Question about Kitchen Ranges
Whirlpool slide-in gas range GW395LEPS00
My mother turned on her 2-year old Whirlpool slide-in gas range (GW395LEPS00) to 375 degrees and baked cookies for 15 minutes. Range became very hot, smelled an odd burning plastic-like smell, which promptly set off the smoke detector. Cookies overcooked, as if oven was too hot (it was very hot to the touch).
Error code E2 F3 displayed - pretty sure but only saw it briefly. Called Whirlpool and they said we need service call. Possibly sensor?
However, upon reheating stove to exact same temperature for same amount of time later this evening, stove appeared to heat normally and no error codes displayed.
Worried about way too hot oven, bad smell, and setting off smoke alarm. Technician supposed to come on Friday but not sure if it is a sensor and sensor part not available unless we order and we are not sure of the problem. It's Christmas! Any suggestions?
Many thanks!
  • 15935 Answers
SOURCE: Whirlpool gas range model gw395leps00 error code e2 f3
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Posted on Sep 29, 2010
0 characters
1 Points
Need to adjust oven temperature on a Croley gas range
you shouldnt need to adjust the burners for a temp problem.
the control has a built in calibration setting and it should be described in your owners manual.
if you dont have the manual, then try to set the oven temp to max, 550, and then hold the bake button in for 10 to 30 seconds. after that it should beep and show you a 2 digit number like 00. that is the calibration mode, then you can adjust it up or down +/- 35 degrees. try to make a small adjustment first like 10 degrees and see how it bakes.
if it takes too long to bake, then use + degrees, if it is burning things then lower -10 degrees.
hope that helps you.
Jan 03, 2010 | Crosley CE35100AA Electric Kitchen Range
Oven temp low. recalibrated up 35 degrees, 375
no you need to still recalibrate the unit if your using the baking style thermo they are famous for being off 75 degrees
Aug 09, 2009 | Kitchen Ranges
Whirlpool oven won't ignite
The good news for you is that your gas provider, the folks who bill you for the gas offer a free service whereby they will send out a technician to adjust your stove for no cost.
Apr 01, 2009 | Whirlpool GW395 Gas Kitchen Range
KitchenAid gas range superba not reaching/registering right temp.
Always preheat your oven and let it cycle at least 2 times. Your unit may show 350 but the manufactures know that it is not 350. When it registers preheated, it really means that it is at an acceptable temperature to start cooking. If you think that it may not be calibrated correctly, your owner's manual will have instructions on how to recalibrate your oven. You will be able to raise or lower the temperature by + 25 degrees or - 25 degrees. As far as the gas smell, you will from time to time smell a gas smell with a gas oven especially if you are right at it when it ignites. If you are smelling gas when it is not in use then you should be extremely concerned.
Mar 14, 2009 | KitchenAid KGST307 Gas Kitchen Range
Oven temp control not working
you need to calibrate the oven.
go to this web site
the second in the list is your solution
Dec 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven will not heat past 220 degrees
Check your bake element, I had the exact same problem and found the bake element had burned in half. The broil element comes on during preheat and kicks off at around 220 degrees.
May 06, 2007 | Amana AER5515QA Electric Kitchen Range
Oven temperature fluctuating
Glowworm, Im assuming your model is a 790.78802500. If your husband is handy with a meter have him ohm out the sensor. It should show around 1091 ohms at 75 degrees or room temp. The preheat is programed so that the manufacturer can get the energy effecient label on the range and what ever perks they get from it. It actually should take around another 10 to 15 minutes to reach the set temp after it shows preheated. You can calibrate the oven by setting bake to 550 degrees. Then press and hold the bake pad again for 15 seconds or until a single beep is heard. Now you can adust temps up or down in 5 degree increments up to 35 degrees by using the slew keys. It will show in the display. Once you have the calibration done, press stop/clear. back
Nov 01, 2006 | Kenmore 78802 / 78804 / 78809 Gas Kitchen...
Kitchen Ranges Logo
722 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
