Question about Kichler PLUG-IN ACCESSORIES - DIGITAL TIMER - 15558-WH - White
Programmed to turn on landscape lights at 6pm every day. Lights are not turning on. Tried reprogramming but still no luck.
  • 15,935 Answers
Reset the timer and re-program your times.
CLICK HERE for the manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Apr 10, 2010
We have had it for 2 years and it just stopped turning on. I have tried reprogramming battery good what else can I do?
Pull the dial toward you.
Line up the correct time of day to the arrow.
This may help in the event that the power went out at some point.
When that happens,
it changes the time when your lights turn on & off.
Apr 15, 2015 | Orbit Underground 57896 6 Station In/Out...
Verve Digital Water Timer as sold at B&Q have lost the operating instructions.
Verve water timers might be Melnor:
Open following link for manuals.
http://www.melnor.com/instructions.php
Links to other water timer manufactures and manuals are found on following link:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
Jun 14, 2011 | GARDENA Water Timer
Cant figure out which outlet is which number on Zilla timer. Turned on the yellow switches and then they turned back on at the time I have set for outlet 7. I thought the yellow ones were 1 and 2 or 1 and...
Open following link for Zilla timers
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Zilla timers are unique for home-type timers.
They are two-channel timers, which means that timer has 2 independent programs.
In the case of Zilla, 1 program controls yellow outlets for daytime hours (6am to 6pm). Once daytime hours are over, the yellow outlets are OFF.
The other program controls blue outlets for nighttime hours (6pm to 6am). Once nighttime hours are over, the blue outlets are OFF.
So if you have a light for example, and light is plugged into yellow outlet, then you can program light to turn on-off during the daytime hours only. You cannot also set a nighttime program for the same light unless you plug light into blue outlet.
Zilla timers are for aquariums, where day and night plays important role in life cycle and activity of different types of aquatic beings.
Add a comment and say exactly which Zilla timer you have, and say what specifically you have done so far, and where you are stuck, and what loads you want to control.
May 02, 2011 | Coralife Zilla Aqualight Power Center
Dishwasher want let me select a program,but is still beeping.led lights on program selection not lighting up.
didn't get the brand or the model # of your dishwasher. so you need to disconect the power for about 20 min . ( turn it of at the fuse box then turn power back on and try to reprogram dw ) if it will not set and go like it should the replace the control as it has failed ,, hope this helps mm and thanks for useing fix-ya .. mm
Oct 18, 2010 | Dishwashers
I set timer back from 9pm to 6pm to turn on. no lights activated the last two nights. Is there an on and off button hidden somewhere? ------Jim thanks
1) Use manual override to see if ST01C timer is functioning:
Push door that covers buttons -or- open door and push ON/OFF button ... timer should make audible clicking sound >> and lights will turn On and Off.
Look on LED screen ... left side of screen is small light-bulb icon ... when lights are ON, icon is black ... when Off, icon is outline
2) Review troubleshooting steps in Manual
a) You might be in Random MODE ... Press MODE button until AUTO appears (AUTO mode lets programs to run)
b) Battery can be too low to operate timer, even if BATT warning does not show on screen >> Change SR2 battery and re-set Time-Date (Time-Date disappears if battery is dead, but programming remains in timer forever until timer is reset)
c) Timer will skip conflicting programming ... For example ST01C has 40 programs ... if Program1 says ON at 7 and Off at 8 ... and Program2 says opposite .. timer will skip these programs
d) Timer will not work on circuit where load (lights, fan. motor) is farther than 100' from timer
e) Timer might not work with underground wiring
f) Circuit breaker clicked off > reset breaker
g) Timer may be carrying too much load: 960 Watts flourscent; 1440 Watts incandescent
h) Timer has 1 year limited warranty > things wear out
i) Circuit has loose wire >> check your connections > review wiring diagrams
j) Timer connected to three-way switch, and other switch has malfunctioned
k) Last resort: Reset timer and reprogram
Oct 01, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Programming the Malibu landscape sensor pack. Model # : 8100-9100
it is an adjustable photosensor system. you will need to play with it to fine tune the settings, but you also need to keep in mind that photo sensor react to everything around them, shade can cause it to think the sun is going down, a cloudy day will cause it to stay on, or to come on. if you are looking for away to set it, to only come on when the sun is going to go down, and to turn off when the sun starts to rise, it might actually be easier for you, to get a time programmed timer for you lighting.
Jan 20, 2010 | Solar Industrial Timer Switch Outdoor Sign...
Pool lights go on randomly--not programmed to go on at all
make sure the light is pluged in a port that is for like a spare aux. any time you add programs you must hit the store button.
Oct 05, 2009 | Jandy AQUALINK RS TELELINK KIT
1996 318 i se battery went flat, replaced it now it wont start, got ignition lights but wont turn over
This is not a sloution but i had a similar problem about 6months ago. I left the lights on which drained the battery, road assistant came to booost start it, there was power but no turn over, not even a clunk of the engine trying ( all electrics are working and lights in the dash are live), tried a new battery same situation,
I took it to BMW independant specialist who put it down to a ECU fault , i was duped into having a new key made as i had no spare as it was believed the immobilizer had locked the car up so to speak, this didnt work , so the mech ordered a new ecu, and had it reprogrammed and it turned over first time, It was bumpy idling at cold start cos i had my original dead battery but after a day it ran like it used to sweet as a nut.
it was expensive 500 quid to put right, but then you may have better luck with your mechanic.
Jun 07, 2009 | 1996 BMW 318
COOL START REMOTE NEEDS REPROGRAMMING
from http://www.crimestopper.com/techweb/InstructionBooks/RemoteStart/rs1300dp_1304dp_a_ops.pdf Note: All transmitter codes must be learned at time of programming!! The unit will learns up to 4 different transmitter codes. 1. Open Hood (If no hood pin installed with your system, then you must ground the Gray Hood pin wire). 2. Turn key to the ON position. (Pink wire must be connected.) 3. Press Programming button 4 times, then after a few seconds the unit flashes the parking lights 4 times. 4. Press button #1 of the transmitter to be coded. You should get 2 light flashes indicating the unit is waiting for a 2nd code, then press button #1 of a second transmitter, the unit will flash 3 times indicating its waiting for the 3rd code and so on. If all 4 codes are learned, the unit will automatically exit code learning mode, otherwise turn key off and close hood. See diagram below.
Dec 16, 2008 | 2-Way Remote Starter
Kichler PLUG-IN ACCESSORIES - DIGITAL TIMER - 15558-WH - White Logo
485 people viewed this question
Top Kichler Hardware & Accessories Experts
Scott Jelt
Scott Jelt
Gene Haynes
Tom Chichester
Are you a Kichler Hardware and Accessory Expert? Answer questions, earn points and help others
