Question about Refrigerators
Mold/Bacteria formed behind ice dispenser spout and above dispenser lever. Can spout be removed for cleaning? If not, How to clean?
  • 4,059 Answers
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Although you may can clean it by just spraying everything you can reach with a spray bottle of bleach and water mix and let it set for a while and then rinse with clean water. Test an inconspicuous spot the check for damage. Or another mold killer may work just as well.
Posted on Sep 30, 2009
My Samsung Model: RF4287HARS refrigerator stopped DISPENSING ice. It makes it, but only water comes out of both push levers now. I get ZERO help from samsung customer service. There is nothing in
The problem is actually in the dispenser lever. The paddle that you press to dispense ice has a plastic lever/arm that extends behind it (you can't see it, it's up high in the assembly.) This plastic lever presses upwards when you push the paddle and presses into a switch. The switch actuates the ice. This little lever is also the ONLY thing that stops the paddle from continuing to press into the water paddle. So when the lever breaks, it creates your two symptoms - no ice and if you press further, you press the water switch and get water.
You need part# DA97-08519A. This is the lever assembly with the switches. You pry the control panel assembly (the whole digital display above the water/ice dispenser) out by inserting a slim pry bar (I used a pocket knife and didn't damage the finish) on one side and working my way around. The assembly is held in place by five plastic tabs (two on each side and one on the top.) When this is removed, the part# above will be obvious.
Sep 08, 2012 | Refrigerators
How to clean water tank as water dispenses with some black stuff
If you look up inside you will mold around the spout. this is were your black stuff is coming from. THe water system is completly sealed and cant be cleaned. However you can flush it. Use a cleaner with bleach in it to remove the mold from dispenser. You also may need to change the chute door . It leaking air is where the mold came from. Ihope this helps.
Aug 21, 2011 | Jenn-Air JCD2389G Side by Side...
I have mold forming on the ice depenser that's next to the water depenser. Is there a way to remove that piece so I can clean it?
with out seeing the brand or model i have to be pretty generic but their should be a removable grate so drips when dispensing ice or water that can be easily lifted and wiped out, if not place a paper towel at bottom of dispenser asm. to catch drips
Jul 23, 2011 | Refrigerators
I;m not getting any water to my ice maker for it to make ice?
It isn't the water supply hose that would be frozen since that is outside of the refrigeration area.You need to verify (if you haven't done so already) that you actually have water supply to the back of the fridge first. If so then take and clean the mesh filter on the fill valve.Use a needle, pin, or a sharp pointed pick to remove it.
Clean the filter (by using toothbrush or a small fine wire brush, and brush it under a slow running water tap). You can see how well you've cleaned it by holding it up to a light and you will see whether there are areas which may require more attention.
Once you are satisfied that it is clean, place it back in and connect your water and test.
Also an icemaker has something called a fill cup, which holds the water from the supply hose as it is being drained into the ice mold. If this ice maker part is not aligned properly, water doesn't make it from the supply valve to the ice mold, and you don't get any ice. Check to make sure your fill cup is properly aligned. You can check this ice maker part by removing the ice bin and having a look, adjusting if necessary. If you have ice forming on the water spout, you could have a leaky water inlet valve, another ice maker part which will need to be repaired.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 30, 2010 | LG LFX25960ST Stainless Steel French Door...
Mold/Bacteria formed between ice dispenser and dispenser lever Can dispenser be removed from lever for cleaning? If not, how to clean?
Use a bathroom mold and bacteria remover spray available from most supermarkets. Also spray down into the feeder on the inside of the door. Make sure you rinse the area thoroughly after use and run water through the water chiller dispenser and run some ice throughthe ice dispenser and throw these away. Then it should be safe to use.
Sep 30, 2009 | Kenmore Refrigerators
Rotten smell coming from water dispenser
change your water filter and clean all the lines for water,you must have an algae,mold buildup in there somewhere,and possibly water got into insulation and has startes to mold
Aug 27, 2009 | Kenmore 53632 / 53634 Side by Side...
Moldy water dispenser area
If you go to geappliances.com click on service and support then click on use and care manuals you can download a use and care manual. Since the refrigerator is white I'd probably use a good bleach spray on the mold be sure to rinse well though so you don't end up ingesting bleach. Chunk of ice sounds like too much water or not enough cold and a qualified tech might not be a bad idea. Good Luck.
Jan 01, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Frs26hf6bw6 ice dispenser lever "sticks" and is "harder" to depress.
try cleaning it it may have mold on it and causing itt to not close
Nov 01, 2008 | Frigidaire FRS26R4A Side by Side...
Ice Dispenser does not work.
Remove the ice tray and clean it throughly with warm water. Let it dry at room temperature and see what happens.
Jul 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Automatic fabric softener dispensor not emptying
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle)by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Feb 15, 2007 | Kenmore 44042 Front Load Washer
Refrigerators Logo
195 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
