Question about SanDisk Sansa Clip MP3 Player
Computer won't recognize clip
Plugged into computer with USB cord and the sansa states it's connected but can't find it on my computer to download anything to it
    President:
  • 803 Answers
Try checking the usb ports to make sure it is not have driver problems:
1. Go to the Windows Desktop, click on the "Start" button, and then click "Run" or "Start Search" if you are using the Windows Vista operating system.
2. Type the following text into the text box: "devmgmt.msc" Click OK.
3. Select your computer when the Device Manager window opens, and then select "Action" from the options at the top of the window.
4. Choose the "Scan for hardware changes" option from the drop down menu that appears.
5. Insert any USB device such as a mouse or flash drive into the USB port in question. Now simply check the USB device to see whether it is working in order to test the port.
If it is have driver problems. Go to http://www.sandisk.com/ and download the driver again.
Posted on Oct 01, 2009
My computer does not recognize my sansa clip
font.f1 {font: 12.0px Times} Hello and thanks for contacting FixYa Technical Support.
Anytime there is an issue where your Sansa clip is not recognized by your computer, run the firmware update for your version of Operating system (Windows, Mac or Linux)
Firmware is software for the hardware itself, so if there is a case, where the hardware connecting via a USB port like your Sansa clip is not recognizing, going to the manufacturer's website and updating the firmware for their specific product you purchased, is a step in the right direction.
For your benefit, I have provided the link to the Sansa Support page, where you can download and install the most current firmware update for your Sansa Clip.
Download Sansa Firmware Updater
Also, for regular operation of your Sansa clip, make sure you are following these steps for use of this device:
  1. Turn on the Clip
  2. Put the device in Hold (move Hold button until orange is showing)
  3. Press and hold the Center Button
  4. Plug the mini-USB connector into the device (be sure the USB is plugged into the computer)
  5. Wait for the Clip drive to mount
  6. Follow instructions below and drag files to the Clip drive
Let me know if this helps.
Regards,
-Mactechtrainer
Apr 28, 2010 | SanDisk Sansa Clip MP3 Player
My computer will not recognise SanDisk Clip
See if you can download the driver for it on Sandisks site, this should make it possible for your computer to recognize it. You may also want to try a different usb cord, USB cords go faulty quite easily.
Nov 08, 2009 | SanDisk Sansa Clip MP3 Player
Is there driver/ software for Win ME for the Sansa Clip mp3?
a friend told me that if the device shows as"connected" when hooked up (it does) AND the battery charges correctly (it does), then (a)the USB connection had enough juice; and (b) the PC recognizes it - i just had to FIND it. device manager/ MyComputer: nada; same for ANY file/ folder with "sansa" or "sandisk." working thru WMP (Windows Media Player), however, I discovered that drive E - for a portable hard drive, NOT currently connected via USB - was STILL showing up in the "Copy to CD or device" field. sure enough, it was the SanDisk clip player (even though it was NOT under the "Recognized Portable Devices" subsection). without using the installation disk at all, it downloaded tunes just fine. *note: the installation disk seemed to be an .exe file ONLY for the Rhapsody music service. as noted above, it was unnecessary. also - my USB ports are 1.1 and not 2.0, and package stated USB 2.0 was a "minimum requirement" - not true*
Jun 17, 2009 | SanDisk Sansa Clip MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Brand new Sansa Clip not recognized in My Computer
Hello!!
try connecting it to other USB slots!!
Nov 04, 2008 | SanDisk Sansa Clip MP3 Player
My computer wont recognize my mp3
I know this is only part of the solution:
- turn off your sansa clip
- put the slide button on hold
- press the centered button while connecting the sansa clip to your pc
the sansa clip will now be visible as a removable disk under 'my computer' :-)
I don't yet know how to proceed from here on
Sep 20, 2008 | SanDisk Sansa Clip MP3 Player
Ask about my sansa clip
does it come with anything else like a cd or usb clip with the software?
Apr 28, 2008 | SanDisk Sansa Clip MP3 Player
Computer doesn't recognize MP3 player -
Make sure you are using a data transfer cable, and not just a "Charge Only Cable"... There is a difference, and they may look similar and both connect via USB so it can be tricky.
Apr 06, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip problems with driver
Comment by vickisanchez, posted on Mar 19, 2008 IT FINALLY WORKS !!!!
Sandisk Tech support had me do the following:
- Turn it OFF
- Put it in the HOLD position
- HOLD the center button IN while plugging into USB port, continue to hold for 5 to 7 sec even after plugged in.
At this point MY COMPUTER recognized it. And it worked.
He also had me to:
- go to WWW.MICROSOFT.COM
- In the upper right hand search bar, type in MTP PORTING KIT
I did this and downloaded the first one. Now my Sansa Clip work perfect. I wish I would have talked to him last week before I returned the last one, for the same reasons.
If this does not help call the 1-800 # , opt #4, and ask for GUY (yes that is really his name) out of 5 or so calls to Tech Support he is the only one who knew what he was doing, and how to actually HELP.
GOOD LUCK
Mar 01, 2008 | SanDisk Sansa Clip MP3 Player
- Turn it OFF
He also had me to:
GOOD LUCK
Oct 25, 2007 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
101 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
