Question about Kenmore Refrigerators
Mold/Bacteria formed between ice dispenser and dispenser lever Can dispenser be removed from lever for cleaning? If not, how to clean?
    President:
  • 1,653 Answers
Use a bathroom mold and bacteria remover spray available from most supermarkets. Also spray down into the feeder on the inside of the door. Make sure you rinse the area thoroughly after use and run water through the water chiller dispenser and run some ice throughthe ice dispenser and throw these away. Then it should be safe to use.
Posted on Sep 30, 2009
Ice cubes wont come out when the dispenser tips it upside down
The ice mold tray has built up deposits that "glue" the ice cubes to the tray. This usually means you will have to change the mold tray. You could try vinegar or lemon juice to clean it but the trays are not that expensive.
Apr 12, 2014 | Refrigerators
I have mold forming on the ice depenser that's next to the water depenser. Is there a way to remove that piece so I can clean it?
with out seeing the brand or model i have to be pretty generic but their should be a removable grate so drips when dispensing ice or water that can be easily lifted and wiped out, if not place a paper towel at bottom of dispenser asm. to catch drips
Jul 23, 2011 | Refrigerators
Ice cubes sticking in tray before dumping. Can't get it out. Lost manual Need to get it out and clean off the mineral deposits.
you may have a bad mold heater . this causes the release of the ice cubes / but do clean out the deposits . as they also prevent a proper harvest .. after cleaning spray mold with a food grade silicone .
Jul 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Mold/Bacteria formed behind ice dispenser spout and above dispenser lever. Can spout be removed for cleaning? If not, How to clean?
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Although you may can clean it by just spraying everything you can reach with a spray bottle of bleach and water mix and let it set for a while and then rinse with clean water. Test an inconspicuous spot the check for damage. Or another mold killer may work just as well.
Sep 30, 2009 | Refrigerators
Ice dispenser has black mold around area that ice comes out
shut down unit press for ice the door will open wipe with warm water
Apr 07, 2009 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Moldy water dispenser area
If you go to geappliances.com click on service and support then click on use and care manuals you can download a use and care manual. Since the refrigerator is white I'd probably use a good bleach spray on the mold be sure to rinse well though so you don't end up ingesting bleach. Chunk of ice sounds like too much water or not enough cold and a qualified tech might not be a bad idea. Good Luck.
Jan 01, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
How do I clean the water lines on a refrigerator?
The ice dispenser spill shelf should be wiped dry immediately to prevent spotting if excessive spills occur. Water left on the shelf may leave deposits. Placing a paper towel under the grill will help absorb the water that would normally stand on the shelf.
To remove deposits, soak the area with one of the following solutions:
  • Undiluted vinegar
  • 1 teaspoon of non-precipitating water softener
  • Mixture of 1 teaspoon of citric acid powder (NOT to be used in stainless steel dispensers) per 1 pint of hot tap water.
Soak until the deposit disappears or becomes loose enough to wipe away. Usually 30 minutes of soaking time is adequate.
Jun 04, 2017 | Refrigerators
Frs26hf6bw6 ice dispenser lever "sticks" and is "harder" to depress.
try cleaning it it may have mold on it and causing itt to not close
Nov 01, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
256 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
