Question about IBM IntelliStation Z Pro 6223-42U PC Desktop
Newest bios 1.70A doesn't load and I even followed the crisis recovery procedure. what next?
  • 86 Answers
Why are you trying to update the bios. is the computer working. you should only update the bios when there is a specific probblem relarted to it
Posted on Oct 19, 2009
Hp Probook 4520's Bios Downgrade help
If you download the bios version you want to a usb stick, copy it to the 4520 and install it from there it should overwrite the new version
Jun 11, 2017 | HP Computers & Internet
Hi i have an acer aspire one 523h-2588 and in the bios it says "IDE0 HDD Password is : Frozen" how can i get rid of it to use my laptop again cause it wont let me see my windows
Acer Aspire One BIOS Recovery The Acer Aspire One has a built-in BIOS recovery routine, which can boot into a minimal BIOS environment via a special boot block to re-flash the BIOS, even if the system does not pass POST and does otherwise not boot anymore. This procedure is also known as Crisis Disk.
First format an USB flash drive with FAT. It does not need to be bootable.
Download the latest BIOS, and extract all files. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Turn the AA1 off, and verify both battery and AC adapter are plugged in.
Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press it once. The AA1 will now access the files on the flash drive and initiate flashing the BIOS. After a while the power button stops blinking, and the AA1 reboots by itself. Wait patiently.
If it doesn't reboot, but keeps blinking, wait at least a few minutes before turning it off, and try again.
Oct 06, 2011 | Acer Aspire One AO532H-2527 Netbook
Hi i need a expert to resolve my laptop Acer Aspire 1640z . I was upgrading my bios from 3a19 to 3A24 and now... after powering on, i hear 1 long beep and 2 short beeps and my screen is black. Nothing...
According to my troubleshooting manual of Acer Aspire 4520-Z3 about
BIOS Flash Utility:
The BIOS flash memory update is required for the following conditions:
New versions of system programs
New features or options
Restore a BIOS when it becomes corrupted.
Use the Phlash utility to update the system BIOS flash ROM.
NOTE:
If you do not have a crisis recovery diskette at hand, then you should
create a Crisis Recovery Diskette before you use the Phlash utility.
Do not install memory-related drivers (XMS, EMS, DPMI) when you use the Phlash.
Please use the AC adaptor power supply when you run the Phlash utility.
If the battery pack does not contain enough power to finish BIOS flash,
you may not boot the system because the BIOS is not completely loaded.
Follow the steps below to run the Phlash.
1. Prepare a bootable diskette.
2. Copy the flash utilities to the bootable diskette.
3. Then boot the system from the bootable diskette.
The flash utility has auto-execution function.
You need to prepare a bootable Flashdisk into dos mode
then you should search for the above mentioned crisis recovery
diskett and transfer its content to the flashdisk.
I read from another forum that for recovery of Aspire 4520 problem
can be done through pressing of the keys combination as follows:
press FN + ESC and hold them, then just hit the power on button
and release it, after awhile "the power button" should blink red,
release the keys FN+ESC and don't touch anything.
After successful of recover the bios it should restart normally.
That happen after 20-30 minutes. If it doesn't restart just repeat the
process.
Hope it helps
Mar 09, 2011 | Computers & Internet
Only a black screen, no indicator lights are nurning
I am using an Acer and it happened to me thrice. It is an easy fix.
If it doesn't reboot, but keeps blinking, wait at least a few minutes before turning it off, and try again. Good Luck
Jan 24, 2011 | Acer Aspire One PC Notebook
I need to perform a BIOS crisis recovery
please remove bios battery and weat 24 hours after install bios battery ,I am sure your computer work again.Never use new RAM because it is not adjust *********** board frquency or system bus.
Nov 23, 2009 | Toshiba Satellite A215-S7422 Notebook
No display
Hope you have tried F5. Also try to update the BIOS via the crisis disk.I think the crisis disk program is on the recovery cd you got with your acer one. if not it's available for download at the acer website.
Thanks for contacting Fixya.
Nov 03, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer 5920 Laptop bios problem
it is not possible from crisis recovery disk.You must replace *********** board
Jun 25, 2009 | Acer Aspire 5920-6727 Notebook
Asus mother board bios
what model is your motherboard? try searching for it on the internet. What is the symptom on the motherboard now? Is it accessible ang operating? Let me know so that I can help you further. Goodluck!
Sep 17, 2007 | Intel Motherboard
IBM IntelliStation Z Pro 6223-42U PC Desktop Logo
124 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
