Question about Kenmore 62602 Electric Dryer
We recently bought a kenmore dryer 90 series. before we bought it the previous owner started it up for us and it worke fine. so wemoved about 20 miles from there to here and now we plug it in and....nothing! it does not at all!! help!! any suggestions? common problems that happen during moves? kenmore 90 series troubleshooting?
  • beautiful151 Oct 01, 2009
    Thank you we found the problem, and this is our first washer and dryer!! were pretty young with 2 small kids, thanks foryour info.!
  • Controlfrk
    Controlfrk May 11, 2010
    The first question that screams to be asked is why you replaced your last dryer. It's quite possible you got rid of your last dryer for a problem in the house and not the dryer. The obvious and most likely cause is an electrical problem in your household dryer circuit. Dryers aren't susceptible to "moving" problems. Check for 240V between the two outside terminals at the wall outlet and 120V between each left-to-center and right-to-center terminals. If you attached a cord it may be that you hooked it up wrong. If these things don't solve your problem, come back with full model number from inside door.
  • 51 Answers
Power cord maybe incorect or check the breaker. nothing can really go wrong with it moving
Posted on Oct 01, 2009
What type of screws do I need for a Kenmore 80 series dryer power cord (where the three screws hold the wire to the terminal)
They are machine screws. Remove the terminal block and take it to the hardware store to match the size of the "lugs." Terminal Block 5304409888
Oct 14, 2016 | Kenmore Dryers
Kenmore series 90 dryer worked fine until water got underneath it, it ran fine for a while after it was expose to water but now it wom't start up.
sounds like the motor is bad.i live near boston,we had bad rain storms a few months ago and all i did was change out dryer motors that were under water
Jul 02, 2010 | Kenmore 73952 Gas Dryer
Need help with gas dryer Kenmore 90 series serial
Check the lint caught in the exhaust vents. If it is clear replace the spark ignitor if no click is hear upon starting up
May 14, 2010 | Kenmore 73952 Gas Dryer
My Kenmore 90 series electric dryer not running
http://www.washerwizzards.com ,,,,check the thermofuse in the back,,it is a white fuse coverd in plastic with 2 wires attached ,,,,hook the 2 wires together and test it
Dec 23, 2009 | Kenmore 63942 Dryer
Dryer cuts out
Either a bad motor or power problem . If dryer has been there for a while and worked fine , then motor is bad . If dryer has recently gotten there , check the cord to make sure it's connected properly , and the wall receptical has 240 volts where it should be ( both 1/2 " straight terminals ) The " L " is ground .
Aug 20, 2009 | Kenmore 659 Electric Dryer
I have a Kenmore Series 90 gas dryer. Works fine.
The only source of a gas leak from inside the dryer itself is the gas valve. They can sometimes leak a little gas when you first turn the gas on after hooking it up. If your gas pressure is normal (and I'm guessing the plumber checked it) and your other gas appliances are working properly, the dryer gas valve is faulty and should be checked by a qualified appliance servicer.
Apr 14, 2009 | Kenmore Dryers
Kenmore 90 series won't start timer ticks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
Kenmore 62602 Electric Dryer Logo
195 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
