Question about Whirlpool GEW9250 Electric Dryer
My Whirlpool Duet dryer's electronic controls are not functioning properly. When I press cancel, the dryer starts. Some of the dryer options are working and some aren't. What is the problem?
I have a four year replacement warranty and so I called customer service and a certified repairman is scheduled for tomorrow morning. Thanks.
Jubilant
Posted on Oct 01, 2009
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
We have a whirlpool duet gas front loader dryer and one morning the front panel says control lock?? What's solution for that??
The Control Lock is a child lock option. This prevents the dryer being started or the cycle being changed when it shouldn't. To toggle this off, you need to press and hold the Control Lock button on the WGD9550WL for 3 or more seconds. Other dryers use pressing and holding Cancel or two separate buttons for the feature. The appropriate button or set of buttons will usually have a Hold for 3 seconds label below or on the key in a small font.
The manual will also have the information on toggling the control lock on and off. Most Whirlpool manuals are available here: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView . Put your model number in the search box and press the right arrow. For dryers the model number is inside the door on the rim of the dryer. If you add a comment with your Whirlpool model number, I will be glad to check if there a different Control Lock option for that Duet model.
I hope this helps.
Sep 07, 2011 | Whirlpool Dryers
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
How do you get the control lock off? my dryer will not start
TO DISABLE: Press and hold the END OF CYCLE SIGNAL button for
3 seconds.
When the dryer is running and Control Locked is on, the
dryer can be stopped by pressing the Pause/Cancel button, but
can’t be restarted until the control is unlocked.
The manual can be found here.
Jul 07, 2009 | Whirlpool GEW9250 Electric Dryer
Control panel on my whirlpool dishwaher not functioning properly
The console (control panel) is defective. The buttons may be getting stuck and/or are corroded.
Feb 20, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Whirlpool duet dryer will not start. Panel lights come on as usual and when press start machine clicks and will not start. Light on wet sensor lights and no drying action begins.
press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly. This is a secret test and reset for your dryers control, so please keep this between us. The whirlpool people would be heart broke if they see this posted on the web ;-) . If your dryer will still not start after this test, you may need a new control. If you need a part let me know and I can ship it right to you. Good luck and I hope this will fixYa and saves you the $400.00 it would cost for whirlpool to send a certified tech to come to your home.
Mike Anderson
Anderson Appliance Repair
9865)945-3808
Dec 01, 2008 | Whirlpool GEW9200L Electric Dryer
Activate the diagnostic test mode.
1. Within 5 seconds, press more time-less time-more time-less time.
2. All indicators should now be on and "88" displayed.
3. Press dryness level button. All LEDs in group should turn off.
4. Press control on button. Control locked should turn off.
5. Open door. Press cancel.
Oct 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
118 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
