Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
We have water pouring into the refridgerator from time to time.
  • 4,070 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 30, 2009
Water pouring out of the bottom
Oh you don't want that.
Jun 18, 2017 | Refrigerators
Water collects at bottom of refridgerator after a few days
Defrost water drain is plugged. find drain under evaporator in freezer **** out and pour hot water down it
Jun 22, 2011 | Frigidaire FRT21H8 Top Freezer...
There is water in the refridgerator
You have a disconnected defrost drain pan. You will need inspect the ceiling of your refrigerator compartment and find the drain hose going from your freezer to your fridge then the drain pan. Sometimes this is molded into the plastic at the back of your fridge and it simply leaking out the joint. Start by defrosting your freezer, then pour water in the freezer itself while checking the ceiling of the fridge for water traces. Keep a wet/dry shop vac handy or a mop to keep up with the excess drainage. Then reattach the hose to the little drain nozzle when you find it.
Mar 13, 2010 | SUMMIT Professional FF1615SS Refrigerator
Water dripping sound coming from new refridgerator
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan. This is the only source of water if nothing else is connected. Are you seeing and water anywhere.
Jan 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Cannot found drip pan, about once a day I see a pool on water on floor on freezer side
take out bottom basket,if it's frozen in melt it out with hair dryer,usually when this happens the drain is blocked and water will be outside of freezer door you have to melt out drain then blow out the drain line i use a steamer,you can try pouring hot water down drain line but alot of times slime forms in there and it has to be blown out with steamer or getting some kind of hose like the water lines used on the refridgerator wter lines and blow through it to unblock it,check it by pouring water down drain to see if it's clear
Nov 08, 2009 | Hotpoint HSS25GDMWW Side by Side...
Whirlpool manuel for model ed2phexmb00 refridgerator
Pour about 1/2 cup of water into icemaker . If it dumps , replace the water valve . If doesn't dump , replace the icemaker . Also make sure the coils are clean of dust , lint , etc...
Aug 09, 2009 | Whirlpool Refrigerators
Water in my refridgerator
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Jan 26, 2009 | Refrigerators
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Refrigerators
Water is pouring out of the top of the ice maker
you have to replace the ice maker .the water is metered via a timer built in it, the unit is not wrth servicing. they cost around 50$ you can do it yourself, they come with instructions. Good luck.
Jan 06, 2009 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
62 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
