Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
Bosch Nexxt Washer (model wfmc2201UC)/need to replace door gasket
Ihave a Bosch Nexxt Washer (model wfmc2201UC) that has a damaged door gasket. I do not know what it takes to completely replace the gasket (internal retainer access or special tools etc.?). Where can I get instructions?
Thank you, Robin
Coldcut
  • 1554 Answers
SOURCE: bOSCH WASHING MACHINE RETAINING SPRING FOR FRONT DOOR GASKET
it is very hard to get the ring on front load washers,
it is much easier to remove the top. bottom and the front control panel
then the door and support panel.
now you have access.
some times you have to remove the counter weight in some models before putting on the ring.
if you can do it without removing these items you are very very good.
Posted on Jun 04, 2008
textonor
  • 130 Answers
SOURCE: how do I replace my
Here is how you do it. 1st remove the door & hinge, 2nd remove the covers on the screw where the door sits that holds down the control panel. 3rd remove two screws holding the door latch in place. Remove the spring & wire holding the boot on and pull the boot loose from the plastic holder Remove the plastic boot holder. You will now see the boot where it attaches to the tub. There is a spring and wire that holds that on. At the top there is a tab on the seal, grab it and pull towards you. The boot will come off. To reassemble I remove the counter weights(concrete weights) from the tub and put the boot firmly into the slot on the tub. Now reinstall the rear spring. Be sure to also reinstall the counter weights if removed and torque them tight around 25 to 30 foot pounds. Reassemble the front panel and put the spring retainer back on. Tools needed T20 torx driver, 13mm wrench, and needle nose plyers.
Posted on Aug 10, 2008
  • 130 Answers
SOURCE: Lots of mold and mildew stains on front door seal.
Easy, try running a cup of white vinegar thru the wash cycle. I sell and fix these and it usually work everytime. good luck
Posted on Jan 24, 2009
blueextc3221
  • 15935 Answers
SOURCE: Our Bosch Nexxt washer uses very hot water on all
there is a mixing valve that uses a solenoid to open and close (and mix) the hot/cold inlet water based on your selection.
If you verify the correct model # I can point you in the right direction for a new valve if you are so inclined.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 14, 2009
I mounted the ring by myself. Here's how:
1. Get a small piece of 2x4 that's longer than the spring will be when it's expanded. You basically have to stretch it less than an inch.
2. Nail two 4d nails to the piece of 2x4 close to the long edge. Again, about an inch or so wider than the compressed spring. Nail them so only about 1/4 of an inch is exposed.
3. File the head of the nails so they are relatively smooth to allow the ring to slide off easily.
Note: Wear eye protection just in case the spring snaps.
4. Hook one end of the ring (not the spring) to one of the nails and use a pliers to stretch the spring to hook the other end of the ring to the other nail.
5. Set the ring into the gasket groove making sure the spring is in the 6:00 position.
6. Hold the spring in place with one hand and gently push it off on of the nails. The other nail should come out easily.
This may take a couple of tries.
Posted on Feb 09, 2010
Replacing a gasket on a bosch nexxt washer
For parts look in Fixya. For changing go to YouTube, great videos to show you how.
Click helped, if helped.
Mar 14, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Door gasket has mildewed and need to remove it for cleaning.
This video will show you how to change a door seal on this Bosch front loader washing machine
May 14, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Leaking
This video will show you how to replace the Bosch Next 300 Series WFMC2201UC washing machine door seal with step by step guide on the process of how to fit and replace
Apr 17, 2010 | Bosch Nexxt 300 Series WFMC2201UC
How do i replace the door gasket
you go up inside and release the clipps holding it on,then replace the new one
Nov 02, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Our Bosch Nexxt 300 washer has a small piece missing from the door seal gasket - I'm a skilled home remodeling contractor - Should I attempt this repair - Are instructions an diagrams available - Who...
Bosch Nexxt 300 washing machine
door seal on this Bosch front loader washing machine and where to get the parts!
we have all bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 08, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
203 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
