Question about General Knipex 10" Diagonal Cutter Pliers
It won't cut nails?
Does it cut piano wire?
    Brigadier General:
  • 4,088 Answers
They probably will a few times, but every time you cut something as hard as piano wire, you put a nick in the cutting edge. It requires extremely hard jaws (like carbide) to properly cut this wire.
Posted on Sep 30, 2009
Porter Cable roofing nailer model are in 175 loses nails out the nose instead of shooting them often what's wrong with it
Usually, on any roofing nailer, the only nail to just drop out of the nose is the last nail of the coil. The nails are held together with two strips of wire welded to each unit. For a nail to just drop out of the nose, the two strips of wire would have to be broken or not totally welded to the nail. Poorly constructed nails will have bad welding or weak or broken wire within the roll. Carefully unwind a coil of nails and check for brittle wire or loose nails. If coils appear to be well constructed, check the condition of the tip of the driver. The driver should have a squared end to cleanly shear the two strips of wire. If the driver is rounded, the two wires will be pulled till they break off affecting the next two or three nails on the coil. Easy to check. Fire one nail, then open latch and examine the next nail to be fired. The head should be aligned with the other nails. If the head is pulled down out of alignment, the driver is not cleanly cutting the two wires. Good luck
May 09, 2013 | Air Tools & Compressors
Tip
Easiest way to trim dog claws toenails?
I always had problems clipping my dogs toenails before I discovered this simple trick. I set my dog up on my outdoor table. It puts me at the comfortable level to trim the nails first of all, and best of all my table has an open filagree pattern. When the dog stands on the table I noticed some of the nails extend into an open place in the table- bam- I was able to cut the nail without the dog knowing I was using the
trimmer. To get each nail, I have to nudge my pet a bit to get one nail at a time into one of the open spots. If you don't have a table like this, be creative, try a wire rack placed on a cabinet, it bends the nails in a natural position to cut just the ends of each nail.
on Apr 15, 2016 | Pets - Others
Ism coil roofing nailer will not hold nails in striking chamber after they advance
The feeder area of the nailer incorporates small levers on both sides of the nails. On the body side, the spring loaded feeder retracts and pulls forward the first nail. On the latch side small spring loaded arm/s hold the nails in place once they are pulled forward. Open the latch and push on both the feeder and the retanier for firm spring tension. On some nailers, due to wear, the grippers on the feeder tend to wear off allowing the nail to slip out of place. On other nailers, the feeder arm/shaft tends to wear and alows the feeder to move out of alignment (check if the actual feeder arm can move from side to side). The feeder shaft should move forward and back with no side to side movement. Finally, some coil nails are welded together with too stiff of wire. After the first nail is driven, the second nail will have one or two strands of wire pointing out not allowing the nails to move into position. After first shot, the two wires should be cut off or bent down out of the way. Good luck.
Nov 02, 2012 | Air Tools & Compressors
What is wrong when the nails Break from the wire coil when feed
I am going to think that you have a problem with the nails. They should not break from the coil until fired and if they are falling,breaking off that is the coil. I would suggest trying another brand or coil. The correct air pressure for a nailer is arund 90PSI. Let me know if you still need assistance.
Mar 04, 2012 | Air Tools & Compressors
How to replace rear window 2003 gmc envoy
NEED TWO PEOPLE, USE PIANO WIRE GUITAR STRING OR SIMULER WIRE, FROM OUT SIDE PUSH WIRE THROUGH WINDOW SEAL TO INSIDE EACH PERSON PULL WIRE AROUND WINDOW CUTTING SEAL, THEN LIFT OUT WINDOW, SCRAPE OUT OLD SEAL , REPLACE WITH NEW SEAL AND INSTALL WINDOW!
Sep 09, 2011 | 2003 GMC Envoy
My P85 simply won't turn on. I have tried two different adaptors. Neither work yet they are functioning with other keys. Please help. I have a gig on Sunday
What adapters have you tried? The P85 REQUIRES a 12 VAC adapter, NOT the common DC type and it needs a 1.5 amp (1500 ma) type adapter. If you connected a DC adapter it will NOT do damage, the unit just won't work. You can find adpaters on Ebay or Google search.
Aug 26, 2011 | Yamaha P85 88Key Portable Digital Piano
The drawers on my homak tool chest are locked and the lock is jammed.
There should be an exposed piano hinge on the back of the lid. Use a small nail and hammer (or a rock, if your only hammer is locked in the tool box) to push the piano hinge wire out a little bit, until you can get ahold of it from the other side to pull it out. The lid will then come off, exposing the jammed lock which you can then remove and replace.
Aug 20, 2011 | Homak Rolling Tool Chest
My Kurzweil ensemble grande mark III, purchased in 1990, has suddenly stopped working. When I switch on, there are no words in the readout and keys make no sound. What should I do?
I had the same problem with the same piano. Your switch has gone bad so replace the on/off switch. Unplug the piano. Pry the on/off switch out with a thin blade screwdriver. With the switch in the "on" position, see if it points to the grey or brown wire & label the wire "on". Cut the wires and bring the switch to a good electronics parts store and ask for a replacement. Install & you're back in business. Or get a handyman to do it for you.
Sep 17, 2010 | Toys
Broken wire from a nail. how do i fix/splice?
I think you are saying a nail was driven into your wall and has gone through your thermostat wires? If that's the case here is a simple solution. Go to your local building supply such as Home Depot. Buy a an "old work" box which is designed to go into your wall where there is no stud. It will require you to cut a rectangular hole just large enough for the box, then tighten the screws to install... but dont do that yet. Get the box and a white or beige plain cover to fit it. The plain cover should have no holes except for the two screws to afix it onto the old work box. Cut a small hole next to where the nail went into the wires. Remove the nail and pull the wires out slightly. See which side has more slack. Locate the old work box on the side where the wires are shorter or tighter (less slack) and pull the other wire into the box so that both can be spliced together. If necessary finish cutting the wires the nail didn't sever. Do not cut red with any other wire at the same time because red is the power (24 vac hot) going to the thermostat. When you have pulled both wires into the old work box and tied a knot to prevent them slipping out, then fit the box into the wall hole and tighten the screws to draw the box snug to the wall surface. Splice each color with a wire nut, tiny wire nuts that are blue or grey are for 18-24 gauge bell and thermostat wires. Join red to red, white to white, yellow to yellow, blue to blue, orange to orange, green to green, etc until all are finished. Doing this will eliminate the need to research which wires are actually in use for your application. Install the cover plate. Test your repair.
Dec 23, 2009 | Goodman GMS90703BXA Heater
1990 honda civic windshield removal
the best way it to remove any trim mouldings and use a piano wire or gutar string to saw the sealent from the glass cut and wrap the ends of the wire around a wooden dowel otherwise you will have a real mess with the broken glass
Mar 20, 2009 | 1990 Honda Civic
General Knipex 10" Diagonal Cutter Pliers Logo
49 people viewed this question
Top General Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a General Measuring Tool and Sensor Expert? Answer questions, earn points and help others
