Question about Xerox WorkCentre XE80 Laser Printer
Cannot clear "E2" error on XE80 - Xerox WorkCentre XE80 Laser Printer
2 Suggested Answers
  • 990 Answers
SOURCE: xe80 copies coming out almost black on auto or light
Hello sir; Just replace drum cartridge it will take care your problem, GOOD LUCK!
Posted on Jan 07, 2009
E9 E2 ERROR
Message = E2
Error = OVERFLOW ERROR
Cause & Solution =
The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
The valve inlet is normal, but the water level sensor Change the water level sensor
(sensor pressure) is low. (sensor pressure).
The drain motor does not work - Test and if faulty change the drain pump
Message = E9
Error = SENSOR PRESSURE ERROR
Cause & Solution = The water level sensor is faulty. Change the water level sensor. (remove pressure tube and blow through it to make sure it is clear first)
Mar 10, 2012 | Daewoo Washing Machines
How to change the door switch
Hello.
Some Washer ranges are equipped with electronic displays that indicate the time of day and the oven's temperature when it's in use. The display also alerts users to error codes including PF, or power failure, and various letter and number combinations that correspond to issues ranging from electronic control malfunctions to problems with the oven door latch.
Related Searches:
F2 Faults
Washer F2 faults relate to temperature problems in the oven. In the case of the error E2-F3, F2 is the general fault code and E2 is the specific error code. An E0-F2 error indicates that the oven's temperature sensor is open; E1-F2, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E2-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in "Clean" mode.
Clear Error Code
If your oven display shows a letter/number combination, washer advises clearing the display. Press "UPPER OFF" or "LOWER OFF" on double oven models. On single oven models, press "OFF/CANCEL" to clear the display. If the code reappears, the manufacturer recommends contacting a professional service technician or contacting the Washer producer
Professional Service
The Tech Sheet included with Whirlpool ovens is meant for use by professional technicians servicing the unit. To address an E2 F3 error, a technician can check the oven's temperature sensor connection, measure the sensor's resistance and, if necessary, replace the sensor.
Thanks.
Dec 07, 2011 | Washing Machines
Error code E2
Error Code E2 means the pump is blocked. The remedy is to take the filter out which is underneath the bottom dish basket and ensure its is clean and free from debris. Then use a small container to empty the water sitting in the bottom of the machine/filter housing and ensure that no waste is stuck in the bottom. That should clear it
May 24, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
Xe80 copies coming out almost black on auto or light
Oct 30, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
I HAVE ERROR CODE H4
Give this a try, should resolve your code.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Aug 05, 2008 | Xerox WorkCentre XE80 Laser Printer
XEROX WORKCENTRE XE80 DISPLAYS AN H3 CODE
Try this procedure.
Jul 17, 2008 | Xerox Office Equipment & Supplies
E2 Paper Jam code flashing .... but no paper jam!
There is a small sensor on the fuser that most likely has become disloged. It requires a lot of disassembly to get to.
But an E2 code is that sensor not being cleared off. It pops out of the frame sometimes during paper removal.
Apr 14, 2008 | Xerox WorkCentre XE80 Laser Printer
Xerox WorkCentre XE80 Laser Printer Logo
29 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
