Question about Zenith DVP615 Portable DVD Player
Need a new charger mine is broken - Zenith DVP615 Portable DVD Player
    Genius:
  • 1,175 Answers
Find an AC adapter that will put out 9 volts DC at 500mA ( milliamps) or higher ( more than 500mA)
find one that matches the plug on the DVD player
I'm using a Powerline Universal adapter I bought at Walmart. Use the yellow coded plug (+) to the tip
I believe.
If this helps, rate my help
Thanks
Posted on Sep 30, 2009
Charger broken
Mine is too. This must be a recurring problem as several people have the same issues,
Feb 01, 2014 | Toys R Us Tabeo
Broken nc10 charger
Depending on what type of plug it is you may be able to change the fuse.
If the fuse has blown then you really need to know why before plugging it back in to the mains. The charger may have a broken wire in the lead that plugs in to the laptop. Usually it happens right near the plug where it gets bent and twisted. It could also be the internal fuse inside the charger box.
If you can't get it tested properly then a new one is your best bet. They are quite cheap on Ebay. Just look for the one for your make and model number and check to make sure the voltage on your chargers label is the same, it's output voltage is probably 19 volts. The voltage must be the same, NOT lower or higher.
Then have a look at the label for the current which is in Amps, something like 3.15Amps. You can buy one with higher current than the one you have but NOT lower than the label says.
Feb 15, 2012 | Samsung NC10 Netbook
Hi i have an HP Elite Book 6230p,my laptop stop charging recently, i was charging it and i removed my charger plugged in another charger of lower current rating it worked well for a while, but when i...
Nice books, have many. 8540s./. better.
i can not decode this post.
sorry
does it run with no battery and the correct pack
mine has 10 options new the i7 and the fast video card suck huge power and mine needs a 100watt pack, the 65w on mine is HOPELESS. see?
run the correct matching pack,
step 2 a new battery, i keep 2 good ones all the time
on Vacation, id not be wanting to find batteries 3000 south of here, ever. (south of the boarder)
test with no battery
then with correct power pack (the charger is a chip inside the pc and in this 19vdc pack its only a power pack pure DC.
then try a new battery ,
if you read your service manual at HP.com
it tells you all packs used and why, and the match.
sure does.
and varies by OPTIONS DAY1. in all case
unless upgraded like mine, is, and sucks max amps mine does.
Jul 03, 2017 | HP EliteBook 6930p Notebook PC
The light on the charger for my helicopter syma S031 with gyroscope remains green even though it needs charging
Mine has also done this. The charger units for these helicopters are mass produced and therefore have a failure rate. I pugged mine in to the mains supply today and it sounded different, as in it 'popped'. The LED failed to light. When I plugged it into my models battery, it went green, even though the battery was low in voltage.
I metered my charger output and it is dead. My S031 is only two weeks old but to get to the shop is a nightmare so I may just open it up and repair it myself (I'm fine with electronics). However, I am not sure if my new battery pack is okay or not, so I run the risk of visually voiding my charger warranty. I have had issues with all of my Syma models and may just get a refund and move on to swashplate 6ch+ machines.
If your charger/S031 is new, I would suggest you return it to the store you purchased it from. Electronics this day and age are a joke and the quality control used is appalling, especially in cheap Japanese models alas.
The charger is sealed and will need to be broken open to access the electronics. Dangerous voltages are inside so I'd suggest you just return it for an exchange.
Jan 16, 2011 | xheli Syma S031 Outdoor RC Helicopter
When plugging in the dsi charger the orange lite comes on for anout 3 seconds then turns off
Maybe It's because it's chewed up (mine was chewed or something so I got a new one... I've been in the same situation, bud, but I couldn't do anything about the copper wire showing underneath.). Make sure to check the entire cord.
1) Try flicking on a power switch.
2) Unplug the actual charger from the wall, and plug it into a different outlet. The outlet you're using may be broken.
3) Make sure the charger is all of the way plugged into your DSi.
Really hope this helped!
Mar 27, 2010 | Nintendo DS Lite Console
Charge port is broken how do i charge the battery
you need a Universal Battery Charger, the one i have is a Omnipotence AC Travel Charger Adaptor, its for all type of Mobile Phone Battery Batteries. i got mine off amazon only £5
Jun 29, 2009 | LG enV VX9900 Cellular Phone
T43 laptop will not charge the battery
Can you start the laptop on the mains charger? If not then either charger is faulty or dc connector on motherboard is broken
Jun 10, 2009 | IBM ThinkPad T41 Notebook
Charger not supported for nokia 3600s....Help please
May 31, 2009 | Nokia 5200 Cellular Phone
Zenith DVP615 Portable DVD Player Logo
90 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
