion drive on a hydro drive model.
4320ae69-ba36-46cf-8311-f57658515ac0.gifAnd this if the diagram for the deck belt on the same model. Hope it helps
Aug 12, 2014 | Murray Garden
Need a diagram of how to put a belt on for a Murray riding lawna mower Model # 42590X92A?
Hello Loretta,
Try these pics. Hope this helps. Good luck and happy wrenching!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 25, 2013 | Murray Garden
LA105 mower won't move when put into gear
Is this happening in all gears or just one? Is the motor bogging at all. If not chances are the problem is in the drive belt to the transmission or in the transmission itself. Check to make sure you are getting it into gear. you should be able to feel the transmission hit a notch for each gear. If you can't, chances are the little module in the top of the trans that sets the gears has broken and needs to be replaced. Often these get sticky before going bad. If the motor is running normally though, it's not the engine, it's drive belt or transmission. with the mower off, you can check the drive belt tension by simply having the clutch pedal in the out (drive) position. In that position the drive belt should be tight enough that you really can't slide it in either direction without causing motion on the motor pulley. If it has slack in it, then your clutch is probably out of adjustment or your drive belt has stretched beyond it's working life. Have you smelled burning rubber at all.. if so the belt is probably slipping. If not, it's more likely that it's in the transmission.
Nov 02, 2012 | Garden
42561x8 drive belt falls off
check the spring on the tenson arm
Jul 20, 2012 | Murray Garden
My murray riding mower wont go in to gear ???
If you can select gears when the motors not running but not when it is then your drive belt is dragging.(trying to drive even when the clutch down).This is usually the belt guides not holding the belt in a neat loop off the pulleys front and back when the clutch is down.
Jan 31, 2012 | Murray Garden
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 | Garden
Clutch vibration and jerking at slow speeds.
Check the drive belt. It probably has chunks missing or at least has flat spots (narrow spots) that cause the belt to jump every time it goes around a pulley. That will set up a heck of a vibration. Also check the pulleys for free movement. The drive belt is above the blade drive belt....
Jul 27, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
274 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
