Question about Bizfon Lands Phones
I have a Bizfone 680 system with three boxes that I?ve had for about 6 years. In the last week, the system has started resetting itself 5-6 times a day. I had my telephone service provider check the lines and he found no problems, so now I?m back to the phone system. Any suggestions would be appreciated. I've been waiting all day for a callback from Bizfon technical support and never heard from them.
  • 84 Answers
SOURCE: telephone connection problem with DSL
unplug everthing from all jacks in the house. call your # a couple of times. if the line rings, plug everything in 1 at a time, but call again after each hook up. if the line goes dead or is busy, that phone you just plugged in is the problem. [ a short in the phone, computer, answer machine, or any piece of equipment plugged into the phone line.] if the line is busy when everything is unplugged, call your phone company. there maybe a problem with your inside wire.there also maybe a box [called a nid] inside your basment/garage or on the side of your house, where you can plug your phone directly in, bypassing all the jacks in your house
hope this helps.
wg
Posted on Feb 13, 2008
SOURCE: Caller ID Problem on the GE2811 Twin cordless phone system
Still have not been able to solve the problem of having inconsistent caller id display when the telephone rings
Posted on Mar 24, 2008
Neoklassic1
  • 70 Answers
SOURCE: no caller ID displayed
If you have digital telephone with cable. First thing you should do is contact the billing department of your service provider. Make sure you are in billing for caller id. If you are let them know you are not receiving service you are paying for. Have them check your number in the switch. Which is the system that allocates each call that is made to and from your number. If this feature is not activated properly in the switch you might be paying for a service that is not properly activated. If all is correct with service provider. Try using another phone that has the caller id feature just to make sure it's not the actual phone. If both phones still doesn't display caller id. You should have your service provider send out a technician to troubleshoot your home telephone lines to make sure all phone jacks and telephone lines are secure and corrosion free, and have them verify service while there. You should also ask about a credit for the time the service was activated until the time the service actually worked.
Posted on Oct 14, 2008
  • 3230 Answers
SOURCE: HF error code
hi,
check this-
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation.
good luck
Posted on Mar 28, 2009
  • 3 Answers
SOURCE: battery back up problem in lg ku990 viewty
don't use a case that has a magnet..... it will drain the battery ...the back is made of metal
from theone33
Posted on Apr 20, 2009
Tv keeps turning off
This is probably due to failing PSU capacitors. It is fixable.
May 19, 2014 | Televison & Video
Frigidaire FKFH21F7HWA Freezer Control Panel Stuck at 0F
did you press and hold the freezer off symbol for three seconds
Jul 31, 2012 | Frigidaire Freezers
When I first turn on the TV there are 3 transparent lines that appear.
The data buffer IC inside of the display panel is bad. It needs a new panel.
Apr 20, 2017 | Samsung LNT4066F 40 in. LCD Television
I have a 2202 Impala. Three weeks ago I attempted to start my car, nothing happened. No click,buzz..nothing. For about ten minutes I jiggled the key, put the key in and out of the ignition several times...
Yes, this your anti theft security failing. Its having a hard time receiving the transponder signal from your key. When it doesnt get this signal, it turns off the starter to prevent theft. It basically thinks its getting stolen so it shuts down. The problem is in the diagnoses. It might be the key, the ignition/lock cylinder, or the TDM computer itself. (Theft Deterrent Module) All are expensive and pointless to fix. Your cheapest route is to bypass the whole system and never worry again. The average life on these systems is 6-10 years. Here is a link with info and some DO IT YOURSELF ways to beat this. http://vatspasslockpasskeysecurityhelp.yolasite.com/
May 17, 2011 | 2000 Chevrolet Impala
I'm having issues with my new HP Pavillion g7. Very slow to get started, gets stuck when opening/starting programs, takes 6-7 mins before I can attempt to get online via wifi. Tonight when I turned it...
hey try repairing your windows with your operating system CD once...or you may have to reformat it..then it will be like new..first backup all the data in C Drive.(OS drive)
hope this helps
May 12, 2011 | Computers & Internet
We at CAAP Davao Philippines have a MGE Galaxy 3000 10KVa UPS with serial no. 13299-4. It was installed last 2003. We had three times replaced its batteries over the period of years, the latest was 2008....
On the Galaxy display you could see what is the remaining battery life time as calculated by the software. Normally after you replaced the batteries you are supposed to reset this counter using specific software by the manufacturer. According to your information you have replaced the batteries 3 times in 5 years period. This is not normal. Nevertheless since the last replacement in 2008 it appears that the battery are now reaching the end life, which is generally 3-5 years life expectancy.
I would review the following of the assumption that the UPS is fully operational and the charging system is working.
1. Do a load test or a battery impedance test to verify the batteries are good
2. I would look at the battery life time specification, whether it is 3-5 years, 5-7 years ect.
3. Check the room temperature, every 10 degrees Celcius above 25 deg reduces battery life time by half
4. Check the number of power failures/ duration of these power failures and if possible what load were on the UPS at the time of the power failures.
I hope this will help. If all verifications are to specifications, then most likely it is a software problem
Apr 01, 2011 | MGE Galaxy 3000 UPS System
Hows to reset oil light and oil filter light on 2007 nissan altmi
press accelerator pedal three times and then turn on ignition. If that doesn't work press accelerator pedal 2 times and turn on ignition.
Jun 02, 2009 | 2007 Nissan Altima 3.5 Sedan
Mitsubishi Projection TV model WS-65513
Good Day;
The continues blinking 99.9 % of the time is four caps on your DM board. The caps are C9B01,C9B02,C9B10 and C9B11 they use 1000UHF the upgrade caps are 680 UHF- 35V. The board is on the very left hand side (from back).
I have performed this repair at least 50 times and it takes me still about 1.5 hours. If you are not handy and do not have a solder station, I would recommend that you call a factory authorized service dealer to perform this repair. With service call and ect. it will cost you around $550.00 and the repair can be done in the home, of course prices varies across the country.
Good Luck, Day, Big Irish.
Apr 11, 2008 | Mitsubishi WS-65513 65" Rear Projection...
My palm treo 680 turns itself off repeatedly
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
Mar 15, 2008 | Palm Treo 650 Handheld
JVC - DVD Video Recorder Model No.: DR-MV5SAX
1 yıl önce JVC DR-MV5SAX MODEL , 062C0323 seri no'lu bir cihaz aldım. Kayıt anında 4-5 dakika sonra "RESETTING" diye mesaj veriyor ve cihaz kendisini kapatıyor. Ne yapmam gerekiyor.
Alaettin Zengin 0 312 290 31 97 Ankara
Nov 08, 2007 | Televison & Video
Lands Phones Logo
67 people viewed this question
Top Bizfon Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Bizfon Lands Phone Expert? Answer questions, earn points and help others
