Question about Maytag Neptune MDE5500AY Electric Dryer
No Heat have 120 to element on both sides...but not 240 between them. Drum turns, just no heat....element ohms out fine....
  • Darin Robin Morvant Sep 30, 2009
    that was the first thing I checked when I noticed I wasn't getting 240 at the element. I am in fact getting 240 from my power source.
    Brigadier General:
  • 4,088 Answers
Check for 240 volts across the two slanted slots at the dryer socket. If you read near zero, try resetting the dryer breakers in the house electrical panel--push off, then push on. If still zero at the socket, either one of the breakers is bad (replace the pair) or a wire is loose on one end or the other. Hope this helps.
Posted on Sep 30, 2009
  • drallim Sep 30, 2009
    Check for an open thermostat or safety over-temp switch in series with and near to the heater. There should be a heavy relay or heavy switch in the timer that turns on power to the element.
I have kitchenaid dryer, #KEYS677EQ0, no heat. Have replaced heat element, & checked all the thermostats. I have power on the thermostat side of the element, but none on the motor side. Motor or timer
1) Have you checked to makes sure all of the connections for the heating element are correct and plugged in?
2) Have you checked to make sure any and all fuses (if any) are good?
3) Have you cleaned the interior of the dryer?
4) Have you opened the dryer up and turned it on to check to see if the heating coil is heating or not?
If you haven't done these go back and do so.
Jun 07, 2015 | KitchenAid Dryers
Will not dry no heat ge model dde9500ramad
Well it is not the fuse because it still runs just no heat. I would first try to reset the breaker and make sure 240 volts is getting to the dryer. Dryer motors work on 120 volts. The heater needs 240 to opperate. Sometimes the breaker will trip on the high load heat side or simply wear out. If that is good then you must check the element, To do so you need to remove the drum. You start by raising the top then getting the front off; then you take the belt idler loose and yank out the drum. The heater element is on the back wall of the dryer.
My video:
Feb 01, 2013 | GE Dryers
My dryer is running, but doesn't have heat.
All electric dryers use 220-240 volts of electricity to run. The elements that make the heat are what actually need the 220 volts, the motor that turns the drum only uses 110. If you have a fused service disconnect box, replace both fuses, as one side is gone. 220/240 is made up of two 110/120 lines coming in, if one fuse, one side, blows, then all that's left is the 110/120 needed to run the drum motor, but no 220/240 to run the heat element. If there is no service disconnect then check the breaker than runs the dryer, flip it off and then back on to see if that makes any difference. Sometimes it will. Then there's the possibility that the hi-limit thermostat on the heat chamber in the machine blew, letting the drum run, but not feeding the coils. If you're not real handy with tools you may want to call a repair tech for this one.
Apr 22, 2011 | GE Profile Harmony DPGT750EC Electric...
My dryer was working fine but now there is no heat?
Check to make sure that your 240 volt breaker to the dryer hasnt tripped. the dryer drum only needs 120 volts to tumble, but the heating element needs 240 volts to heat up. Or the element itself has quit, or the tstat controlling the element has burned out
Apr 27, 2010 | Dryers
Dryer spins but no heat
You have one of three problems going on here. I will list them in order of most common to least common.
- Not enough power. Your dryer uses 240 volts to heat and only 120 volts to run the drum. Check your circuit breaker to make sure it did not partially trip by turning it off completely and then back on
- Heating element has failed. The element can be checked with an ohm meter and should read under 100 ohms. It is not too hard to replace, with the power off take the back panel off the dryer, the element is in the right lower corner looking at the back, held in by 2 screws.
- Thermal cut off, just above the element on the heater box is a small component with 2 wires going to it. this fuse is activated by over heating due to poor air flow, if your venting is kinked or full of lint this part will fail, it can be checked with an ohm meter also
Apr 24, 2010 | Whirlpool LER4634J Electric Dryer
Dryer won't heat
The first thing to check would be the power, I know that sounds silly since the drum turns but your electric dryer uses 240 volts to heat and only 120 to run the drum. Check the circuit breaker or fuse by turning it off completely then back on.
If that does not fix the problem you have one of two components that have failed. Either the thermal cutoff or the heating element. The cut off is a small two wire heat sensing switch located just above the heat element. They are both accessible from the back
Apr 23, 2010 | Whirlpool LER5636P Electric Dryer
No heat from element
check your power supply there should be two 120 volt lines that will make 240
on your power cord wich is flat you measure from line 1(black) to neutral 2 (white) =120 and 2(white) to 3(red)=120
and from 1(black) to 3(red) =240 volts ac
if you don't have this readings correct-
check your breaker
it is a double breakerthat cuts both power lines, but sometimes only one side trips
Mar 09, 2010 | Dryers
My whirlpool duet front load dryer is not heating up. The drum moves but there is no heat. how do I fix this?
Check your breaker. The dryer will spin at 120 volts but will not heat without the full 240 volts. If that's not your problem there are some fuses behind the bottom front panel that need to be checked, along with the heating element. You'll need an ohm meter for this. If its not your breaker, its best to hire someone. Good luck...
Nov 16, 2009 | Dryers
Whirlpool dryer won't heat
Okay...first of all, what led you to this point where you are troubleshooting the heating circuit? Does the drum still turn? The first thing to do before assuming you have a bad component if check the power at the receptacle. You should read 220-240 VAC. If you are missing one leg of your 220 service, you will get similiar symptoms as the dryer heating circuits require 220 service, while the motor that turns the drum only uses 110-120 VAC. The result: A dryer that the drum spins, but won't heat. This has caused many people to believe they had a bad appliance, only to find out that the problem was the electrical supply.
The heating element should read between 9 and 13 ohms. Make sure you aren't measuring anything to ground or you will get improper readings. Also, make sure you are actually measuring on a resistance scale and not using a continuity check. Disconnect the wires from the terminals of the heating element before measuring. Measure at the terminals of the element. If you still get 0 ohms, you may have an element that is grounded to the chassis. If this is the case, I would recommend replacing.
Some dryers also have a heat relay. The manufacturer places a wiring diagram inside the operator console. Sometimes the heat relay will go bad and will not energize the heating circuits. This can also cause a no heat problem. The realy (if equipped) will be located inside the operator console, and is a simple item to replace.
I hope you find some of this helpful. Let me know what your dryer symptoms are.
Sep 12, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
61 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
