Question about Maytag Dryers
How to open top of dryer - Maytag Dryers
  • Controlfrk
    Controlfrk May 11, 2010
    Numerous model styles are made under the Maytag name. You will need model number to receive accurate information. Usually somewhere inside the door.
    Problem Solver:
  • 10 Answers
On most all Maytag dryers (true Maytag dryers, not Whilpools brand), you access the dryer from the rear panel, not the top.
Posted on Oct 01, 2009
Drum hitting dryer top
Sounds like the bearing seals may be getting worn. You will need to open the top of the dryer and look for wear marks.
Oct 17, 2012 | Whirlpool LGB6300 Gas Dryer
Need to open top of maytag dryer model#LDE93OGACE how do you open top of dryer
Most dryers open the same way. When facing the front of the dryer,take a flat blade screwdriver & pry up the left & right corners. There is a spring snap that will pop out. Then lift up the lid. It should be hinged at the back.
To close just push down firmly.
Apr 04, 2012 | Whirlpool Dryers
A paddle inside drum is loose, need to open top of dryer
first take the door out from the hinges then the frame around the door the you can open the top or the front of your machine...
May 01, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do I open the case on a GE dryer?
Of corse there is some variation among different GE models, but in general there will be one of two methods. Disconnect from power, then: 1. Open door and look for screws from top area of front panel into the dryer top to allow top to open, which in turn allows front panel to be removed. 2. If no screws, then use a putty knife to push in on the two clips which secure the top to the front panel. (right in the seam, front panel to dryer top, a couple inches in from each side.)
Sep 22, 2009 | GE DBSR453EBWW Electric Dryer
How do I open the case on a GE dryer? I am trying to replace the drum belt on my dryer and cannot open the case to gain access to in the inside of the machine
The belt goes on around the drum from the front.
Sep 22, 2009 | Dryers
Maytag PYE2300 AZE electric dryer
Unplug the cord of the dryer before starting.
Raise top by placing a putty knife between top and front in the seam between the two about 2 inches in from each edge and lifting up at the same time. Raise top to full open position.
Look down inside the open top dryer at each side there will be a screw on each side a few inches down. Leaning against the front remove the two screw and pull the top forward a few inches and raise it from the supports at bottom then swing it aside protecting any wiring.
This will give you access to the underside of the dryer.
Reverse the disassembly process to reassemble the front and top being careful not to disconnect any wiring.
Sep 19, 2009 | Maytag Dryers
One of the 3 arm or flip in dryer is very loose
Remove the top of the dryer by removing the four screws in the back. the entire top should slide forward an inch allow you to lift and pivot the top off to the side. it will not come off entirely because of electrical wires. with that moved off to the side you should see the top of the drum. reach in the front door of the dryer and rotate the drum so that the loose blade is at the top. in that position you should be able to tighten the screws.
Jun 26, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Can't open the dryer to check the belts. Where are the screws to view the motor?
OK. There is only one belt. To open the dryer, pull forward on the TOP of the dryer at the corners. You may have to open the lint filter cover and remove 2 screws holding the lint filter guide in place.
The top is held in place by two clips that, when you pull forward on the top, will release. Pull forward and lift up. I always put a knee up right below the top in the center to aid in making sure the dryer doesn't move when pulling on the top.
The top will then lift up from the front tilting backwards.
Jun 24, 2009 | Hotpoint NBXR463EBWW Electric Dryer
Where do I find the heating element in my hotpoint dryer
Heating element is behind the drum. Disconnect power. Use putty knife to release 2 spring clips holding top at front edge of dryer. Swing top back. Remove two screws holding dryer front to sides near open top. Swing dryer front to the side. (you don't have to disconnect the door switch wires) Remove plastic tub block at top center of opening. Release belt. Pull up on back of drum, then pull drum out through the open front of dryer.
Sep 12, 2008 | Hotpoint NLL113EYWO Electric Dryer
DRYER HEATS ,BUT DOESN'T TURN
FIRST UNPLUG UNIT!!
Remove 2 screws by filter area on main top.
Grab back of dryer and pull top forward while holding dryer in place with knees. Do this to pop up top on front left then front right. Remove 2 screws holding front panel 2 side panels. They are at top front of side panels, inside.
Pull front panel out at top and pull up to remove front panel. Put belt around drum with grooved side toward drum.
Nov 11, 2007 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
177 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
