Question about Dryers
My druer is heating but the drum wont spin
My dryer is heating but the drum wont spin
    President:
  • 1,922 Answers
Either the motor is defective or the drum belt is broken or off the pulleys, if you can't hear the motor start and run w/o belt attached and it just buzzes the motor start cap could be bad
Posted on Oct 03, 2009
Why portable dryer heats but does not spin?
Open it up and check the belt inside. A belt is around the drum and around a pulley at the motor. If it is broken or has slipped off, then it wont spin.
Jan 18, 2016 | Dryers
Dryer is doing everything but drum spinning... counter thinks its going... have not let it go long enough to see what heating is doing but drum is not moving.....?
sounds like the belt:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
routing of belt:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Good Luck Tim
May 10, 2011 | Whirlpool LER5636P Electric Dryer
Makes a banging noise when it rotates
Check the druer at the seam of the drum, inside the dryer at the seam of the drum there is probably a crack in the drum, also if it goes away after the dryer has a chance to heat up it may just be the seam hitting the wheels, check for the crack first, very common.
Jan 07, 2010 | Dryers
Druer works, heat and tumbling but it makes a loud
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Oct 28, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
Heats but wont spin
is the dryer belt on the moter pully and drum or possibly broken belt
Aug 13, 2009 | Crosley CDE6000 Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Whirlpool Dryer wont spin
If it heats but doesnt spin, most likely the belt. May not be broke though. May have fallen off. Let me know if you need more help.
Dec 16, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
211 people viewed this question
Top Dryers Experts
