Question about Brother HL 1440 Laser Printer
The paper(8.5"X11")in side the HL-1440 half way tightly,(the other half is out, which I can see it) How can I get it out?
    President:
  • 1,187 Answers
With printer power either OFF or ON.
With your hands, you must get a good grip on the sheet and pull hard. It will not damage anything.
Thre will be some toner powder on it, so keep it from flying all over.... Best to pull towards the OUT direction. The sheet may tear, but that is normal... Get a better grip and pull.
Posted on Sep 30, 2009
Is there any way to remove the paper jammed inside the HL-1440 Laser Printer? I tried to pull it out, but the paper just tears.
Use your fingers to rotate the rolls until the paper rolls out -try to pull the paper out slowly next time it usually will roll out sorry to sound condescending but it will 90 times out of 100 come out without tearing.
Jan 15, 2013 | Brother HL 1440 Laser Printer
LEFT HALF OF PAPER WILL NOT PRINT I JUST PUT IN A NEWW CARTRIDGE
connect it to your cpu tower the cord fro the printer if you have the mac the outlet is in the back
Sep 16, 2011 | Brother HL 1440 Laser Printer
First page comes out blank, with dRegular on upper left side, i am wasting paper every time i print out HELP
I had the same problem (first page empty except for the term "dregular") under Windows 8. My solution: Install the right driver... Before, I had a general driver (Brother Laser Class 1 or so), then I updated the suggest driver list and chose my exact modell. Now, I can print properly...
Sep 15, 2010 | Brother HL 1440 Laser Printer
My HL 1440 Laser printer does not print The
If your printer have no paper jam inside and paper tray has paper in it, then you need to replace toner cartridge.
Oct 06, 2009 | Brother HL 1440 Laser Printer
Paper jammed and now a piece of the paper is still inside the printer - somewhere. It is a HL-1440. Do you know how I can get the torn paper out?
Turn over the toner/drum assembly and look under the roller and guide, also if you open the rear door there are levers on each side to release pressure on the paper if it's in the fuser. With the toner and drum out, you can see up to the input to the fuser, and from the back is the output from the fuser. It could be HOT!
Sep 17, 2009 | Brother HL 1440 Laser Printer
Brother HL-1440 LASER PRINTER requires ''Service Call A''.
currently, the error you have is not a service errorl, ready and alarm blink means that you have either a paper jam, no paper, or a paper misfeed.
do you get this error only when you try to print?
according to the service manual the lights can not alternate in blinking.
May 30, 2009 | Brother HL 1440 Laser Printer
Paper Jam Around Fuser Unit
Remove the fuser unit and unwrap the paper. The instruction book should tell you how.
Feb 17, 2009 | Brother HL 1440 Laser Printer
Laser Printer HL-1440
Hi , The error message your getting refers to the following for the Ready & Alarm Buttons Flashing.
1. Paper Jam
2. Misfeed
3. No Paper
I hope this helps!!
Dec 05, 2007 | Brother HL 1440 Laser Printer
Brother hl 1440 paper jam
clean the paper feed tires with some alcahol. they are located in the upper part of the machine when you pull out the paper tray. they are gray in color. if that does not work the feed tires may need replaced.
Oct 12, 2007 | Brother HL 1440 Laser Printer
Brother HL 1440 Laser Printer Logo
26 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
