Question about Dishwashers
Asko DW 1353 not draining
My Asko DW (Model #1353) is not draining...we've cleared the drain and pump and then replaced the pump with the spare we had and it is still not draining.
All hoses were checked and seem clear.
  • Zindadil Feb 25, 2008
    I have a ASKO Dw95.2 and for some time I am having problems. It wont drain. When I started a cycle earlier it used to drain the small amount of water from the pan first and then start the fill cycle.
    Just a couple of days ago the pan was full and the machine did not drain. I restarted another cycle but this time the water did not drain. The wash cycle was “OK” but in between it did not drain nor drained at the end.
    I drained the water from the drain pipe via a Vacuum pump. After that the dishwasher did not fill in with fresh water and just hums. The start stop knob completes the cycle without the dishwasher wash cycle.
    What could be the problem and please offer me a solution. I am a handy man and know simple to hard “how to install skills” but very poor trouble shooting.
    I have a feeling either it has to be the solenoid (because the wash cycle did not trigger after I drained the water) or the drain pump is broken.
5 Suggested Answers
bluegreenash
  • 661 Answers
SOURCE: Not draining...hose clear
not really, it sounds like you have done all the basics,
Posted on Oct 09, 2007
  • 101 Answers
SOURCE: Dishwasher is full of water
The drain pump needs to be replace.
Posted on Apr 26, 2008
  • 10865 Answers
SOURCE: Kenmore portable dishwasher not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Posted on May 28, 2009
SOURCE: Hi, we have an Asko D3122 dish washer, pump runs
Did you ever find out what the problem was?
Posted on Mar 10, 2012
Asko advisory center
Try these... -Clean out the drain pump inside and below.
- Pull the suction boot off the drain pump, clean out any gookus.
- Blow through the drain hose starting from the connection at the pump.
make sure it is not clogged follow the line from under the sink and disonnect it from under the sink and make sure it is clear
- If all else checks out, replace the pump.
The Duet hides the pump/filter access behind the lower panel. Most LG, Miele and ASKO washers have it right up front for easy access. I guess keeping such a base element out of view helps sales.
Long Drain error code.
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
Press, PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the "F2 error code" will be displayed.
Potential Causes:(1) Check the drain hose and make sure it is not plugged or kinked.
(2) Check the electrical connections at the pump and make sure the pump is running.
(3) Check the drain pump filter for foreign objects.
If the above does not correct the problem replace the pump
Mar 07, 2018 | Asko D1776 Stainless Steel Built-in...
Hi I had f2 flash up on the control panel so we drained it and turned it back on it now shows 5 on the control panel and wont do anything else it is a ASKO D1976
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be there when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now. Hope it helps...
Daniel
Jun 08, 2011 | Asko D1976 Built-in Dishwasher
My Asko Dishwasher D1976 on the main panel all of the top lights are on and in the display window it flashes F2. The motor is on but nothing else is happening can you help. I have checked that drains are...
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now.
Hope it helps...
Daniel
Apr 22, 2011 | Asko D1976CSTM Built-in Dishwasher
Asko 1755 dishwasher. The pump keeps running We need to replace a new PCB P/N: DW955 8057931-05 Is it available?
My Asko Model 1585, Type DW 95.4 Circulation pump just died. I have the following parts available (All in working condition):
* 8057931-05 Control Board (this is the replacement part AFTER the recall)
* 8057083 Drain Pump
* 8057085 Fan circulation module (the one in the dishwasher door)
* 8057077 Heating Element
Photos and motor/coil/element resistance values available on request. I have no prices listed as I am still trying to determine their value. I am an old Boy Scout & NOT out to screw anybody.
Feb 20, 2011 | Dishwashers
Asko washing machine won't drain.
Further on to this F3 problem I had the issue on model W6461. There is a short cut to the fix, instead of taking off the grey pipe from the drain pump (the hose clips are pre crimped in the factory so as stated above are difficult to remove) try this.
Stages as follows:
1) Open drain pump door (bottom left of machine).
2) Remove black pipe and drain residual water.
3) Unscrew coin trap and remove, use a container to hold the water.
4) Leave the container underneath and make sure you have some towels ready (I didn't at the time)
5) Where the washing machine drain hose connects to the outlet or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear through back the coin trap.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water.
Just ran the machine now and fault cleared.
Good luck
Jurgo
Apr 30, 2010 | Asko W660
Asko model 1776 that doesn't drain. We stored it for years and have installed it without any installation guides. It was from a construction auction and it had some mice living in it in the shed. I...
Remove the drain hose and make sure its clear. Inspect the pump outlet where the hose attaches and make sure itts clear. Usually insects build nests in the end of the hoses during storage. If this is not the problem, and it does spray water during the wash cycle, it is either the separate drain pump or the control board. test the drain pump to see if it has resisitance (unplug the unit first) if not it is bad. If the pump has resistance it may be seized. Last check the control board.
Feb 12, 2010 | Asko D1776 Built-in Dishwasher
DW doesn't pump out. Pump doesn't come on. There
If the water doesn't drain from your dishwasher, check these:
  1. Drain line/air gap--A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump--You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid---The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt---A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor---Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Oct 09, 2009 | Frigidaire Dishwashers
Asko 1805 Frozen
Sounds like the controlunit is bad.
Jan 01, 2008 | Asko 24 in. 1805 Built-in Dishwasher
Dishwashers Logo
108 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
