Re: RCA lcd TV mod. L32WD12.\r\nTV works fine for
TV works fine for a while, then picture will go black-&-white, and there wiill be lines across the screen.
Any suggestions?
  • jiro Oct 01, 2009
    Thanks for the tip.
  • 17,970 Answers
I suggest review the User Guide (page 29 and next) for the Advanced Picture Settings (Automatic Format).
NOTE:
If you're getting a black and white pciture from a device you're connected to your TV, you might have your video cables connected to the wrong jacks. A yellow video cable connects to the yellow video input jack on the side of your TV; three yellow video cables or bundled component video cables (red, blue and green) connect to the component input jacks on the back of your TV.
I hope help you, good luck.
Posted on Sep 30, 2009
Rca tv model l32wd12 sound no picture
You need to replace the mother board/main board.
Make sure you have a really good surge protector for ALL your electronic devices.
Feb 04, 2015 | RCA L32WD12 32 in. LCD HDTV
RCA L32WD12 will not turn on without several trys
Likely bad filter caps in the power supply---if you look inside and find this it may be a easy repair.
Dec 18, 2012 | RCA L32WD12 32 in. LCD HDTV
TH BUTTONS ON MY RCA 32 INCH TV WON'T WORK
If all do not respond the set likely has a keyboard lock feature---look to the owner manual and read it carefully.
Dec 09, 2012 | RCA L32WD12 32 in. LCD HDTV
My rca l32wd12 tv has a black screen no picture no sound
good day. you may consult that problem to qualified technician to fix you problem
Jun 21, 2010 | RCA L32WD12 32 in. LCD HDTV
Were can i get a power supply unit for a rca l32wd12 tv
You can order it from the link below:
274595
Do not forget to rate the solution.
Thanks.
Mar 01, 2009 | RCA L32W11 32 in. HD-Ready LCD Television
POWER WON'T COME ON
I have the same problem with RCA L32WD12
THIS TV IS ONLY A FEW MONTHS OLD HOW DO I GET SERVICE
JERRY
Sep 01, 2008 | RCA L32W11 32 in. HD-Ready LCD Television
Link
I was referring to the links posted by Ekse. If you could send me the info you have, I will point you where the capacitors are.
My email is jah2mil@hotmail.com
Aug 08, 2008 | RCA L32W11 32 in. HD-Ready LCD Television
RCA L32WD12
There is a small glass cartridge fuse located inside your tv. You must remove the back to access it.
Feb 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA L32WD12 32in. HGTV LCD Television
I had the same problem happen this afternoon, so I took it apart, and the source of the problem is the key controller panel (behind the buttons). It's held in place by 2 screws, if you take the case apart, which is literally only 15 or 20 screws, and then loosen the 2 screws holding the key controller panel on, and then use a small screwdriver to space it out from the button caps. Tighten the screws, and put it back together. Just be careful not to let it go too far to the other side, or you'll have a problem with the menu going on and off at random, which is just as annoying.
Nov 07, 2007 | RCA L32WD12 32 in. LCD HDTV
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
