Question about Archos 604 WiFi Digital Media Player
Code 2 My screen says recovery code 2 but none of the options work and I cannot get it to connect to my computer to download the new firmware. Can you hlep?!?
  • Anonymous Feb 19, 2008
    I have the same problem with my 404, but recovery code 3. again none of the options work, if any solution is found I really need to know, i would hate for 180$ to go down the drain......
  • 4 Answers
Hello everybody, i had this same problem with my archos 604 wifi but thankx to someone on another forum i fixed it. it is really easy:
first you take the battery off, then you unscrew the 4 or 6 screw on the sides of the hard drive, then you lift the lid and then the hard drive, VERY CAREFULLY, Then you will see the problem : the little black plug conected through a ribbon to the hard drive is not plugged correctly or it is completely unpluged from the white socket. even if it is not un plugged just make sure it's tight, put everything back together and it should work just fine. ( IT IS A LITTLE DIFFICUL TO SCREW IT BACK TOGETHER BUT YOU"LL GET IT RIGHT) it is a weird problem. but it is easily fixed.
i hope that helps, bye
Posted on Apr 18, 2008
Hard drive is broken.... thats the problem
Posted on Apr 12, 2008
Cretive zen 4gb reload firmware
1. Download this
2. Connect your Zen to your computer
3. Run the file that you downloaded in step 1
4. Follow on-screen instructions
5. It should now be working.
Aug 05, 2009 | Creative Labs ZEN V Plus MP3 Player
Archos 605 wife (wife firmware)
If you chose any of these options already your Os is gone..
try this solution
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in to Pc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 20, 2009 | Archos 605 WiFi Digital Media Player
Creative zen
First off, download the Firmware upgrade from Creative (http://support.creative.com/downloads/welcome.aspx?nDriverType=4#type_4)
Don't run it just yet!
Now, go into the Zen Micro's Recovery Mode:
1. Take out the battery
2. Press and hold the ON/LOCK button in the ON position (far left) and put the battery back in the player.
3. The player will then switch on - wait until "Recovery Mode" appears on the screen then let go of the ON/LOCK button.
The Recovery Mode options include an option to "Reload Firmware".
Now connect your Zen Micro to your PC and run the Firmware upgrade. Your player should be recognized by the Firmware uploader. If it isn't, then then your player has other damage.
Jan 16, 2009 | Creative Labs Zen MicroPhoto MP3 Player
Recovery code 104 for the archos 405 mp4 player
go to archos firmware and download version 2.1.04 to your pc or laptop and save it in a folder then get ur mp4 turn it on and go format you will get a screen that says done leave it on that and connect to your pc or laptop it will recognise your mp4 then go in my computer and open 405 and open your save file and drag the save file into the 405 but NOT into a folder below them and after it has\copied turn the 405 off and start it up should be as good as new
Dec 27, 2008 | Archos 405 Digital Media Player
Creative Zen Touch stuck in "recovery mode"
Have you tried to load the firmware? First you'll need to download the firmware to your PC from Creative's website: Click here. After you've downloaded it, connect your Zen via USB to your PC and open the firmware icon, then click "Upgrade."
For more detailed instructions on how to troubleshoot your Zen, click here
Jun 03, 2008 | Creative Labs Zen Touch MP3 Player
Recovery code 104
Same issue on my Archos 605 wifi 4GB
The Repair didn't work so here's what I did.
1) connected via USB and got all my Picture, Videos and Music to a safe place.
2) Downloaded firmware update.
fouund it here - http://www.downloadplex.com/Drivers/Firmware/Archos/Download-Archos-605-Wifi-4GB-Firmware-2.1.04_109044.html
3. Copied update to root of archos drive and rebooted
4. Archoes installed the update and rebooted and came up to desktop again
5. reinstalled plugins (thank god I saved them) copied plug-in to root.
6. Back on the road again
Feb 23, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 Recovery code 108
1. Download the latest firmware from Archos
2. Format the drive on your player
3. Connect the A605 to your computer using the USB lead
4. Copy the new firmware the A605's root folder (Drive X: on your PC or whatever letter was assigned to your Archos
5. Click ok and you are finished
Feb 18, 2008 | Archos 605 WiFi Digital Media Player
In order to fix this issue, we are going to need to force the unit into a
recovery application. In order to do this please make sure that the unit is
completely shut off. When the unit is off, you are going to want to press and
hold the TV/LCD button and the power button at the same time until a recovery
code 101 pops onto the screen. As soon as you see this, let the buttons go.
Once you got this screen up, you are going to want to repair the operating
system by arrowing down and clicking repair. After this is done it is going
to ask you to connect your device to the computer and install an update file.
In order to do this, you are going to want to go to www.archos.com and go to
downloads. You are going to want to download the firmware for your unit.
After the firmware is saved to your desktop, plug the unit into the computer
and open up "My computer" and you should see the Archos in the list
of drives.
Your going to want to copy the firmware onto the root directory and not in
any file folders. Once the firmware is on the Root directory, go ahead and
unplug the unit from the computer. It should still say Please plug your
device into the computer and install an update file. Click OK. After this is
done, it is going to tell you to please connect DC or USB in to continue with
the update. Go ahead and let the unit install and reboot. After this is
done, you should be able to use the unit properly. If the unit still does not
work properly, we are going to have to create an RMA for the Archos. If you
need anything else, Please feel free to contact us via Email or at
877.300.8879.
Jan 10, 2008 | Archos 605 WiFi Digital Media Player
Can't get out of recovery code 2 on archos 504
I had the same problem and manage to solve it. You need to do the following
a. go to Archos website and download latest firmware and save on your pc
b. turn on 504 and select repair - unit not connected to pcm you will see a screen where you wil be prompted to press DONE (but DONT press it yet!!!!)
c. connect 504 to pc and wait until pc recognise it (it will recognize it this time)
d. copy firmware from pc and paste it to 504 root directory.
e. press done on 504. now when the device restarts you just select Repair and that should work. :)
Dec 13, 2007 | Archos 504 500870 Digital Media Player
HELP!
Can you hear HardDrive clicking?
Oct 03, 2007 | Archos 604 WiFi Digital Media Player
Archos 604 WiFi Digital Media Player Logo
147 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
