Question about Polaris Qt Quiet Spa Blower 220v 2 Hp
Our blower randomly turns on
The blower on our pool spa has just been randomly turning on---because the water level isn't always adjusted for the spa, it rapidly drains the pool. What could be causing this problem?
The spa side switch probably has a short and will need to be replaced. If the rubber coated buttons are cracked then moisture has gotten inside and corroded the contacts.
Posted on May 03, 2010
    Problem Solver:
  • 3 Answers
Cold weather turns it on automatically to keep pool water from freezing in your water pipes.
Posted on Dec 04, 2009
How do I adjust the pressure switch on my hayward h250 heater
The purpose of the pressure switch is to verify the pool pump is operating properly and water pressure is present in the heating chamber. When water pressure is not present, the heater control system is designed to not allow initiation of flame. The pressure switch is preset at the factory for deck level installations. When the heater is located below the level of the spa or pool, the pressure switch may require an adjustment to compensate for the no-flow static head.
CAUTION: The Hayward Pool Heater is essentially a furnace. A trained technician should be consulted to repair it. DO NOT OPERATE the Hayward Pool Heater without a properly functioning and calibrated water pressure switch. The pressure switch adjustment requires both the pool pump and the heater be operational. As a result, extreme caution should be used during this procedure since sources of energy can not be isolated during the procedure.
The following procedure is recommended to calibrate the pressure switch.
1. The water pressure switch is located behind the front service panel. The pressure switch is typically on the left side, above the burners.
2. Be sure the water filter is clean before making the adjustment.
3. With the pump and heater system switch on, carefully turn the pressure switch adjustment dial clockwise, until a click is heard from the gas valve.
4. Turn the adjustment dial counterclockwise 1/4 turn.
5. Turn the pump off and on several times. The heater should shut off immediately when the pump is shut off. If the heater fails to shut down when the pump is off, repeat the steps above until the pressure switch is properly adjusted.
6. If the adjustment process fails to produce proper results the pressure switch should be replaced.
Jun 22, 2014 | Hayward H Series Pool & Spa Heater...
Jandy pda time keeps resetting back to default and the spa blower will turn on and off by itself
go to system set up see if programs if you have a 4 button spa remote disconnect and see if it goes away sometimes they get water in the wiring no programs are stored in the PDA
Jun 09, 2013 | Jandy Aqualink Pda Ps8 Wireless Handheld...
I filled my pool with hard well water. I added salt, waited, then turned on salter system. Water is brown. Is this from the hard water? How can I correct this?
The brown water is from the well water used. For an average pool of 18x52 I would add 2-3 gallons of regular chlorine and filter filter filter
If you are using the pump that came with the intex pool you will want to blast the filter cartridge with the garden hose about every 12 hours so that your flow doesn't slow down too much
Jun 14, 2011 | Intex Automatic Salt Water System for ...
I run the filter pump then turn on the salt water system for 4 hours and test for the chlorine and it is always very low or no chlorine and the ph is always high
pH will always rise over time when using a salt generator. You'll need to periodically add acid to counteract this affect. As far as low chlorine levels try running the system longer...An average pools circulation system is setup to turn over the pool water once in about 8 hours. Running your system longer should lead to a higher chlorine residual and overall cleaner water.
John
Apr 26, 2011 | Intex Automatic Salt Water System for ...
I have a Jandy 2440, water level decreases in spa mode
Probally your return JVA is not turning all the way. If it was going down fast that would mean not turning at all and you would probally need a new JVA. Not getting all the way around means the cam has probally slipped. If you have a book (more of a pamphlet) on the JVA it can walk you through adjusting the valve. It is worth it it comes with pictures.
Pull the handle and remove the top of the JVA by removing the six small screws. Once it is open than you can loosten the set nut on the shaft and adjust the valve to the full spa position. The cam on the shaft will need to be set so that the valve goes off when it reaches this position then you will need to tighten the set screw again. Run the valve a few times to be sure it stops when it should. If you have it set then go ahead and put the top back on. I hope this helps, good luck.
Mar 01, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
How do I lower the water level in my pool? Show a diagram, so I can see what values I need to turn and adjust. My pool has a float mechanism and a drain fuction at the main control panel but I am not sure...
Their is no valve to turn the float valve need's to be lowered. If the level has been good and has just started to run high you may need to replace the float valve. At your house you will find a pipe coming off one of your hose bib's and running into the ground. This will be the pipe that has a valve to shut the leavler off.
Jan 21, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink RS4 randomly turns on blower, pump, heater
I have has to deal with the same problem and have found that the spa switch is causing the problem. When I went into the lockout controls menu and locked out the spa switch I no longer had the problem. Once I figured this out and determined the spa switch was faulty I replaced the spa switch and everything is work correctly now.
Oct 09, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Controls for lights/waterfall/air blower randomly turn on
Do you have a spa switch?If so unplug black/brown terminal bar from outside jandy panel.diagram on inside of door.If this corrects the problem replace switch
Sep 27, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Polaris Qt Quiet Spa Blower 220v 2 Hp Logo
248 people viewed this question
Top Polaris Garden Experts
Paul Bade
john h
Are you a Polaris Garden Expert? Answer questions, earn points and help others
