Question about Lexmark JetPrinter X1185 All-In-One InkJet
HOW DO I FIX A SHORT CIRCUIT ON A LEXMARK X1185 PRINTER?
WHERE DO I LOOK FOR A SHORT CIRCUIT ON A LEXMARK X1185 ALL-IN-ONE PRINTER?
WAS WORKING FINE UNTIL MY DAUGHTER PUT A PENNY IN IT AND AFTER SHAKING IT OUT... IT STARTED DOING THIS PROBLEM.
I PLUG IN THE POWER SUPPLY (AC ADAPTER) ...THE POWER BUTTON LIGHTS ON THEN GOES OFF IN A FEW SECONDS. NO NOISE NO MOVEMENT.I TRY TO PRESS THE POWER BUTTON AGAIN BUT IT WILL NOT COME ON.
I TOOK IT APART AND CLEANED IT (DRY RAG DUSTED BUT HAD TO WASH THE GLASS FOR THE SCANNER AND BUTTONS) THE BUTTONS MAKE CONTACT AND THE WIRES ARE CONNECTED TO THE GREEN CHIP.
i KNOW ITS NOT THE ADAPTER FOR IT WORKS WITH ANOTHER PRINTER AND IT GETS POWER TO THIS PRINTER FOR I NOTICE A RED LIGHT STAYS ON BEHIND THE CARTRIDGE PIECE, EVEN WITH THE OTHER ISSUE.
IF I MOVE THE CARTRIDGE SLOTS TO THE MIDDLE WITH THE ADAPTER NOT IN, THEY MOVE EASY..BUT WHEN I PLACE THE THE ADAPTER IN, THE SLOTS INSTANTLY MOVE TO THE SIDE AND THERE IS RESISTANCE WHEN TRYING TO MOVE THEM BACK TO THE MIDDLE AND A GRINDING/ZAPPING NOISE WITH A STRONG SMELL COMES FROM THE MOTOR ON THE LEFT CORNER..IM GUESSING CONTROLS THE CARTRIDGES MOVEMENT.
SOO IF THIS IS THE PIECES CAUSING THE PROBLEM WHAT IS IT AND WHERE CAN I GET A REPLACEMENT? AND COULD THERE BE ANYTHING ELSE CAUSING THE PROBLEM THAT SHOULD TRY FIRST TO FIX?
  • Lexmark Expert
  • 228 Answers
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test.
To self-test the printer, please follow the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please contact Lexmark tech support.
Posted on Oct 01, 2009
Lexmark x1185 not printing all the page
In this case what i would Request u to do is.........
Goto Control Panel goto Printers folder.........
There u will see the Lexmark Printer Icon...........
Just right click on the Printer Icon and click on Properties.........
Now click on Advanced and goto Print Processor.........
Change it to Lexmark NTEMF 1.0008........
Click on Apply click Ok now try to Print..........
Prints Fine............Issue Resolved........
Same Problem........
Download the Lexmark ToolBar from:
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1255995709_0_en,00.html
Restart your computer once and now try to print using the Lexmark Tool Bar..........
It should work fine........
Good Luck..............
Apr 13, 2013 | Lexmark JetPrinter X1185 All-In-One InkJet
Driver for lexmark x1185 using mac os 10.5
He can simply plug it in to the computer (the Mac) and if it does not work immediately, then run software update. Software update should be ran WITH the printer plugged into the computer. It will then show an update called "Lexmark Printer Driver 1.1" and is about 71MB in size. After installing this update, the printer should work fine.
Apr 13, 2009 | Xerox WorkCentre M15i Laser Printer
Need to instal lexmark printer scaner x1185 given to me. no disk
Sure, try the link below. Choose your operating system and then save the driver to your desktop. Open and install.. http://downloads.lexmark.com/perl/downloads/downloads.cgi
Mar 24, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
My Lexmark X1185 will scan but will not feed to print
You probably need to adjust the roller or do an alignment. Your owners manuel should have the info on how to do this.you can probably clean the roller . If it shiny it will not pull up the paper. Check it out.
Oct 29, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1185 printer will not print color......everything else works fine
the ink is clogged not the cartridge but were the ink feeds into the printer. there should be a cleaner tab in the printer preference tab if available
Jan 08, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark x 1185 on windows vista
icannot conect my lexmark x1185 to my compaq vista
Jan 07, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Ink wont work for Lexmark X1185
Is the cartridge in correctly? Is this a new printer or did it happene randomly one day?
Oct 22, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark JetPrinter X1185 All-In-One InkJet Logo
326 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
