Question about Kitchen Ranges
Kenmore Elite 790 Range
The inner coil of the triple surface element quit working. Everything else on the cooktop and the oven is working fine.
Any help or suggestions would be appreciated.
  • 13 more comments
  • AMetsFan Dec 21, 2007
    Today, my Elite 790 inner coil also stopped working! A little too coincidental that this also happened to someone else.
    When I turn on the burner, I can hear like a relay click on, but it does not heat. The middle and outer burners are fine.
  • ocfixer Jan 14, 2008
    I'm having the same problem with the inner coil not working for the SECOND time. The first time this happened the range was still under warranty & the Sears' repairman replaced the entire coil unit. Now, one year almost to the day I have the same problem & of course the warranty no longer applies. I will be ordering a new coil & replacing it myself unless someone knows of another solution. I will no longer deal with Sears. They charge $65.00 just to walk in the door & the cost of this repair will be over $300.00. This range is not even 2 years old!
  • sapphirellc Apr 30, 2008
    can anybody advise on DIY repair/replacement for inner coil electric element. The middle and outside elements work
    Kenmore Elite Model No 7909912
  • Anonymous May 18, 2008
    Same problem here... this has already been replaced once.
  • kcanderman Aug 18, 2008
    My triple burner does not seem to heat evenly. I've had sears out twice to replace and the repairmen say that is the way it is supposed to work. Can anyone tell me if the three rings should glow evenly when all three are on? My center is very bright but the others very weak.
  • Anonymous Nov 15, 2008
    I too have this same problem. Kenmore Elite model 790. Is there a solution to this as to why only the inner burner is going out?
  • f789 Nov 15, 2008
    I too am having a problem with the Kenmore Elite Model 790 inner burner not working but the middle and outer are. Has anyone heard as to why this is happening? Seems to be more than coincidence! Sounds like a design problem?
  • Anonymous Dec 01, 2008
    Same problem here. The range is about three years old, but one would expect the burners to function properly for that short a time span. From the frequency of this problem, it appears to be more than coincidence.
  • Anonymous Dec 14, 2008
    Same problem and the stove is 16 months old. The inner circle of the triple burner does not work.
  • vicki527 Dec 27, 2008
    Our middle element is out on our Kenmore Elite 790. We are under service warranty, but after over 2 months we have yet to get it replaced. The problem is that every new element that is sent out arrives broken. We just received another one today and it was broken. I think this makes number 8. Sometimes it is UPSs fault by the obvious damage to the package. Sometimes it is poor packaging. Bottom line although we have a service agreement I cannot get a new element that is not broken. Very frustrating.
  • dbob1 Jan 03, 2009
    Good grief! We've had our model 790 for just 6 months and the inner burner on the dual element has stopped working. Based on the comments posted so far I expect this will be a continuing problem. Sears should extend the warranty on this design failure.
  • darwal61 Jan 09, 2009
    My 790 is 21 months old and the center went out on the triple element.
  • Anonymous Jan 24, 2009
    Same problem ,13 months old. Will not buy Sears again. Mike
  • car357 Feb 14, 2009
    I have the same problem. Kenmore 790 inner coil not working on the Triple Element.
  • Anonymous Apr 14, 2009
    I have a duel element and the inner just went. The outer works fine. The oven is 3 yrs old, so I guess I can't complain too much compared to the others.
I can't believe I found this today. Today, my Elite 790 inner coil also stopped working! A little too coincidental.
Posted on Dec 21, 2007
I have had the exact same problem and have only had the stove for 1.5 yrs.
Posted on Jun 27, 2008
I had the same concern on ours which is only 30 days old. The middle element was darker than the inner and outer. Service man just came. He called their technical department and was told that the middle element is supposed to not be as bright. He measured voltages to each element and the continuity of each element. Sears says it is supposed to be this way. Don't know if it's true. I do see that the middle element does react to being turned on (a little) but doesn't seem to add much heat. If it is truly correct, seems like a poor design. Takes forever to boil water on that burner.
I am having another item replaced on it. When the next service technician comes, I will ask the same question to see what they say.
If any others know if the Sear's info is correct or not, please post it.
Posted on Apr 24, 2009
Looking for instructions on how to replace the main cooktop on our kenmore elite elecric range, model 790
To raise and lower the cooktop:
1. Remove all items from cooktop and set aside.
2. Grasp the sides of the cooktop and then lift from the
3. Lift the cookop high enough to allow the support rods
to snap into place. The llft-up rods will support the
cooktop in the raised position.
4. If necessary, clean underneath using hot, soapy water
and a clean cloth; then dry.
5. To lower the cooktop, grasp the front corner of each
side of the top while pushing back on each rod with
the heel of your hand. This will release the notched
support. Hold the range cooktop and gently slide the
top back down level to the range.
Aug 03, 2016 | Kenmore Kitchen Ranges
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
Removing the top of my Kenmore model 790
You could have asked in the original post. :>)
Look at the upper rail of the oven at the front. Look for clips that unscrew and will allow you to tilt the top backwards.
Oct 29, 2015 | Kenmore ELITE 790 30 FREESTANDING DUAL...
How many watts does my range need or use?
Check the plate on side or back of appliance for this info!
Dec 31, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Kenmore electric range model 790 oven stopped functioning, both broiler and bake. however, oven light still comes on.
I believe there is a thermal fuse (also called a TCO or Thermal Cut-Out) located either on the back of the oven, or between the top of the oven and the cooktop that has opened up. Did this happen after running a self-clean cycle?
Sep 09, 2014 | Kenmore Kitchen Ranges
Electric range surface elements not working after self clean cycle.
It sounds like it is broken. You can bypass it by connecting the 2 wires together. This should be fine until you replace it. They aren't that expensive.
Mar 06, 2013 | GE Ovens
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
Kenmore electric range 790. Both the broil and
Kenmore oven 790.91072601, bake & broil not working, relays are cycling but no heat... Sounds like I have the same problem but its the night before Thanksgiving and Iam in panic mode... I've orderd a new Temp Probe part # 316233902. did you ever get yours fixed
Jul 13, 2009 | Kenmore Kitchen Ranges
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Kitchen Ranges Logo
1,591 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
