Question about D-Link DI 514 Wireless Router (DI-514)
Can this router get a connection without being plug directly to a modem my wireless card can see the connection but they ask me for a password
  • 404 Answers
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Oct 02, 2009
UNABLE TO ACCESS OLD PASSWORD FOR D-LINK WIRELESS MODEM
Just reset your modem... unplug and press and hold the button the plug it while you're still holding it for couple of sec then release holding it. make sure you plug it to your computer it may show some msg on your screen etc. and just follow it if there is..
Oct 11, 2012 | D-Link DSL-G604T Wireless Router
Tip
How to set up wireless home network with a DSL subscription.
If you have a DSL, "Digital Suscriber Line", most companies will provide you with a modem. Usually the modem will have only one ethernet connection, meaning you can only connect one computer.
In order to connect multipule computers you will need a wireless router, ethernet HUB, or router.
Connecting with wireless Router
The only thing you really need to change is the following 3 settings on the Wireless Router. The SSID (so you know what wireless network is yours), the WPA/PSK and or WPA2/PSK, encryption method TKIP key or password. Under "administration" change the administrator password for a secure wireless connection. ( WRITE DOWN YOUR PASSWORD)
Connect to your wireless router
1. Plug in either your (1) wireless card, (2) PCMCIA wireless card, or (3) USB wireless stick.
2. Turn on your laptop or desktop computer. Select the wireless router with the strongest signal and with the name of your routers (SSID) and click connect.
3. Open your web browser and type 192.168.1.1
If this dosn't work, check your wireless router instruction manual for the correct IP address for your model.
4. Your router will ask for a password, usually (admin, admin) works or (admin, (ENTER) ) try both. If neither work try resetting the router by holding in the reset button for 3 seconds.
Once you log on to your router you can set parameters to your liking or just set the , {SSID}, {WPA/TKP} key or password, and the router administrator password to keep others from accessing your network and possibly computer.
Ethernet
Start at step 3 above.
More questions?
on Feb 05, 2010 | Computers & Internet
How do I discover or reset the password
Your modem if it is a Speedstream 5200 does not have any wireless capability and as such, there is no need for a password. You can only use one computer connected with an ethernet cable to your computer. What you can do is purchase a wireless router, preferably a N series wireless router because it is stronger than a normal G series router. Normally your modem connects to your computer via the ethernet cable. With a wireless router, instead of plugging the modem to your computer you should plug it in router. From the router you can connect another ethernet cable and plug it in on your desktop. You can connect at least 4 wired computer to your router. For the wireless part, all they have to do is look for the strongest wireless signal then hit connect. If it ask for a password then it should be in the sticker at the side of the wireless router.
Dec 14, 2011 | Efficient Networks SpeedStream 5200 Modem
I set up a home wi-fi network and have changed lap tops. I don't remember my password. How do I set up a new password. Linksys WRT160N V3
There are several things you can do, both of which require you to plug your laptop into the router directly via Ethernet cable. These instructions are for a majority of Linksys Wireless Routers, but may work on others.
  1. Assuming you have not changed the internal IP address of the router, plug the ethernet cable from the port on your computer to the LAN port on your router (most notably the ones labeled 1-4).
  2. Once you are connected, open a web browser and type in http://192.168.1.1 and press enter.
  3. If your IP address is still default it will ask you for your user name and password. The default is username: admin and password: admin. If the password doesn't work use password as the password.
  4. Once you get "inside" your router go to wireless tab and then to wireless security. There you should see the wireless password in plain text. Copy this down and disconnect from the router.
  5. If you had to disconnect your modem from your router, connect the modem back to the WAN port (not the 1-4) on the back of the router.
  6. Turn on your wi-fi on your laptop and search for your SSID (network name).
  7. Click on the network name and it will prompt you for a password. Use the password that you have written down in the previous steps and you should connect.
If you cannot connect and you are sure you have written down the password and entered it correctly, do a reboot of the modem and router in this order.
  1. Unplug router then unplug modem
  2. Wait 30 seconds
  3. Plug MODEM back in only and wait for all lights to become solid (except the Activity light).
  4. Plug the router back in and wait for all lights to light
  5. Try to connect again.
Good Luck!
Chris
Sep 28, 2010 | Linksys WRT160N Wireless Router
I have a wireless-n 150 router. I have tried to use it with a Toshiba Windows Vista computer and I cannot get the wireless to work. I have unplugged it and plugged it back in and that doesn't do it. The...
The wireless router needs to configured with the wireless settings, SSID, encryption etc. Then the wireless card in the Toshiba needs to be configured with the wireless router's SSID, encryption etc.
To secure your wireless router from unauthorized access and to configure the wireless card in your computer so it can connect to your wireless router, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jun 11, 2010 | Office Equipment & Supplies
Wbr-2310 dlink router wired connection issue
connect your computer to the router by an ethernet cable. Open Internet explorer or FIREFOX. Type the roiuter's default IP-address (if not known: its either 192.168.0.1 or 192.168.1.1 or 192.168.0.0 or 192.168.1.0... keep trying until you're answered and asked for the password to enter the router (either attached on the router, in the manual or try: user: admin password: admin or password: password. Whgen you're in you'll find many checkboxes you could fill oput or notr; Easyway: give your net a name (SSID), then choose the network access security (set it to wpa-psk), choose a password and enable DHCP (then the router does the rest). Disconnect, look if the computer sjhows reception of your netwoirk by displaying its name. then connect. You will be asked for the password you chose. Done.
Jun 04, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
How to change the password of stc wireless modem
i just want to change my wireless PASSWORD. Please simply help me how to change my current password in clear steps.
May 22, 2010 | Zyxel U 336S Modem
Internet not working through wireless linksys router but working when directly connected to modem
I think the problem will rely depending on the settings on your router, Follow these step by step solution on resolving the problem.
1. Connect the cable coming from your modem going through the internet/WAN port of your wireless broadband router.
2. I suggest you test your internet connection first by connecting an ethernet cable from your Wireless Router LAN port going to your PC NIC(Network Interface Card).
3. In order for you to setup your router, you should be using a web browser. Go through your router configuration by typing 192.168.0.1 / 192.168.1.1, on your web browser. The ip address depends on the manual of the router which default ip address is assigned to your router.
Illustration:
after enter the ip address, pressEnter and you should see a login box where you can type the username and password of the router.
You should check from your manual what is the default username assigned when you purchase the router. Since some routers have been using standard username and passwords.
You should use "admin" as your username and leave the password blank, press Enter / OK.
If you have a successful login, you should see a router configuration webpage where you can setup your router.
Look for the Internet Setup panel, select what type of connection you are using,
DHCP - for cable modems
PPPoe - for most DSL modems
if you are unsure, just check with your ISP.
Set the SSID to identify your router and assign a WEP (Wireless Encryption Key) under your Wireless Security section to encrypt your routers network to prevent others from connecting to your internet without any permission.
Feb 03, 2010 | Linksys Wireless-G Broadband Router
DLink wireless router will not connect to internet we have a new modem, tried connecting through a cable, and wireless, tried new cables, rebooting, resetting and all standard procedures. Is there...
It's the modem, not the wireless router that is the problem.
The modem must have the proper account name & password for it to work.
Test:
Connect a computer directly into the modem (without router). The modem has an Ethernet connector. If you can't get Internet by connecting a computer directly to the modem, then you will never get the router to work.
Contact your ISP. They may not give you the account name / password, but instead do a service call to your location.
Oct 06, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have a WGT624 router. I have had verizon internet for about 2 months. Recently, I could not get on the internet using wireless but could when just using the modem. I have unplugged the router and then...
either you need to reconfigure the router for the wireless configuration or setup the router for PPPoE connection. if you have internet directly to the modem contact your router manufacturer if not then you need to contact your ISP and ask if you need to setup the route rwith PPPoE connection and get the user/password
Sep 07, 2009 | NetGear WGT624 Wireless Router
D-Link DI 514 Wireless Router (DI-514) Logo
49 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
