Question about HP Computers & Internet
SR5550R DESKTOP SETUP DETAILS LAYOUT INS OUTS
SR5550R DESKTOP
HARDWARE CONNECTIONS INPUTS OURPUTS
  • HP Master
  • 19,396 Answers
S550R was sold only in eastern Europe, therefore I will publish documentation for the analog model SR5550f:
Click here to see main input output on installation poster.
All manuals here. » Getting Started Guide 40.23M » Advanced Setup Guide 5.31M » Setup Poster
Here support page.
Input outputs are Monitor, Audio speakers out (green jack), Audio mic in (red), and aux (blue, often not used). Here how to connect monitor and speakers. also input from Keyboard and mouse on Ps1. Additionally computer has several USB, a LAN card and an integrated modem (optional). This PC can also have card reader and has a power cord.
» Setting up a Monitor
Connecting Speakers in Windows Vista.
See also:
» Manuals » FAQs
Posted on Sep 30, 2009
Having problems connecting speakers via a power amp in to my behringer x2222 usb mixing desk - im not getting the ins and outs correct :(
I had a like problem with a crown amp. I found it was in the amp settings , nothing to do with the mixer set up. We had it a mono setting. Take a look at your amp set up book, i'll almost bet thats where the problem is
Dec 06, 2012 | Behringer Xenyx X2222USB USB Audio Mixer
I have a Kenwood VR-507 trying to hook up Teac EQA-120 Home Equalizer
As with any stereo analog device, processor or tape deck - Outs go to Ins. But any typical AVR will only be able to use it for analog stereo sources. Once a Tape Loop is engaged all digital inputs are disabled though you CAN still use DSP effects on the analog sources.
Sep 11, 2011 | Teac EQA-120 Home Equalizer
How do i connect an equalizer model gr-408 to a receiver vsx-d508
In any tape loop (MD/Tape 1 or Tape 2 Monitor), OUTs to INs, BUT it will only be useful for stereo analog sources as activation of the loop disables any digital audio inputs.
http://www.opweb.de/model.php?id=328
Aug 14, 2011 | Pioneer VSX-D508
I have a numark cd1 combo and i need to connect it my preamp and
1-RCA outs on the cd1, right? Route to ins on the preamp (use adapters if necessary, you don't say what pre and eq you have)
2- if the pre has an effect loop/aux bus or whatever, install the eq in the loop, and output the pre to the ins on the power amp; otherwise route the outs from the pre through the ins on eq then to power amp ins.
Jul 01, 2009 | Audio Players & Recorders
How would you connect a Roland Space Echo direct into a Behringer 2642a mixing desk? Have tryed all inputs/outputs with nothing. Could this be because the mixing desk has ballanced ins/outs and the Roland...
In order for this to work, you need what is called an "insert" cable. This will have a balanced 1/4" connector on one end and 2 1/4" mono-connectors on the other. The balanced connector is also known as a TRS connector (Tip,Ring,Sleeve). You should have "insert" jacks on the mixer. Place the balanced connector into whatever insert you wish to use (usually this is inserted into the main insert). One of the 1/4 plugs is for input, one for output. I don't know which is which for your specific unit, you will have to experiment. Keep us posted. Dan
Jun 12, 2009 | Behringer Audio Players & Recorders
Is my txsr605 compatible with a dxrd511
Yes it will. Connect it using the ins and outs of one of the "Tape" inputs and it should work very well.
Feb 26, 2009 | Onkyo TX-SR605 Receiver
Sherwood 460 equalizer hook up
Connect the EQ to the Sherwood as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop.
The CD player should be connected to the receiver though the CD in's and out's (or if your Sherwood doesn't have a CD in/out, then use AUX or TAPE2).
To hear the EQed signal with all receiver sources (like the CD player) you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Jan 09, 2008 | Audio Players & Recorders
Connection between CD, EQ, SP technics
Each unit (the EQ and the Processor) should have left/right in/out rca jacks as well as L/R tape in/outs. The EQ or processor use the receiver's tape loop and then provide a tape loop to replace the one they've used on the receiver.
You plug the first unit (let's say the Sound Processor into your receiver/amp as if it were a tape deck (Processor's outs connect to reciever's tape ins (play) while the Processor's ins connect to the receiver's tape outs (record).
Then you chain the EQ off the Processor in the same way (EQ outs connect to Processor's tape ins (play) and EQ ins connect to the Processor's tape outs (record).
Last you connect the tape deck to the EQ as follows. Tape deck outs connect to EQ's tape ins (play) and the tape deck ins connect to the EQ's outs (record).
This will put both the Sound Processor and the EQ in the receiver's tape loop. In order to have all the receiver's source signals routed through them you may have to engage a Tape Monitor switch or button somwhere on your amp which will route the tape loop to your speakers.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Help
Just connect you EQ to your receiver as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
This will put the EQ in your receiver's tape loop. To hear the EQed signal with all receiver sources you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Nov 22, 2007 | Technics RS-TR272 Single Cassette Deck
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
