Question about Samsung Washing Machines
I have samsung washing machine WA80U3 model with drain problem
I have samsung washing machine WA80U3 model. Its drain is not working fine. Its giving me E5 error. How can i resolve it?Its warranty has just expired and our local customer service is unreachable here in Riyadh, KSA.
The private plumbers are giving me hit and trial suggestions. Someone says the drain pump needs to be replaced and the others are saying the motor is not working fine. So I do not trust them.
I would be thankful for getting me out of this problem.
SOURCE: Kenmore washer stopped with F21 error code
Absolutely correct about the pump. There were coins stuck in the pump.
Posted on May 14, 2008
ronaldo_ross
  • 1056 Answers
SOURCE: Eurotech Washer\Dryer EWC177 does not dry
Unplug the power. At the back are several circuit breakers. make sure they all have continuity. They only open in the event of overload, thermal or electrical. After that they are suppose to clickback to normal. If all of them tested ok, check the continuity of the heating element. You may see a break in the nichrome wire coil, thats the heating element.
Posted on Jun 29, 2009
canbruce75
  • 1776 Answers
SOURCE: Kenmore 70 Series Washing Machine Drains, But Won't Spin
Yes sir, a bad motor coupler could cause the machine not to spin. You did the right thing in checking out the lid switch and the pump first. It sounds as if the motor coupling is worn and may be slipping. I will attach a link to a video that may assist you. Hope this helps and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Posted on Aug 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: My LG washing machine is giving me a dE error
Drain error. It took longer than normal for the machine to drain. This is caused by the wrong detergent, too much detergent, drain hose way too high, slow drain, and my fave: frozen drain. I have your wm2277 deluxe polyunsaturated, 99 and 44/100th% real deal repair manual. Right ova HERE
Posted on Feb 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: Maytag Neptune Washing Machine won't drain
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
What does an E5 code mean?
Make and model helps, but here are all the E5 Error Codes we get asked.
On a cellphone?
E5 code Google Search
On a washing machine
e5 error code code washing machines Google Search
Dishwasher
e5 error code code dishwasher Google Search
Stove / Cooker
e5 error code code stoves Google Search
Fridge
samsung fridge e5 error code Google Search
Aug 27, 2017 | Cell Phones
My samsung wasing mechine does not stop filling water. model wa80u3
it seems the washer's inlet solenoid isn't responding to the diagnostic computer on the washer and needs of replacement contact samsung to have it serviced
Feb 21, 2017 | Samsung Washing Machines
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
WHY DOES SAMSUNG WA80U3 WASH MACH NOT SPIN???
Could be:
1. No AC
2. Blown house or machine fuse.
3. Bad AC cord.
4. Bad on/off switch.
5. Bad Timer.
6.Broken Belt or Gear.
7. Bad Motor.
8. Clogged pump.
9. And more
If you can't find the problem Get professional service or replace it!
Jun 03, 2014 | Washing Machines
Samsung error E5
I don't know about a E5 error; are you sure it's not a 5E error? That means a drain error or "water not draining" error. Check the drain pump and drain hose for an obstruction. If that's okay, and the dishwasher drains water, then you probably have a bad ECS sensor.
Mar 30, 2014 | Samsung DMR77LHS Tall Tub Dishwasher
Hi i have a error coming up on my main cycle E5 Quickwash 30degrees on my washing machine. It is a Samsung WF7600NAS . its not spinning, i have drained and cleaned the filter> please help
'E5' for all Samsung washers decodes as 'water temperature rising/falling too quickly. Check thermistor'.
That, to me, means a service call for you I fear ;-0(
Sorry that we appear to be of no more help remotely on this occasion.
Good luck,
John C
Mar 16, 2011 | Samsung WF337AA Front Load Washer
"dE" on LCD. Filled machine with bucket as water pressure is so low. Also, watewr drains immediately so I keep drain hose above water level in machine: WA80V9
Hi
Thanks for using FixYa. As you have not mentioned the complete model no# and the manufacturers name however, from what you have described error DE can either be drain error or door error. Door error means something is wrong with the door switch and door lock assembly. You should start by checking the door latch as well. If they are working fine then try to clean the drain hose and check the motor brushes(if the machine has motor) if they are worn can also cause this error. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 24, 2010 | Samsung Washing Machines
WATER WILL NOT DRAIN OR SPIN
OE is inded a drainage error.
From what you describe it is most likely that the drain motor is not working properly due to a loose electrical connection or bad motor itself. This is not that easy to verify since it requires some machine moving and disassembly to get at it.
I can give you further instructions if you like...
If your machine is still under warranty you should call someone in for service.
Aug 06, 2008 | LG WM1815CS Front Load Washer
Wahing machine busted
give me the brand and model number so i can know what im dealing with
Dec 31, 2007 | Washing Machines
Washing Machines Logo
868 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
