Question about True 52 cu. ft. / 1472 liter Commercial Freezer TM-52F
Fereezer door adjustment - True 52 cu. ft. / 1472 liter Commercial Freezer TM-52F
  • True Master
  • 1,169 Answers
Http://www.truemfg.com/InstallationManuals_old.aspx?language_id=1&event_id=401&from=food
Go to this True web site and check out your manual. This should answer you questions.
Hope this is of help to you.
Posted on Dec 03, 2009
Door open light stays on and freezer quits cooling with door shut
There is probably an adjustment bolt for the door on the bottom underside you can get the door better.
Oct 31, 2013 | GE / FUF21SVRWW
Freezer is level but door is not. matching frig. is level and door is level doors then do not match across both doors. is there an adjustment on freezer door that can be done?
Please check the doors hinges/supports. Loosen the bolts of abnormal level door, adjust the level and tighten the bolts. If it is not work put a metal sleeve on support shaft ( It may wear down already)
I think that all you can do to re-level the door.
Dec 06, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
My freezer does not have the suction sound when the door closes and the alarm sounds constantly
Your door seal is defective. Check that it is clean, that the door has not been bent or twisted, replace the door seal, adjust the door or both.
Nov 29, 2010 | Kenmore Freezers
How do you adjust upright freezer doors? After releveling, the lower opening side corner is sticking out a little and seal is not quite touching, 1/8th".
pull door seal back exposing screws loosen slightly twist door ie. put foot at bottom of door and push or pull top of door.close to see if door mates up good if so tighten screws
Aug 29, 2010 | Freezers
Fridge door sagged and needs adjusting.
the screw holding the door is not well tightening.
Feb 19, 2010 | Freezers
Freezer door has a gap in the middle. Seal doesn't
Put a long straight edge on the door to verify a warp. A 4 foot level is good for this test.
If the door is in fact warped. You should pull back on the seal,loosen the screws behind the seal holding the door liner in place,adjust the door to the straight edge and re-tighten the screws.
If the straight edge does not show a warped door,take a hair dryer and heat the seal where it is off the frame. Do this with the door closed and you will see the seal relax and touch the frame. Let it cool in this position before opening the door again.
If neither of these is the cause,loosen the door hinge and re-adjust the door position,then re-tighten the hinge screws.
Feb 13, 2010 | Frigidaire 19.53 cu. ft. Commercial...
I have a kenmore upright freezer model #253.9266411 there is a gap in the upper left side does anyone know how to adjust the door? The seal is fine
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
Sep 02, 2009 | Kenmore Freezers
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
Will not seal. new from sears.
The description below is for a gap at the top of the door. Adjust the procedure for gap at bottom by "twisting" the door in the opposite direction.
May 06, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
How do you adjust a Westinghouse 2 dooe refrigerator door
Loosen the top hinge screws.
Pull up on the door to where you want it.
While holding the door in place, re-tighten the screws.
Mar 11, 2009 | Frigidaire Freezer Refrigeration White...
True 52 cu. ft. / 1472 liter Commercial Freezer TM-52F Logo
220 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
