Question about Ovens
Main fan oven element gone, label with model number not readable, how can i get model number to be able to order prt?
  • 51 Answers
Owners manuel is the only place else/ sometimes you can take the park to a service center near you and they can match it up or get a number off of it
Posted on Oct 01, 2009
Hotpoint 24in double electric wall oven 20RJ83D not heating, element is working
The thermostat for the upper element has gone bad. Needs to be replaced.
Apr 15, 2017 | Ovens
Fixed fan element, but can't remember how to put it back together again
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jun 22, 2012 | Smeg Ovens
Oven and grill not heating up, model no se 336ss-5
Dec 04, 2011 | Smeg Ovens
My smeg electric oven model no. SA22XMF/7 is not heating after we lost power. Fan and light is working but the heat is not. What can that be ? Is it the fuse or the element has gone
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Nov 29, 2011 | Smeg Ovens
My kenwood CKB200 oven tripped my mains circuit. When I put the power back on the Oven did not heat up as well as before. I am assuming that one of the elements has gone. There is less heat at the bottom...
ISOLATE THE MAINS POWER BEFORE OPENING ANY PANEL ON YOUR APPLIANCE
There are sometimes up to three heating elements in simular types of ovens.
A Visual inspection is required to accertain which is the element not working, remove rear panel, there is odd types that have the element to the side of the fan assisted oven, have a good look when panels removed. The blow element usually has a blow out hole with Black Gray at the point it will feel rough not smooth like the rest of the element case, the second way is a bulge on the surface skin, it should be easy to identify. Part could be obtained through www.whitegoods.co.uk you will need the model and serial numbers. Some models you have to remove the fan or fans if twin, some models have top fan usually no element in the top except grill.
Hope this has been helpful please send me info if more tech is required.
John
May 20, 2011 | Ovens
Hi i have a belling oven model number XOU252 and for the past year and half the oven element keeps blowing. It will first start my tripping my mains electric switch which can go on for weeks then the...
ISOLATE THE MAINS BEFORE OPENING ANY PANEL
Remove the rear panel, there is a component with two terminals screwed to the chassis, read whats on it, take a note of the letters and numbers, get a replacement, from a local electrical store, or www.whitegoods.co.uk you will need the model and serial number, this component stops the cooker from over heating, the elements have to be controlled, the second cause is fan running too slow, if the fan does not cause enogh pressure the element will over heat.
John
May 19, 2011 | Ovens
The main oven of my DY46 Hotpoint is not heating up
It will be the element that has gone, and it is easy to replace.
Remove the cover at rear of oven compartment, and you will see the fan element, just undo fixing screw,and replace element.
Feb 22, 2010 | Hotpoint DY46 Style Line Stainless Steel...
Main oven not heating.
You need to replace a faulty main oven element.
This is done by removing the rear cover in the main oven,
there you will see the element, disconnect and replace.
It is not a difficult job , and is not too expensive.
Plz frate my solution.
THANKS.
Jan 06, 2009 | Zanussi Ovens
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Smeg SNZ91MFX1 Fan heating not working
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Jan 01, 2008 | Smeg SE250XUK Stainless Steel Electric...
Ovens Logo
35 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
