I Have a motor home in the USA with two Dometic roof top air conditioners Ser No 7477097 and 7477095, I'm importing this vehicle into Australia and for importation I need to know appoximatley the year of manufacture and what type of freon do they havee.g cfc or hfc. Reece Callingham
  • 2 more comments
  • tranphys Sep 30, 2009
    The problem is the Vehicle is still in the USA and I'm in Australia, this is the only information that the owner could supply.
    The Vehicle is a 40ft Country Coach 1988-89 but I'm told the air conditioners have been replaced within the last 5 years.
  • tranphys Oct 01, 2009
    Thankyou, one of the replacement is a 15000 btu but that size difference should make any difference, thankyou for you help.
    Thank you Craig for your help.
    President:
  • 1,714 Answers
Need make and model numbers...
Posted on Sep 30, 2009
  • 1 more comment
  • Craig Butler
    Craig Butler Sep 30, 2009
    Do you now what year the RV is? What make it is?
  • Craig Butler
    I'm going to need something else to go on...I can make a guess if you can tell me what year the RV is?
  • Craig Butler
    Craig Butler Oct 01, 2009
    I'm going to estimate the two units mentioned at 120 volt, 13500 Btuh Roof Top A/C units. Both units charged with 13.75 oz of R-22 Freon. That's based on the research I did on existing RV roof top units out there. It should be comparable to yours. Good luck and thank you, Craig
Why does my Duro-Therm by dometic roof top air conditioner make extra chatter noise on high speed but not on low speed?
clen fan blades at both end of motor. the temperture will be colder at lower fan speed. depending on age and useage the bearings might be going out in motor.
Aug 18, 2014 | Dometic Rooftop RV Air Conditioner
Where can I find a shroud for my 2003 model 59516.331 duo-therm high efficiency Dometic roof mounted dometic RV air conditioner?
Try googeling Camping world ,Adventurerv ,or best rv and truck supplies ,these are all in the USA who deliver to Australia.I usually find that it is much cheaper to buy parts like this from the US even with the delivery charge.
Good Luck John
Oct 11, 2012 | Dometic Rooftop RV Air Conditioner
I purchased a dometic roof top ac unit mdl#641515.301c0, however on the website i cannot find install manual or user manual
What part about installation are you having problems with, and what are you installing it on? Do you have both upper (roof) unit & lower ( at ceiling) ? Is it a ducted system or blowing directly from ceiling assy?
Check this link as well , you may find 6300 series is same install.
http://www.dometic.com/enus/Americas/USA/RV-Products/Manuals-and-Instructions2/
Jun 02, 2012 | Dometic Rooftop RV Air Conditioner
Where can I find a replacement shroud for my dometic roof top A/C?
Try any local RV dealer, camping world, etc , or call 1-800-544-4881 to order directly from Dometic.
This link will take you to a dealer locator for your info on dealers in your area.( http://www.dometic.com/enus/Americas/USA/Customer-Support/Dealer-Locator/ ). Have your model number ready. Most dealers may even have a used one to sell you if you ask.
Sep 29, 2011 | Dometic Rooftop RV Air Conditioner
When set at coojest setting, water begins to pool on roof of my motor home
It is normal for water to come out of your unit. On some units there is a drain line if you take the top off of the unit you will see the line hooked to the condenser side (cold) of the unit. But most units just let water run out on the roof and run off. Your unit may have settled or if you have applied a sealant on your roof you may have changed the flow of the discharged water. The water is moisture that condenses from the air inside your rv. This should not cause you any problems unless you have a leak in your roof.
Aug 08, 2010 | Dometic Rooftop RV Air Conditioner
AC compressor will not engage
It could be the capacitor, it could be a loose wire connection, it could be a delay switch or a contactor/relay.
Mar 30, 2010 | Dometic Rooftop RV Air Conditioner
How do find the roof rafters in a pop top.
Hi; Try using a electronic stud finder and switch to metal detection. Or maybe call or google the company that built the popup. Sometimes they can tell You exactly where to make Your cuts...alpharome416
Feb 10, 2010 | Dometic Rooftop RV Air Conditioner
My roof dometic roof top air conditioner runs but will not cool when the motor kicks on it goes right back off and will not cool
Check run capacitor, or in the compressor wire box, there should be a little black overload that might be weak or loose connection.
Aug 02, 2009 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
