Question about LaCie Big Disk Extreme (300797U) 1000 GB Hard Drive
Cannot detect the lacie 1tb exreme big disk - LaCie Big Disk Extreme (300797U) 1000 GB Hard Drive
  • ynotphone
    ynotphone May 11, 2010
    -> computer type (pc or mac)?
    -> what os are you running (xp/vista)?
    -> did it work before?
    -> is there power to the hard drive?
    -> if you tried plugging the hard drive into another computer does that computer see it?
    -> is there a pop up when the hard drive is inserted?
    The more information you can provide the easier it is for someone to help you... yelling my hard drive wont work will not help tell us wha tyou are doing!
Hi there!
Same issue here
Running win XP on my laptop and I have my LaCie NAS on my network and was working fine 'til today.
Issue: unable to access my LaCie NAS
troubleshooting done:1- rebooting NAS 2-power cycling the whole network 3- also tried accessing NAS from a Mac Book (used to be able) 4- nable to ping it by name or by IP
I had one my NAS's shares mapped to Y:, Now I can see the share from my network places but when I go to map network drive the Y: is no more assigned to that share.
My next move would be to re-install the NAS but I want to know and make sure that this will not delete what I have on that NAS.
Thanks to anyone that would jump in and give a hand to a desperate novice in Networking
Posted on Oct 18, 2009
LaCie 1Tb SSD
Part of your Loading Door came loose when you loaded a disc.
Mar 03, 2014 | LaCie 1TB Little Big Disk Thunderbolt SATA...
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Help is it possibol to upgrade lacie big disk extreme 500gb to 1tb or 2tb. thanks. FC
Maybe. If the current disk-drive has an IDE interface, then your 500GB disk-drive already is the largest IDE disk-drive ever produced. Or, if the current disk-drive has a SATA interface, then the sky (or the thickness of your wallet) is the limit.
Nov 15, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
, hard disk problem
Hi, blinking light may indicate activity to or from hard disk and computer, maybe the disk partition was damaged or lost due to incorrect ejection or a virus, you could use a free partition recovery software to try to fix it, for example EaseUs.
Dec 23, 2017 | LaCie Big Disk External USB 2.0 1TB Hard...
My lacie hard disk 1tb all of a sudden isnt
Just contact www.lacie.com great support. their answer for my drive was to reboot the drive. For me it worked.
Follow the procedure below to reset the Network Space to factory defaults:
  1. Move the power switch to the OFF position. Wait for the drive to shut down.
  2. Turn ON the drive.
  3. Within about 3 seconds, flip the switch OFF and On several times.
  4. Immediately turn it ON
If the light flashes quickly, the unit is resetting itself. Attempt to connect to the drive again after about 1 minute using the default username and password (by default, they are both admin.)
Jan 27, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I need a new AC Power Supply for my 2T LaCie external hard drive.
Call LaCie. Your drive may be eligible for extended warranty support where your power supplies may be replaced FOR FREE.
Jul 07, 2009 | LaCie 301294U 1TB Big Disk Extreme + with...
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
LaCie Big Disk
Fixya is unable to suggest parts sources.
Dec 17, 2017 | LaCie 301294U 1TB Big Disk Extreme + with...
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
LaCie Big Disk Extreme (300797U) 1000 GB Hard Drive Logo
693 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
