Question about Dryers
Hello my name is Mike, I have a GE
Hello my name is Mike, I have a GE DBL333EB3WW and it does not dry anymore. I am about to take the back off to change the heating element but I can not figure out how it comes off. Do I have to take the 3 screws on the inside of the drum out before I can remove the element?
  • 304 Answers
The link below describes disassembly of the dryer you have . You will notice that the manual is for Westinghouse and Frigidaire. GE must have had some made for them also. Circuit diagrams and control panel appearance may not be exactly the same but disassembly will be.
The disassembly section begins at page 61.
DBL333EB3WW Service
Posted on Oct 01, 2009
Water leaking from washer bottle
My name is Mike.
I read your problem. If your talking about your windshield washer bottle. Then to save some money, you can take it out, and seal the leak if you know where the leak is coming from. At Home Depot in there construction area or plumbing area, they make epoxy that you can mix up and put on the area where it is leaking, and let it dry until hard, and put back in and good as new. Plan b would be checking your local junk yard or u-pull it places to see if they have one for your model. These are the ways to save some money. This will save a lot of money from cost of new one from dealer.
Oct 06, 2011 | Cars & Trucks
I have a GE dryer model DBL333Eb3WW, can you tell me how to change the heating element? GE is telling me I have to buy the whole housing, ($200) can I just change the heating coil?
Hi lwoodard925...
Call and talk to these people at www.partselect.com, they will have your part and give you advise on how to install it.
Please take time to rate me 4 thumbs up.
Sep 03, 2011 | GE Dryers
Have a dbl333eb3ww GE electric dryer it tumbles but no heat ?
has it worked before?
it could be a safety, it could be the heating element.
Mar 27, 2011 | GE Dryers
Stove top burner keeps on clicking
Hello, your problem is going to be 1 of 2 problems, 1st did you spill liquid on the switch? if so the switch has shorted out, unplug the appliance for 24 hours to dry the switch out then plug it back in...if after 24 hours it is still clicking you have a bad switch (these are the burner knobs) check each one with a ohms meter, the one that is bad will read infinite on your ohms meter when it is switched off. If you have any other questions please feel free to comment. Good Luck!! Mike
Dec 03, 2009 | GE Kitchen Ranges
GE Spacemaker Electic Dryer Poor Drying
Hello
Make sure you have a 30amp two pole breaker. Also, it could be a heater problem.
John
Nov 24, 2009 | GE Profile DPXH46EAWW Gas Dryer
Ge gas stove top keeps clicking
Hello, your problem is going to be 1 of 2 problems, 1st did you spill liquid on the switch? if so the switch has shorted out, unplug the appliance for 24 hours to dry the switch out then plug it back in...if after 24 hours it is still clicking you have a bad switch (these are the burner knobs) check each one with a ohms meter, the one that is bad will read infinate on your ohms meter when it is switched off. If you have any other questions please feel free to comment. Good Luck!! Mike
Sep 22, 2009 | GE Kitchen Ranges
Water leaking out of the bottom of my ge refrigerator.is there a tray that I need to empty? cannot locate one.
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 11, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Leaking water onto the floor from bottom left side of refrigerator
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 23, 2009 | GE Refrigerators
Dryer takes hours to dry one load of clothes
I WOULD SAY YOUR DRYER NEEDS CLEANING OUT OR YOUR WALL VENT IS CLOGGED AND NEEDS CLEANING OUT-MIKE
Mar 04, 2009 | GE Dryers
Towels won't get dry in GE dryer
there is a blower wheel that move the moist heat air out,i think you have a clogg on the dryer vent side or the wall vent side,they need to be cleared or the dryer holds the moist hot air in the dryer and takes forever to dry,let me know how you do--mike
Nov 12, 2008 | GE Dryers
Dryers Logo
245 people viewed this question
Top Dryers Experts
