Question about Sears 61301 Gas Kitchen Range
No clicking noise when turning the nob..
If the gas isn't on isn't the stove still Suppose to make the clicking noise? I just bought a used one and it dosnt make the noise.is the suppose to be a plug in the back of the stove because there isn't one and I thought it should have one.
  • 333 Answers
Most modern gas ranges do have an electric pilot light. This one however does not. Normally you should always get the ignition (clicking noise) whenever you turn the temperature control knob. Provided that the stove is plugged into an electrical source. If you are not, then your ignitor could be out. Replacing it is fairly easy with a difficulty scale of 5/10.
But on to your problem. If you lift the lid on the stove top you will see two holes about halfway between the front and rear burners. Just connect the stove to a gas source and put a match or lighter to this hole. Don't worry, it won't blow up or flare up on you. You will need to do the same thing to the oven. If you open the broiler part of the stove, use a flashlight and look inside. You will see a similar type of gas line. Do the same with a match or lighter.
As with all gas appliances, ALWAYS check your gas lines for leaks using soapy water. If you see bubbles after spraying the solution on, then you have a leak and shouldn't turn the gas on until it's foxed. Use yellow Teflon tape or "pipe dope" on all gas connections.
Posted on Sep 30, 2009
  • Sears Master
  • 5,568 Answers
If you have no ignition on any top burner, the ignition transformer has failed. This is a high voltage transformer and is probably located in the control panel of the range.
One of the nobs on the front of my gas stove is broken and i would like to know where i might get a replacement on ? the burner still works if i push the nob back on and turn it but it is broken in half...
Hello Danny, I have seen replacement knobs at Home Depot and Lowe's Hardware. Write down the make and model number of your stove and take a knob with you to compare.
Mar 24, 2015 | Kitchen Ranges
The electric igniters for the stove burners stopped working. All four stopped at the same time.
If all 4 stopped working at the same time, the problem is with the spark modulator.
If the igniter is working on several of the burners but not on another, (or any variation), the problem is with the igniter wiring harness.
By design, the igniter for each burner is daisy chained in the wiring harness such that if one goes, the others will still work.
Mar 24, 2015 | Magic Chef 31000 Gas Kitchen Range
Amana counter top gas stove when plugged in start making clicking noise and you can smell gas .
on most, your push down and turn to hi to open gas valve and turn on piezio to light burner. it sounds like you have a knob already turned on . the control under the knob may need replacing. kinda an easy replacement if you get new part. check out repairclinic.com for video(maybe) but for parts for sure. be careful. gas is explosive.
Mar 16, 2015 | Amana Cooktops
Nobs on stove won't go off
For starters turn the electric off. Is your range gas or electric? When you turn the knobs to off do the lights stay on? What brand and model number do you have?
Jul 30, 2013 | Cooktops
Kenmore elite gas range clicking sound
If unplugging it for a couple minutes and plugging back in does not rectify then it sounds like a bad spark module or a shorted wire inside. All 4 should spark at the same time when any burner is used. (Does trying to light a burner make the other 2 spark too?)
Eric
Jun 20, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Gas stove makes clicking noise when turning on
When a gas stove is clicking, it means it is trying to ignite the burner. If the knob is held in the ignite position for more then 3 seconds and the burner does not ignite, it means that (1) the gas is shut off to the stove, (2) she does not have gas service set-up yet at the apartment, or (3) the gas nozzles feeding the burner are dirty and clogged.
Most of the time, when you move to a new apartment, you need to call the gas company and have the gas turned on, unless it is included in your rent. Either way, when a house or apartment is unoccupied, the gas is turned off for safety reasons. I would contact the landlord to be sure.
Mar 22, 2009 | Stoves 600SiDOm Gas Kitchen Range
How does the q900 works
I do not know either but I would be tempted to turn off the gas, but keep the electric to the oven, and use a plastic Knitting needle to find out. It should show on a display somewhere.
Feb 11, 2009 | Stoves Premier 720GRa Gas Double Oven
Super Capacity 465 Gas Range
my gas stove top burner will not ingnite when I turn on the gas.
I have gas supply to the house, the gas stove top makes the tick tick noise when you
turn one of the burners on, but no flame, even if you try using a match.
What all can I checK?
Sep 20, 2008 | Kitchen Ranges
Gas cooker keeps igniting
Sometimes when I clean my cooker, and it gets damp, mine ignites like that. It soon stops after it dries out. Give it chance and see.
Jun 21, 2008 | Stoves Premier 720GRa Gas Double Oven
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Sears 61301 Gas Kitchen Range Logo
356 people viewed this question
Top Sears Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Sears Kitchen Range Expert? Answer questions, earn points and help others
