Question about RCA Televison & Video
RCA Colortrac won't change channels.
I have a RCA Colortrac Model G26261TN, made July 1998. It was recently given to me. It will play a DVD fine most of the time. Sometimes it won't go to channel 91 so I can play a DVD. I have a amplified antenna instead of cable (my old TV got 4 channels in good). When I go to put it on a channel, sometimes it will come in and other times it won't. Other times it will come in for a time and then go totally off air. I get nothing. I know it has good picture and sound because it plays the DVD's. I don't have the original remote. What do you suggest? I'd appreciate any advice you can give me. Thanks. Lisa
tvtek
  • 1284 Answers
SOURCE: Cannot get DVD to Play on TV
Try the old RCA/GE channels of 90/91 or 92 to get to the inputs. Or try entering channel 00. Let me know if that works.
Posted on Feb 23, 2007
  • 192 Answers
SOURCE: TV was Fine last night, this morning there is picture, but no sound
Since the you were vacuuming behind the set before this happened, I'm going to assume that you unplugged an input. Check the wiring, not just on the back of the set, but, on the back of the peripherals (DVD, Satelite, cable box, etc.) If wires are connected, then, take a component, such as a VCR or cable box and hook it up to the RF connector (AKA the cable connector) and run it on channel 3 or 4. If you have sound, then, you have a configuration problem and need to rewire your set. Hope this helps.
Posted on Mar 18, 2007
  • 1153 Answers
SOURCE: can't get TV onto the AUX channel
Do in your menu have like VCR or DVD in the option area? If so then put on vcr or dvd. Also you can look for the channel in the add or erase area and move past the channel 2 by going the other way and see if the aux or video1 comes on then simply chose it.
Posted on Sep 09, 2007
swampduck651
  • 5 Answers
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
swampy
Posted on Feb 05, 2008
SOURCE: Channel keeps changing to 'Input 2' even when playing DVD
Have you taken the remote control out of the room? Try changing inputs from the TV.
Posted on Dec 21, 2008
Can't change channel 3 to video for dvd playing - video won't come on to use with dvd player
I SUGGEST YOU USE AV CABLES( RCA ) AN CONNECT TO THE AV INPUT OF THE TV
Jun 20, 2013 | Panasonic CT-36D32 36" TV
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
I purchased a RCA DRC-8335 DVD/VCR RECORDER COMBO
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
Can't find dvd channel on my tv...
hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
shaun
Mar 06, 2017 | Zenith SY2569X TV
Hi, I have a RCA 27" console color tv without the original remote. It has the RCA cable ports. I bought a Toshiba DVD and it needs the TV to have an external channel which can only be set by remote? Is...
After market remotes only work the most basic of functions - ie., volume channel changes , on/off. They do not get into menus, change inputs, etc. If you can change channels on the console tune it to 3 or 4 and get an rf adapter for your dvd player outputs, set it to one of those channels, and connect to tv antenna input. Ir will work but the picture will not be as good as it can be.
Mar 03, 2017 | RCA G27647 27" TV
DVD Player does not work
General Problems
Player won’t work (locks up)
• Try unplugging the AC power cord and plugging it back in.
• Reset the DVD/VCR: on the front of the unit, press and hold the STANDBY/ON button while you press and hold the STOP button—wait at least 3 seconds
before you release both of the buttons. You’ll need to set up your menu preferences because this Reset Procedure returns the DVD/VCR’s menus to the
factory default settings and also erases the contents of the Disc Library.
Mar 15, 2008 | Televison & Video
RCA Colortrac 2000--can't hook up video game machine.
Be sure the hookups are in the input #1 row. Then tune to channel 91. Dont know if all tvs have to be on channel 91 but its the only one that works on mine when I hook up my xbox 360.
Dec 27, 2007 | Televison & Video
Can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Sep 09, 2007 | RCA F25254GY 25" TV
Televison & Video Logo
59 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
